Cooling Fans Reviews
Six popular140 mm case fans from Alphacool, Arctic, Cooler Master, Corsair, Noiseblocker and Noctua in a comparison test
Reader requests are of course our command and so today we have a big comparison test with 6 popular 140mm case fans. And yes, fans are a dime a dozen, but in the end, which fan fits which system and which budget? Is a model suitable as a case fan and how does it really perform on different radiators? What about the real speed range, how high is the start-up speed and what parameters does such a fan offer over the speed range, including the usually unavoidable noise emission? Exactly for these findings we test, because you should not trust any data sheet that you do not…. well, you know already
Today we are testing a total of six popular 140mm fans, but we also know that of course you can’t cover all your needs with them. But we will continue to test piece by piece (fan by fan) and then also tackle the database as a kind of compendium – but until then there will be individual or group tests to further fill our data. How extensive the results are, you will see on the next pages and today I put in everything that Pascal measured for the 140.
How exactly this all works and runs, you can see on the next page, where we present the test system and measurements once again. And one thing is also clear here: it is not the purchase price of a measuring instrument alone that counts, but its appropriate use and correct calibration. Because you can also sink a lot of money and time for nothing. But that’s why there are consulting industry partners and the almost omniscient community and not just undifferentiated swarm knowledge.
Important preliminary remark
I don’t want to spoil anything and I don’t want to blacken any manufacturer unnecessarily, but I have to make an important preliminary remark. We had already chosen the Noctua NF-A14 FLX as a reference and will continue to use it as a reference for individual tests of 140mm fans, although the Noiseblocker NB-eLoop X PWM B14XP ARGB now performs slightly to significantly better in many test fields. However, there is a good reason why we still stick to the Noctua model, at least in this review.
In the 120mm roundup, as well as now, the first tested fan from Noiseblocker was defective, respectively acted below the specs and consequently had to be replaced. This can happen once, but not several times. This is exactly why, and until the manufacturer gets a better handle on quality control, we will continue to use Noctua’s model. We can measure whether the fan does what it says in the specs (although Noiseblocker also showed deficits here and the homepage has not been corrected to this day), the buyer unfortunately cannot.
Unfortunately, this cannot be tolerated in this amount and must be openly communicated. In the future, sample tests will have to show whether the circumstances have improved and whether all the technical specifications on the packaging and the homepage are really correct. Then this fan can also become the reference.
Maximum speeds in a quick check
We have deliberately chosen 6 fans with very different maximum speeds between 1500 and 2000 rpm and first test whether this specification is also adhered to. In this case, at least everything is already right, at least a good start.
On the next page you will see how and what we test and why. Understanding the details is extremely important in order to be able to objectively classify the results later. The differences between many models are more in the details and THE best fan for all situations can hardly exist. There is a certain optimum in every situation and of course there are also good all-rounders. But they usually have their price. But if you plan to use 60mm radiators for example, you might save money by choosing the best model for your application, which might not perform so well as a case fan. And vise versa, of course.
All previous articles about fans on igor’sLAB
126 Antworten
Göran
160 Kommentare 63 Likes
Sehr interessanter Test. Ich muß sagen Lüfter für über 30€ pro Stück habe ich noch nicht gekauft, aber die Performance des NB ist schon beeindruckend.
Kann es sein das der Noctua bei 100% nicht so gut aussieht, weil er am langsamsten dreht ?
Normalerweise würde ich Arctic kaufen und wenn die Lager irgendwann kommen, dann halt die nächsten ... bei den Preisen ist man selbst mit Versandkosten noch günstig. Aber im Sinne der Nachhaltigkeit ist das natürlich nicht.
Vielen Dank für den Test!
Corro Dedd
2,015 Kommentare 816 Likes
Fehlt noch die Verbindung von Artikel zum Forum und beim eLoop hat sich ein Fehler eingeschlichen, der ist nämlich 29mm dick, nicht 25mm. Daher performt er auch so gut.
ipat66
1,629 Kommentare 1,779 Likes
Unterhaltsamer Artikel...:)
Neue Referenz?
Mir ist aufgefallen,dass der Energieverbrauch ( in min und max – Watt ?) nirgends auftaucht?
Entweder ich bin blind oder es ist nicht vorgesehen?
Ich fände es interessant zu wissen, ob einer nur 2 oder doch schon10 Watt braucht um Luft auf links zu drehen....
Pascal TM-Custom
1,100 Kommentare 1,313 Likes
bist du wohl Still :ROFLMAO: bitte nicht noch eine Messung mehr ich werd noch irre bei so vielen Zahlen und Daten ich muss mittlerweile höllisch aufpassen das immer alles eingetragen ist. Langsam verlier ich vor Tabellen und Balken denn Überblick.
Aber schauen wir mal wie wir das vielleicht noch einbauen können.
Pascal TM-Custom
sagen wir mal so Arctic gibt echt sehr lange Garantie das spricht für Überzeugung Natürlich ist hier dann die Frage wer schickt seinen Lüfter nach 3 Jahren ein oder kauft nicht direkt neuen. Schön ist einfach zu sehen das es nicht immer Premium braucht. Wer Günstig kauft kauft 2 mal das seh ich beim Arctic nicht so. Da hab ich schon Premium gesehen die schon eher die Flügel strecken.
Pascal TM-Custom
wird geprüft danke für Hinweis
12,113 Kommentare 23,912 Likes
Arcaras
77 Kommentare 33 Likes
Könnte auch dran liegen, dass ich es falsch lese, aber irgendwie habe ich das Gefühl, dass auf Seite 10 in der letzten Grafik die Balken teils falsch angezeigt/skaliert werden.
Pascal TM-Custom
ipat66
Die Werte der X-Achse stimmen nicht.....
Pascal TM-Custom
*huch* seh es auch gerade wasn da passiert. Eben die anderen angeschaut die passen wir korrigieren das danke ist uns nicht aufgefallen.
RAZORLIGHT
381 Kommentare 291 Likes
Warum hat man sich bei den Noctuas nicht für die PWM Variante entschieden?
Und nach wie vor keinerlei ungewöhnliche Geräusche beim P14 wie bei mir? P12 zeigt ein ähnliches Verhalten wie ich im anderen Post schon angemerkt hab.
Meine "Sample Size" sind 3x Liquid Freezer II 280 also 6! P14 die allesamt das selbe Verhalten aufgewiesen haben.
Bezüglich der LFII Pumpe hat es Arctic wohl auch nicht so mit der Qulitätskontrolle, aber das lässt ja mittlerweile bei fast allen Herstellern über alle Preisklassen extrem nach.
Dennoch super Tests, bin auf andere Lüfter gespannt, hätten die P14 nicht dieses dämliche Geräusch bei bestimmten (mMn. zu vielen Drehzahlen) wären es für mich die perfekten Lüfter.
25€+ würde ich lediglich für die NF-A12x25 von Noctua ausgeben, bei Noiseblocker ist die Qualitätskontrolle wie angemerkt auch relativ schlecht.
ipat66
Habe auch 5 P14 von Artic verbaut...
Kamen im 5er-Pack.
Alle funktionieren ohne Auffälligkeiten über den gesamten Drehzahlbereich.
Pascal TM-Custom
wir hatten bewusst FLX genommen um das mit Spannungen zu zeigen das Thema ist sowieso etwas speziell.
Was das Geräusch angeht ich weiß jetzt welches du meinst das ist beim last Wechsel. Und ja es ist Radiator abhängig beim 45 und 60er hatte ich das nicht gehört. Aber beim Slim
RAZORLIGHT
Nicht nur beim Lastwechsel, ich hab das bei fest eingestellten Drehzahlen, ~500,800,1000,1200RPM etc.
Die Aufnahmen wurden bei festen Drezhalen gemacht!
LFII Radiator ist 38mm dick.
Wurde auch in 2 verschiedenen Gehäusen getestet.
Phanteks P600s und Fractal Meshify 2
Auf nem Radi oder als Gehäuselüfter?
Mit oder ohne Headset auf dem Kopf ;)
Pascal TM-Custom
glaube das hat echt mit Radiator zu tun manche Lüfter machen da echt ganz komische Geräusche. Ich hab ja die neue AIO da gehabt und mal so getestet mit denn Lüftern war komplett ruhe.
exi78
231 Kommentare 150 Likes
Den Arctic gibts auch als CO-Version mit Doppelkugellager für einen längeren Betrieb, falls sich einer gedanken machen sollte.
Ansonsten wurde es hier ja schon geschrieben, bei dem Preis holte man sich dann einfach den nächsten Lüfter.
Hab nur Erfahrung mit 12cm Lüftern, die eLoops waren immer sehr anfällig, je nachdem sie verbaut waren, haben sie Nebengeräusche fabriziert...
RAZORLIGHT
Naja, das hätte immerhin einen Vorteil, ich könnte die P14 als Gehäuselüfter nehmen und müsste mir nur andere Lüfter für die LFII holen.
Welche AIO hattest du da, die LFII 280 und bei dir war Ruhe?
Gibts Möglichkeiten das Problem zu beseitigen, entkoppeln etc.?
Das Geräusch bleibt, auch wenn ich einen der 2 Lüfter stoppe.
Pascal TM-Custom
ich hatte die neue LFII mit 240 da sind eben die neuen Lüfter drauf mit dem geschlossenen Frame. Also diese ARGB 0DB Lüfter. Ich denke einfach das die Blattform etwas mit Verbindung Radiator zu tun hat.
eine Möglichkeit würde mir einfallen mach mal so kleine Gummi Unterlagscheiben zwischen Lüfter und Radiator damit du bissel abstand bekommst das könnte helfen.
Follow Igor:
