announcements CPU Editor's Desk Practice Reviews Services Software System Technology
PROJECT HYDRA – OC Sandbox for ZEN3 CPUs | Freeware Download
Yuri Bubliy aka 1usmus is now taking a completely different approach with Project Hydra than he did with the former CTR (Clock Tuner for Ryzen), although the focus and goal of both programs are the same: an OC sandbox for optimizing current Ryzen processors from AMD that are based on Zen3. For Project Hydra, Yuri took the well-meant advice and started from scratch, which was visibly good for the new program, because all compromises, such as the attachment to the chipset drivers or the Ryzen Master, were completely shelved and everything was reprogrammed independently or separately.
Yuri also started a Patreon project at the same time to compensate the effort at least to some extent and to collect and evaluate first feedback there. This is also why I waited until today to host the first released installation on igor’sLAB again and also to support it. The old CTR will be not continued and deleted completely, the old links will lead here to this page and Project Hydra will be offered here as freeware for free download within our community exclusively and as a better replacement for the CTR.
The differences between the freeware version offered here and what is also offered furthermore on Patreon as PROJECT HYDRA PRO are not so big, but it is of course free to everyone to become either also a supporter after a successful test, or to be able to test and also use the software furthermore free of charge with only few cutbacks. What makes all this different from each other, you can see here (on page 2 you can also find the roadmap):
HYDRA_10D_Comparison
What’s new? Project Hydra is and can do much more
If and how much you gain at all by overclocking your Zen3 CPU is of course primarily dependent on the quality of the respective CPU. So miracles will certainly not necessarily be expected in the broad masses. However, it has been shown that the presets changed with HYDRA have often resulted in the respective CPU running much more economically and thus naturally cooler. That alone is worth a try and if, depending on the silicon, you get a little more clock for free, all the better.
We will of course evaluate the feedback of the readers together with Yuri within the framework of the community and provide corresponding tutorials if necessary, which can depict the flow of the development much better than a static PDF as a general instruction will ever be able to. The variations due to the different hardware are far too great for that. In this connection I refer of course also to our forum, where also gladly multilingual discussions may and should be.
This first overview shows what HYDRA actually offers.  You will find the introduction and explanation on the next page.
HYDRA_10D_Intro
System requirements
The requirements and also the handling have now become much easier. The following list shows what is required and must be preset and what is not:
  • Requires: Zen 3 CPU like Ryzen 9 5950X, Ryzen 9 5900X, Ryzen 7 5800X, Ryzen 7 5700G, Ryzen 5 5600X and Ryzen 5 5600G
  • Stable, overclocked (or XMP) DRAM.
  • PBO settings – no matter. Disabled (Auto) Curve Optimizer (in UEFI).
  • Recommended values for Manual CPU LLC (Load Line Calibration). ASUS – 3, MSI – 4, ASRock – 2, GIGABYTE – High.
  • CPU Voltage – Auto (in BIOS). Offset is forbidden.
  • Windows 10 build 2004 or newer. Windows 11 fully supported
  • Chipset drivers or Ryzen Master – Not required
  • Actual GPU drivers
  • Power plan – Balanced (recommended)
607 Antworten
Blubbie
808 Kommentare 275 Likes
Lustig und ich dachte Igor und Co sind. Nun unter die SFF case builder gegangen... Weil es den Namen proejt Hydra hier schon länger gibt:
YT Promo entfernt
Project Hydra läuft bereits seit einem Jahr, also noch vor dem YT-Dingens ;)
Hans Yolo
120 Kommentare 25 Likes
ich krieg den Download nicht gestartet, hat jemand anders das Problem?
edit: Link kopieren und selber in einem neuen Tab einfügen hat geholfen
Sci-Man
144 Kommentare 92 Likes
Verstehe ich das nun richtig, dass der CTR für Zen 2 somit ersatzlos gestrichen wurde?
Finde ich zwar schade, da es vermutlich noch einige Zen 2 Nutzer da draußen gibt, aber bei einem Ein-Mann-Projekt auch verständlich.
Ich warte noch auf den Zen 3 refresh bis zum aufrüsten, aber dann werde ich mir den Spaß mit der Hydra bestimmt auch geben :D
leorphee
25 Kommentare 5 Likes
Dann werden wir das mal testen wenn ich etwas Zeit dazu habe. Obwohl ich gestehen muss, dass der CTR noch bis letzte Woche ununterbrochen lief bei mir.
LEIV
1,550 Kommentare 632 Likes
CTR kann man ja trotzdem benutzen, gibt halt keine Anpassungen mehr.
Hydra benutze ich hauptsächlich, wegen den tatsächlich sehr akkuraten Curve optimizer Werten für das bios, damit kann man dann selbst noch etwas feintuning mit PBO betreiben, oder eben mit Hydra
10,227 Kommentare 18,931 Likes
Ich habe überlegt, ob ich es noch stehen lasse. Aber die Downloadzahlen waren in der letzten Zeit so niedrig, dass mir die Relevanz von insgesamt 2 GB an überflüssigen Daten dann doch etwas zu klein erschien. Denn wir wissen ja alle, dass der CTR in den falschen Händen auch zu kapitalen Schäden führen konnte.
m
markward
1 Kommentare 0 Likes
Hat das Projekt auch eine eigene, offizielle Webseite? Die Patreon-Mitgliedschaft wird monatlich bezahlt, heißt das es ist effektiv eine Subscription für die Pro-Variante?
RedF
4,677 Kommentare 2,559 Likes
So wie ich das verstehe kannst du bei Patreon einmal die 9€ zahlen die Pro version Laden und wieder kündigen. Bekommst so halt kein Update von der Pro
noir.
242 Kommentare 156 Likes
Eine eigene Website gibts nicht dazu. War beim CTR ja genauso. Es wird bestimmt wieder den einen oder anderen Partner geben, der das ganze mit hostet (wie hier jetzt) .
Die Patreon-Mitgliedschaft ist kein Abo der Pro-Variante, die funktioniert auch ohne aktive Unterstützung. Aber für den Download selbst muss man schon einmal Unterstützen.
Empfinde ich aber jetzt nicht so als Beinbruch. Wenn die Software gut ist, ist mir das durchaus auch Geld wert. Und der Entwickler freut sich und macht weiter.
edit: Bis jetzt gabs Updates der Pro-Version nur über Patreon.
LEIV
Nein, keine offizielle Webseite.
Das mit der Pro Variante müsste man mal noch mit Yuri abklären, ob 1x Subscription = Pro Variante für immer, oder nur die zu diesem Zeitpunkt aktuelle Pro Variante bedeutet
Kann ich dir leider aktuell noch nicht sagen
RedF
Kannst du das gehate in ein anderes Forum schreiben?
LEIV
Das mit der Spannung und Takt ausloten geht bei den Ryzen genauso einfach.....
Ein Problem ist allerdings, das die CPUs dann nicht mehr ordentlich runter takten im IDLE, und man dann immer diese Spannung anliegen hat.
Warum weiß nur AMD, deshalb gibt es Leute, die sich da ein paar kleine Hilfsmittel ausgedacht haben
Guest
Das Problem bei dieser Software ist, dass sie auf den ersten Blick so tut, als wäre es ja ganz leicht - ein paar Klick und das Programm macht alles für euch. Methodisch bedeuten vier Sets an Konfigurationen (z.B. 1-2C, 2-4C, 5-8C, 9-12C) bei einer Instabilität 2hoch4 mögliche Stellschrauben.
Wird bei Allcore OC das System instabil, habe ich die globalen Parameter Takt und Spannung und bei einer Instabilität kann ich Takt runter und/oder Spannung rauf. Einfach und zuverlässig. Wenn ich aber z.B. 4 verschiedene Sets an Takt/Spannung habe (per Core OC) und irgendwas säuft ab, dann ist Ende im Gelände, weil ich keinen Anhaltspunkt habe, welche der Konfigurationen problematisch ist. Und bei Ryzen und dem Energiemanagement gibt es Quereinflüsse, ich kann nicht einfach sagen 20mv mehr Spannung auf alle Sets, weil dann die anderen Konfigurationen ein zu geringes PowerBudget haben.
Während ich also bei Allcore 2hoch1 Variablen habe (=2), sind es bei vier Sets 2hoch4 (=16). Per-core-OC bei mehr als QuadCore CPUs ist nicht zuverlässig und daran ändert auch kein grafischer Aufsatz etwas. Die Software gaukelt einem eine Leichtigkeit vor, die es nicht gibt.
LEIV
Theoretisch richtig, aber wenn das System abschmiert, sagt Hydra im Log welcher Kern es war, und was man nachstellen soll
Guest
Bei einem BSOD beispielsweise wird gar keine Applikation mehr irgendwas protokollieren, da hast du einfach nur einen Crashdump durch das OS in dem eine Access Violation oder ähnliches zu finden sein wird ohne Bezug auf einen instabilen Kern. Bestenfalls kann Hydra, sofern vorab konfiguriert und protokolliert, sagen das vor dem Crash ein bestimmter Prozess (der vorab definiert wurde) auf CPU Core X ausgeführt wurde und out of the Box läuft sowieso alles erstmal auf allen Kernen, sofern keine Process Affinity gesetzt wird.
Und ich war mit 2hoch4 Stellschrauben ja nur auf Spannung/Takt bezogen, in dem Tool kann man ein paar Dutzend Einstellungen trefffen.
User denen Stabilität auch nur im geringsten wichtig ist, sollten von diesem Tool die Finger lassen. Wer erstmal Freude bei einem Crash hat, weil er einen Grund zum Basteln bekommt, der kann gern zugreifen.
RAZORLIGHT
356 Kommentare 263 Likes
Werde erstmal mehr Erfahrungen der Community abwarten bis ich mich an das Tool ranwage.
Bin gespannt, wann es die ersten Tutorials gibt.
Z690 und ADL sind auch nicht der ideale Mikrokosmos. Das RAM-Gefrickel ist momentan an Peinlichkeit kaum zu überbieten, vor allem mit DDR4. XTU ist auch so eine Ausgeburt der Hölle, also nennen wir es mal ausgleichende Gerechtigkeit. Die VF-Kurve ist von Intel vorgegeben, klappt aber nicht auf jedem Brett.
Die SSD-Performance ist übers Chipset schlechter als auf einem X570 Brett. Auch das nervt. 73xx MB/s zu 68xx MB/s. Rund 500 weniger.
Antwort 4 Likes
Eins gibts ja schon ;)
RedF
Also das mit dem Curve Optimizer werten hat bei mir bestens geklappt.
Follow Igor:
