Cooling CPU Practice Reviews Watercooling
Intel Socket LGA-1700 “washer mod” part 2 – motherboards, ILM manufacturers and coolers in a before/after comparison | Practice
As promised, today we cover part 2 of the “Washermod”, in which we want to evaluate a few more combinations of different motherboards, socket manufacturers and coolers in a before and after test with the modification. To briefly summarize what the washer mod is all about: washers are installed between the motherboard and the ILM (Independent Loading Mechanism) of the LGA1700 socket so that less pressure is exerted on the CPU, which in turn results in a more flat surface and thus better contact with the cooler. Details on theory, implementation and measurement methodology are given in the first part.
LGA1700 manufacturer Lotes vs. Foxconn
Lotes LGA1700
Foxconn LGA1700
In the first part, my guinea pig was a Gigabyte Aorus Z690 Tachyon that uses a socket from Lotes. The question naturally arises whether different base brands could bend differently and thus perhaps produce different results. So here’s the MSI Z690 Unify-X, which uses an LGA1700 socket from Foxconn. Only the manufacturers Foxconn and Lotes are currently available for LGA1700. So with this again I tested all the different thicknesses of washers, since this could have an effect on the bending of possibly softer materials.
MSI MEG Z690 Unify-X (Foxconn), 12900K 51/0/49, 1.35 Vcore LLC7, Corsair XC7 PRO RGB LGA1700:
Washer Config P0 max Δ P1 max Δ P2 max Δ P3 max Δ P4 max Δ P5 max Δ P6 max Δ P7 max Δ Ø relative
stock 59.9 67.9 62.0 72.7 64.1 68.7 62.3 62.0 64.95
0.5 mm 59.9 66.9 61.7 72.0 63.8 66.2 61.9 61.1 64.19 -0.76
0.8 mm 57.2 63.5 61.4 69.9 63.2 66.1 60.2 61.1 62.83 -2.13
1.0 mm 55.0 61.6 58.0 67.0 58.4 62.6 57.7 56.9 59.65 -5.30
1.3 mm 57.2 64.0 61.9 68.1 63.1 63.9 61.9 58.1 62.28 -2.68
In short, here too we end up with around 5 °C improvement with 1.0 mm thick washers compared to the factory version of the socket. After all, the socket manufacturers seem to adhere to Intel’s specification in a very similar way. How useful this is (not), is up for debate. I also once tested plastic vs. steel washers of the same thickness, and again the difference is within the range of measurement tolerance. While I do record the water temperature to within 0.1 °C, only integer values can be returned for the core temperatures, which of course affects the accuracy of the measurements. By the way, on the Unify-X with 1.3 mm washers was the only config with detectable impact on RAM stability in my tests. Though the board performed a new memory training on its own during the first boot, after which the RAM was immediately stable again.
With E-Cores – more efficiency (waste heat)
Since 1.0 mm could be identified as the ideal dimension for the washers for both socket makes – at least according to our measurements – all further tests will only be carried out with this dimension, also to save some time. But on the flipside I also grabbed the Asus Maximus Z690 Apex and the ASRock Z690 PG Riptide and simply tested the CPU with default settings. So PL1 4095W, E-cores active and all clock speeds and voltages on auto, because if we’re honest, a majority of CPUs will run in this state for their entire lives.
Asus Maximus Z690 Apex (Lotes), 12900K, Auto, Corsair XC7 PRO RGB LGA1700:
Washer Config P0 max Δ P1 max Δ P2 max Δ P3 max Δ P4 max Δ P5 max Δ P6 max Δ P7 max Δ E0-3 max Δ E4-7 max Δ Ø rel.
stock 53.7 61.5 58.5 64.5 60.5 61.5 56.5 56.8 45.5 44.5 56.35
1.0 mm 48.8 56.4 53.7 59.4 54.7 58.3 53.3 55.4 43.3 40.8 52.41 -3.94
The difference between the stock and 1.00 mm configs has now shrunk to about 4 °C, but that also fits in with the fact that the heat is now distributed over a larger area in the CPU. The e-cores are each grouped in clusters of 4 cores and only have one temperature sensor together. But they also benefit measurably and reproducibly from the Washermod.
ASRock Z690 PG Riptide (Foxconn), 12900K, auto, Corsair XC7 PRO RGB LGA1700:
stock 57.9 63.5 61.5 69.5 64.5 68.5 60.9 65.4 49.5 50.5 61.17
1.0 mm 53.2 58.4 56.8 61.1 57.0 60.9 55.4 57.2 44.4 44.3 54.87 -6.3
On the Z690 PG Riptide, the gap has increased to almost 6 °C again, whereby this board automatically applies a slightly higher core voltage and thus produces more waste heat, and the measurement tolerance is also a factor. So here the picture of about 4-6 °C improvement by the mod is confirmed as well.
elgreco111
40 Kommentare 3 Likes
Super beschrieben danke für die Recherche. Habe gestern mein neues MB Asus ROG Strix z690 F gaming Wifi mit den Washern umgerüstet und probehalber den Pumpenkopf montiert liegt Plan auf (Corsair H150i Elite Capellix) lt Abdruck der Wärmeleitpaste. Werde die Originale gegen eine Kryonaut extrem tauschen soll angeblich eine der besten sein.
Was mir aufgefallen ist die CPU Halterung war nicht mal handfest vom Werk angeschraubt?? Die Halterung ist ubrigens von Foxconn
D
Denniss
1,522 Kommentare 549 Likes
Vielleicht umgehen die Boardhersteller die Vorgaben von Intel schon ein wenig um dem Problem leicht entgegenzuwirken: unnötig hohen Druck etwas verringern durch weniger fest angezogenen Sockelschrauben
k
krelog
173 Kommentare 53 Likes
wurden hier mal die Toleranzten der Sockel vergliechen das hätte mich mal interessiert weil allein der Sockel eine Toleranzkette von 4 Bauteilen hatt die ja alle noch mal Toleranzen haben
skullbringer
306 Kommentare 328 Likes
Das sind übrigens Unterlegscheiben, die nach meinen Messungen relativ exakt und konstant mit den Maßen sind: 1,02 +- 0,2 mm
(kein Affiliate)
Tatsächlich hatte ich schon eine Meldung, wo einer der 4 Torx Schrauben einfach 0,25 mm zu kurz war und dann mit dem Mod das Gewinde der Backplate nicht mehr zu fassen bekam. Nach etwas hin und her tauschen ging es dann, aber schon seltsam, wenn das Maß auf 8,75 mm festgelegt wird und dann noch 0,25 mm Toleranz sein dürfen....
a
apollo567
15 Kommentare 1 Likes
"Denn wenn wir Deutschen schon Intels Montage-Konzept verbessern müssen, dann doch wenigstens auf ein paar Hundertstel exakt."
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Case39
2,506 Kommentare 931 Likes
Wenn man bei einer neuen CPU Platform schon selber, handwerklich tätig werden muss, sinkt die Attraktivität schon erheblich ab.
a
apollo567
die Ausgereiftheit der Plattform war für mich auch der Grund aktuell auf ein Ryzen 5800X aufzurüsten, statt einem 12600er. Man kann auch mehr Hardware weiternutzen und muss nicht auf Windows 11 wechseln. Das Intel Plattform braucht noch etwas 'Reifezeit' aus meiner Sicht.
s
spaboleo
9 Kommentare 1 Likes
Der Mod (0,8mm PA Unterlegscheiben) hat bei meinem Asus Prime Z690M-Plus D4 (FoxConn ILM) mit i5-12500 und 240er AIO ca. 4°C Einsparung gebracht.
Die EKWB LGA-1700 Backplate trägt aber auch ihren Teil dazu bei, um "Schlimmeres" zu verhindern. Diese ist mit 3mm Stahlblechdicke auch ausreichend massiv gefertigt.
Bisher kann ich keine Probleme oder Instabilitäten feststellen.
Haru
116 Kommentare 65 Likes
Ich hab mir dann auch mal Unterlegscheiben bestellt, 1mm Dicke. Kommen wohl die Tage mit der Post.
Mal schauen, was das so bringt. Habe eine Liquid Freezer 2. Ich bin gespannt.
Nen faden Beigeschmack gibt das hier allerdings trotzdem.
SJGucky
50 Kommentare 20 Likes
Im Gegensatz zu AMD hat Intel schon immer eine OnboardGrafik, außer man kauft eine F-CPU.
Und du machst einen Fehler. Der 13900k (Herbst 2022) wird mit Sicherheit 8 P-Cores und 16 E-Cores haben. Warum sollte Intel also 2 Jahre später die E-Cores verringern? XD
Den 256 Core wird es bestimmt geben, und zwar von AMD, den Threadcruncher...
Zum Artikel...Ich hoffe keiner nutzt Flüssigmetall. Bei dem Buckel würds einfach von der CPU runterlaufen...
Extrem Modder würden warscheinlich keine Washer (Abstandsscheiben/Passscheiben/Unterlegscheiben) nehmen sondern einfach den IHS abschleifen.
Ich wüsste also gerne noch, ob das Lappen (Abschleifen) des IHS mehr bringt als die Washer oder sogar ob es zusätzlich zu den Washern noch was bringt...
Martin Gut
7,786 Kommentare 3,577 Likes
Wenn sich der Sockel erst innerhalb der ersten Wochen verbiegt, müsste man mit schleifen warten bis die Verformung da ist. Am Anfang schleifen bringt sicher nichts, weil der Prozessor dann noch gerade ist.
Bei der Biegung würde ich aber schon bald mit der Bandschleifmaschine anfangen und erst dann zu Micro Mesh Schleifleinen übergehen. o_O
Haru
Ich würde mal sagen, dass die Backplate der Liquid Freezer 2 was getaugt hat. Hab die CPU seit kurz nach Release verbaut und zuerst nen NH-D15s drauf gehabt. Danach das Mounting der LF2 fest geknallt.
Taugt also. Jetzt kommen mal die washer drauf und ich Schauma :)
Kleiner Edit:
Das brachte zwischen 10°C bei 100W im cb R20 und 20°C bei 400W. Hab die Scheiben aber ausgemessen, 1,02±0,05mm. Das beim 12900k ist krass. Vor allem deshalb, weil die CPU sonst bei Vollgas am throttlen war. Das sind mal eben 1000-1500 Punkte im CB R20.
N
Noel1987
25 Kommentare 5 Likes
Hey
Ich habe das gleiche Board wie du
Ich nutze aber eine custom Wasserkühlung
Meine Temperatur in cinebench liegt bei 71 Grad bei 196 Watt
In spielen bei max 55 Grad
Ich nutze eine 12700k
Denke das ich dort keinen Mod brauche
Board und CPU seit Release im Einsatz
Haru
kommthalt immer drauf an, welchen Kühler bzw. Kühlblock du genau hast, da die Backplate hierfür ziemlich wichtig ist. Wenn du der Einschätzung bist, dass es nicht notwendig ist, dann lass es. Ich habs gemacht und bereue es nicht, zumal die CPU dadurch entlastet wird.
N
Noel1987
Ich nutze einen bykski kühler für 1200 Sockel
Dieser deckt die komplette Rückseite ab
Ich habe leider keinen Vergleich zu anderen 12700k Systemen
Mein Gefühl sagt mir nur das 71 Grad bei ca 200 Watt nicht ganz so schlecht ist
An sich ist die Idee gar nicht schlecht und ich werde es sicherlich bei der nächsten Wartung der Wasserkühlung ausprobieren
Aber der PC wird überwiegend zum Spielen genutzt und ein Temperatur Problem liegt nicht vor so daß ich nicht die Notwendigkeit sehe das sofort zu machen
In den meisten spielen liege ich bei 50-55 Grad
BigLA
119 Kommentare 10 Likes
Mal eine naive Frage, da ich das Thema gar nicht so genau verfolgt habe...wirkt sich das auch bei Wald&Wiesen-Kühlern aus?
beispiel 1: boxed :LOL:
beispiel 2: bequiet pure rock 2
Wäre mal interessant ;)
H
Headie91
1 Kommentare 0 Likes
Warum macht man mit F-Cpu einen Fehler?
BigLA
Wollte nur mal ergänzen, dass der Box-Kühler die ganze Geschichte unterm Board ganz schön verbiegt, aber das wird sicher bekannt sein...!? ;)
Aleister
19 Kommentare 3 Likes
Also mal kurz zu dem Thema Washer Mod und seinen Tücken ;)
Habe die Unterlegscheiben auf ein ASUS Prime B660-Plus D4(DDR4) montiert und folgendes bemerkt.
1. Habe ich mich an die Vorgaben 1mm, etc. gehalten, doch die Unterlegscheibe war von ihrem Gesamtdurchmesser für die unteren Bohrung zu breit.
Also habe ich unten vom Rand der Kunststoff Unterlegscheibe etwas mit einem Seitenschneider abgetrennt. Dann passt das optimal mit der Verschraubung zum Sockel!
2. War ich arg amüsiert, dass ein 150€ Asus Board, bei der Thematik, mit einem Lotes Sockel daher kommt ;)
3. Für den Intel 12600 ohne k habe ich einen Scythe Fuma2 mit dem 1700 Mounting Bracket verwendet. Dies kann ich echt empfehlen, da dort der Sockel von hinten toll unterstützt wird. Der Anpressdruck durch denn verschraubten Kühler ist übrigens ordentlich!
Ergebnis: Maximal 78°C und maximal 111 Watt(CPU) nach 10 Minuten Cinebench 23.
Cinebench 15 Single Core: 268
Cinebench 15 Multi Core : 1958
Cinebench 23 Single Core: 1854
Cinebench 23 Multi Core :13591
Die Wahl für dieses recht einfache Board habe ich vor allem wegen der Kompatibilität zum meinen 4x8 GB 3200MHz @3500MHz Crucial Ballistix Sport Riegel getroffen (2xBlack-/2xTuf Edition). Der Ring Bus(was ja im Endeffekt der Northbridge Takt der Intel CPU sein müsste)läuft übrigens mit 4100MHz und der Speichercontroller mit 1750MHz.
Fazit:
Als Upgrade für meinen Ryzen 7 2700X, würd ich das bei dem Ergebnis und solch einem leisen Scythe Kühler, immer wieder machen, schon weil mir, für die der Zeit gebotene Leistung, ein AMD System zu teuer erscheint!!! Und das schreibt euch jemand, der sich seit über 15 Jahren nur AMD Systeme zusammengeschraubt hat.
---Grüße---
Xaver Amberger (skullbringer)
