As another entry in our new category of small PC systems, today we’re looking at a model from Chinese manufacturer Beelink, which specializes in just this form factor. Even the product name is compact! How the SER3 performs in terms of performance and workmanship is revealed in the following article:
In any case, the box is already space-saving, only slightly larger than the computer itself. Unlike many other manufacturers, there is no product picture or much text, apart from the name of the series on the front and the specifications on the back, there is not much to see.
If you pull the packaging apart, you are immediately greeted by the SER3. A little more padding for shipping would certainly not have been bad, but obviously everything arrived in one piece.
The accessories then consist of the corresponding power supply, a wall mount including screws, and two HDMI 1.4 cables in 100cm and 20cm lengths.
The labeling of the power supply was unfortunately difficult to photograph, so here are the specifications again: 19V @ 3.0A at a maximum of 51.0 watts, model TDX-1903000E
Specifications
Here is an overview of the technical details. As always, more information is available on the manufacturer’s product page.
24 Antworten
