Those who are waiting for news about Intel’s upcoming Rocket Lake processors can take a deep breath just before the launch, only to come up for air again right away. After all, Intel’s Rocket Lake architecture represents the first significant architecture upgrade in over 6 years and [...]
Processors
You’ve seen a lot of things, even on YouTube. For example, a 500 watt power supply miraculously survives even a GeForce RTX 3080, while exactly this card even forced a 1300 watt Platinum behemoth to give up in the lab before the Ampere launch. Well, NVIDIA has meanwhile defused the boost and [...]
AMD’s Zen3 architecture Ryzen 5000 desktop CPUs and matching X570 motherboards are popular, sell like hotcakes, and are also considered one of AMD’s best CPU lineups because they offer a lot of performance.But where there is a lot of light, there also seems to be the first shadows, if [...]
Now that Zen 3 has been out for some time, one naturally wonders about AMD’s next-generation CPU architecture for the Ryzen and EPYC CPUs, i.e. Zen 4 carries. Latest rumors now say that there will be another huge IPC jump and massive performance increase over the current processors. The s [...]
Intel has announced that the 11. It is expected that the 3rd generation Rocket Lake desktop CPUs will not be compatible with the existing B460 and H410 based motherboards. According to Intel, the new CPUs will only be officially supported on Z490 & H470 motherboards, while the more budget [...]
Since there were some irritations at the beginning, also in connection with older installations, a special CTR-Cleaner is now available for download, which deletes the old entries from the registry under ” %LOCALAPPDATA%/A, %LOCALAPPDATA%/Nemesis_UIv2″ reliably. Please note: The program [...]
Today is finally the day, the Clock Tuner for Ryzen is released in the long-awaited second version with support for the latest Ryzen 5000 CPUs and many other outstanding new features. CTR was already a very popular tool in the community for optimizing CPU voltage and clocks for Ryzen CPUs in the [...]
If you are in urgent need of a new computer, you have to put up with the extreme prices on the one hand and the limited availability of the components on the other. It’s annoying, but it’s not likely to change anytime soon. Because you can’t always choose the time of an upgrade [...]
Intel previewed its upcoming Rocket Lake architecture for the first time at CES 2021. The upcoming Rocket Lake CPUs mark the first really big architectural overhaul in well over 5 years and is also an architecture that, due to circumstances, has been backported from 10nm at great expense so that [...]
The fact that graphics cards cause considerable load peaks I could already prove impressively 6 years ago for the first time – including all the resulting problems and measures for the power suppliers. In the meantime, a lot has been done, of course also in the interest of the end customers [...]
Our friend Yuri (1usmus) made an interesting discovery in the course of working on the new Clock Tuner for Ryzen (CTR) 2.0 for the Zen3 CPUs and the implementation of AMD’s API, because although both the Ryzen 5 5600X and Ryzen 7 5800X are actually made with only one chiplet (CCD), some time [...]
The first block diagram of AMD's Ryzen 5000 "Cezanne" APUs based on the Zen 3 architecture has been leaked by now Videocardz. The block diagram shows that AMD's Ryzen 5000 'Cezanne' APUs will feature some major design changes compared to the current generation and are not [...]
The time has finally come, the new version of Clock Tuners for Ryzen CTR is in the starting blocks! The release will also take place on our side as the official German-speaking host already in a few weeks – after some further and necessary tests with end users – but also the current [...]
AMD in detail we have gone through and we had already talked about the heatspreaders of the current generations, a burn-in and the thing with the camber. Now finally follows the picture gallery for the individual Intel CPUs. Basic article, “CPU heatspreaders examined in detail – do we [...]
We already talked about the heatspreaders of the current generations, a burn-in and the thing with the cloud. For that, I’m also happy to link again to the basic article “CPU heatspreaders examined in detail – do we need to re-design the coolers for AMD and Intel now?” But [...]
I had already announced a long time ago that I would continue to work on the topic of heatspreaders. However, I myself do not have the measuring equipment in the micrometer range that would allow a clear statement, so I gratefully resorted to the help offered by a German research center. It was [...]
2020 was actually a first-class year for technological innovation, but it will probably also go down in history as the year of the ultimate frustration of discouraged consumers, when the target group will end up not being able to buy what has been on their wish list for a long time: graphics cards [...]
Since the other two AMD CPUs have arrived and I was able to get a replacement CPU for the Ryzen 9 5900X (and buy it), I have revised the whole launch article and added the missing entries. This would give us the quartet of Ryzen 5 5600X, , Ryzen 7 5800X, Ryzen 9 5900X and Ryzen 9 5950X now complete [...]
Since I received a Ryzen 9 5950X yesterday, which also has two Dies, I also chased it through all the benchmarks, virtually overnight. The problem with the two CCDs did not occur in Shadow of the Tomb Raider, so that one must rather assume a CPU-specific problem of the sample. What has been [...]
Currently I was able to test two of the new Ryzen CPUs with Zen3 core, which could not be more different. On the one hand, there is the Ryzen 9 5900X with 12 cores (24 threads) as the new, two-largest miracle product of the upper class, and on the other hand, there is the Ryzen 5 5600X with 6 cores [...]
I don’t really need to comment on the following document, because it really speaks for itself. In fact, everyone involved is happy to see a huge demand, but when things turn out the way NVIDIA does, the anticipation and hype quickly turns into disappointment and even anger. But that’s [...]
I am as coreZair in various forums and as 3DAndStuff on my YouTube channel. But today I am writing this article for you as a guest author. In addition to my YouTube videos, I would like to share the results of some of my research with you. The XMG Apex 15, a notebook that is equipped with an AM4 [...]
TumApisak has discovered something again, specifically a new entry in the database of Sisoft Sandra, and this is also promptly distributed as usual on Twitter. It seems that a multi-GPU setup consisting of two Intel Xe LPs with 1.25 GHz clock speed each was used and entered there before a run. But [...]
Now AMD has let the cat out of the bag and much of what I could already report in the past weeks (including the final clock rates) has arrived. A clear increase of the IPC, together with a considerably higher clock rate, we can probably also replace Intel as a gaming chapter. The prices turn out as [...]
I would like to inform you that we are pleased to exclusively host and support the project ClockTuner for Ryzen (CTR) by 1usmus (Yuri Bubliy) for the German region. Since the english language support is provided by Guru3D, we want to be fair and link the manual / tutorial there as well, since the [...]
