CPU Latest news
Zen 5 flexes its muscles: AMD Ryzen 5 9600X with 14% more performance and 5.5 GHz clock frequency
The AMD Ryzen 5 9600X is a six-core processor of the Zen 5 generation that has been leaked and boasts an impressive clock speed of up to 5.5 GHz and a performance increase of 14% compared to its predecessor, the Ryzen 5 7600X.
Leonardo.ai
  • Model number: 100-000001405
  • Cores/threads: 6/12
  • Base clock: 3.9 GHz
  • Boost clock: 5.4 GHz (up to 5.5 GHz with PBO)
  • Cache: 38 MB
  • TDP: 65 W
3. Performance increase compared to the predecessor
The Ryzen 5 9600X offers a number of improvements over the Ryzen 5 7600X:
  • Higher boost clock: 100 MHz higher
  • Improved single-core performance: 15%
  • Improved multi-core performance: 14
  • Higher clock rates possible through PBO tuning
The Ryzen 5 9600X shows impressive results in initial benchmarks:
  • Geekbench 6:
    • Single-core: 3284 points (15% increase compared to Ryzen 5 7600X)
    • Multi-Core: 14,594 points (14% increase compared to Ryzen 5 7600X)
  • Outperforms the Intel Core i9-14900KS in the single-core Geekbench
  • Equivalent to the Ryzen 7 7700 (8 cores) in the multi-core Geekbench
  • Faster than the Core i5-14600, but slower than the Core i5-14600K in the multi-core Geekbench (with higher TDP)
The Ryzen 5 9600X outperforms the Intel Core i9-14900KS in the single-core Geekbench, which indicates strong single-core performance that can have a positive impact on gaming performance.
The AMD Ryzen 5 9600X proves to be an impressive six-core processor with significant performance gains over its predecessor and strong single-core performance, even outperforming the Intel Core i9-14900KS in this area. The combination of performance and energy efficiency (65W TDP) makes it an attractive option for price-conscious users looking for high performance.
Note: Benchmarks are still preliminary and further testing in various applications and configurations is needed to get a full picture of performance.
Table 1: Geekbench 6 benchmark results
Processor Single-Core Multi-Core
AMD Ryzen 5 9600X 3284 14.594
AMD Ryzen 5 7600X 2841 12.797
Intel Core i9-14900KS 3223
AMD Ryzen 7 7700 3192 14.572
Intel Core i5-14600 2987 13.034
Intel Core i5-14600K 14.349
Source: Benchleaks
a
anton_
164 Kommentare 71 Likes
na vielleicht wechsel ich vom 7600x auf den 9600x :D :D Und nein, nicht wegen der 14% , sondern weil ich für den 7600x eine andere Verwendung hätte, und der einen alten PC ersetzen würde
L
Locomotion
41 Kommentare 5 Likes
Multicore Leistung im Vergleich zum 14600K, etwas stimmt da nicht! Die Zahlen in der Tabelle belegen nicht die Aussage im Text, sondern stellen das Gegenteil dar.
8j0ern
3,139 Kommentare 1,005 Likes
Passt doch ?
Evt. mal die Internet Seite aktualisieren ( F5 Taste )
8j0ern
7-zip ?
B
Basti198320
17 Kommentare 2 Likes
Nette Vorstellung, wenn der Leistungssprung bei allen Modellen so gegenüber dem Vorgänger ist könnte sich ein umrüsten lohnen. Wichtig wäre auch wie sich die CPUs in gleichen Situationen verhalten und welche Unterschiede sich im Verbrauch und Temperaturen ergeben zwischen den 7000er und 9000er Modellen. Dies sollte sogar mehr im Fokus rücken.
ArthurUnaBrau
345 Kommentare 169 Likes
Ich hoffe, die neuen CPUs haben ein besseres IHS Design. Die Temperaturen der 7000er-Serie stimmen mich nicht glücklich. Noch macht mein 5800X3D alles, was ich ihm zuwerfe, bei höchstens 75° C (280er AIO).
ecth_
31 Kommentare 8 Likes
Naja, mein 7800X3D wird auch kaum über 65°C beim Zocken. Leicht übertaktet via BCLK 102MHz. Mit Arctic LF3 bleibt das Ding kühl.
Ich denke X3D CPUs sind einfach kein guter Benchmark für heiße CPUs :D
ArthurUnaBrau
Naja, Roman hat ja gezeigt, dass die 7000er IHS es der Hitze schwerer als nötig machen, zu entweichen. Mit Direct-Die-Cooling (für einen normalen User wie mich utopisch) waren mehr als 20° K Unterschied drin, und das finde ich schon krass.
Dass deiner allerdings bei 65° C bleibt, stimmt mich etwas ruhiger. Die 7000er Reihe werde ich überspringen, mal schauen, was die 9000er so mit sich machen lassen.
ecth_
Gut, 65°C beim Zocken. 100Hz Framelimit.
Mit Cinebench habe ich schon die Thermal Limits gehabt 😅 Aber ist halt keine realistische Last für mich. Wenn alle Kerne, dann eher über einen kurzen Zeitraum. Nicht dauerhaft. Dafür hätte ich ohnehin eher einen 7950X oder X3D gebraucht.
matmartin
66 Kommentare 20 Likes
Werde zwar nicht von meinem sehr günstig erworbenen Ryzen 7500F aufrüsten, aber schön zu sehen, dass in der AM5 Plattform noch so viel Potenzial schlummert. Da wird sich das aufrüsten in ein paar Jahren lohnen.
ArthurUnaBrau
Eh, ok, also kein realistisches Ergebnis. Ich zocke immer ohne Framelimit.
ecth_
Hängt von den Anforderungen ab. Der Bildschirm kann nur 100. Wieso mehr rendern?
ArthurUnaBrau
Gegen input lag. Meiner macht auch „nur“ 165 Hz, aber mit 300 fps habe ich trotzdem weniger Input Lag.
Kommt sehr drauf an, was man spielt, ich spiele oft multiplayer shooter.
Samir Bashir
