GPUs Graphics Reviews
Sapphire Radeon RX 6950 XT Nitro+ Pure Review – Snow White as an unique beauty with a reserved character
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
After the already extensively tested new AMD cards in the recently published launch article, the Sapphire Radeon RX 6950 XT Nitro+ Pure has now also found its way to my lab as another board partner card. The continued unavailability of these particular graphics cards for the masses is a shame and all the more annoying because these products are really good and competitive graphics cards that would have deserved to make the masses of willing buyers happy as well. And so today I’m testing a product that stands out pleasantly from the crowd and is unfortunately still stuck in the delivery to Germany.
With the (Attention! Officially prescribed name according to AMD’s nomenclature) “NITRO+ AMD Radeon™ RX 6950 XT PURE Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 2”, which I will call Sapphire RX 6950 XT Nitro+ Pure again in the article for the sake of simplicity, as otherwise the charts and legends would explode, here is a thoroughly interesting RDNA2 specimen that you have to listen twice (or three times) to hear. And Sapphire has not set the factory clock too high and thus even leaves a lot of room for own OC experiments. I will show that this is possible in a water cooling article.
This graphics card, like all RX 6000 models, can handle the new AV1 video codec, they also support DirectX 12 Ultimate for the first time and thus DirectX Raytracing (DXR). With AMD FidelityFX, they also offer a feature that should also give developers more leeway when selecting effects. Variable Rate Shading (VRS) is also included, which can save an immense amount of computing power by smartly reducing the display quality of image areas that are not in the player’s eye anyway. So much for the feature set of all new Radeon cards.
With an MSRP of 1399 Euros, you have generated a certain premium that you can accept or not. Everyone has to work that out for themselves. But Snow White and unicorn feeling are already included. After all, that’s something.
Optics and haptics
The Sapphire RX 6950 XT Nitro+ Pure weighs 1571 grams, which is of course heavier than the RX 6900XT reference card, but slightly lighter than the MSI card from the launch article. It is also longer with its full 32.5 cm, a stately 13 cm high (installation height from PEG) and in addition a brute 6.4 cm thick (3.5 slot design), whereby a backplate and the PCB are added with a total of four more millimeters.
The white body is made of light metal, the Sapphire lettering and the light band on the top are LED illuminated, the backplate is still adorned with an illuminated logo. Apart from that, everything is nicely made of light metal instead of plastic, which makes a lot of difference haptically.
The graphic brick including illumination is supplied via two standard 8-pin sockets and a 6-pin socket, so everything is as known and used. We also see the vertical orientation of the cooling fins and the board reinforcement in the form of a backplate and a massive frame here. But more about that in a moment in the teardown.
The slot bezel is closed, carries 1x HDMI 2.1 and three current DP ports. However, the USB Type C port is missing. More about the construction, the cooler and the assembly can be found on the next page in the teardown.
Technology
With the 80 compute units (CU), the card has a total of 5120 shaders. While the base clock is specified at 2162 MHz, the boost clock is 2368 MHz in the Silent BIOS and 2435 MHz in the Performance BIOS, which is also achieved. The card uses 16 GB GDDR6 with 18 Gbps, which is made up of 8 modules of 2 GB each. This also includes the 256-bit memory interface and the 128 MB Infinity Cache, which is supposed to solve the bandwidth problem. The card thus has a switchable dual BIOS, which is nice. With the BIOS DIP switch in the middle position, a switchover can be solved seamlessly and directly via software on-the-fly with Sapphire’s TriXX software.
Other data is different in the BIOS, for example the TGP, i.e. the maximum power for GPU, SoC and memory. The performance version offers up to 325 watts TGP instead of 303.
Raytracing / DXR
At the latest since the presentation of the new Radeon cards, it is clear that AMD will also support ray tracing. Here, NVIDIA takes a different path and implements a so-called “ray accelerator” per compute unit (CU). Since the Radeon RX 6800 has a total of 72 CUs, this also results in 72 such accelerators for the Radeon RX 6800XT, while the smaller Radeon RX 6800 still has 60. A GeForce RTX 3080 has 68 RT cores, which is nominally less for now. When comparing the smaller cards, the score is 62 for the RX 6800 and 46 for the GeForce RTX 3070. However, RT cores are organized differently and we will have to wait and see what quantity can do against specialization here. In the end, it is an apples and oranges comparison.
But what has AMD come up with here? Each of these accelerators is first capable of simultaneously calculating up to 4 beam/box intersections or a single beam/triangle intersection per cycle. In this way, the intersection points of the rays with the scene geometry are calculated (analogous to the bounding volume hierarchy), first pre-sorted and then this information is returned to the shaders for further processing within the scene or the final shading result is output. However, NVIDIA’s RT cores seem to be much more complex, as I already explained in detail during the Turing launch. What counts is the result alone, and that’s exactly what we have suitable benchmarks for.
Smart Access Memory (SAM)
AMD already showed SAM, i.e. Smart Access Memory, at the presentation of the new Radeon cards – a feature that I also enabled today in addition to the normal benchmarks, which also makes a direct comparison possible. But actually SAM is not Neuers, just verbally more nicely packaged. This is nothing more than the clever handling of the Base Address Register (BAR), and it is exactly this support that must be activated in the substructure. Resizable PCI bars (see also PCI SIG from 4/24/2008) have played an important role in modern AMD graphics hardware for quite some time, since the actual PCI BARs are normally only limited to 256 MB, while the new Radeon graphics cards now offer up to 16 GB VRAM.
The consequence is that only a fraction of the VRAM is directly accessible for the CPU, which requires a whole series of workarounds in the so-called driver stack without SAM. Of course, this always costs performance and should therefore be avoided. AMD thus starts exactly there with SAM. This is not new, but it has to be implemented cleanly in the UEFI and also activated later. This is only possible when the system is running in UEFI mode and CSM/Legacy is disabled.
CSM stands for the Compatibility Support Module. The Compatibility Support Module exists exclusively under UEFI and it ensures that older hardware and software also works with UEFI. The CSM is always helpful when not all hardware components are compatible with UEFI. Some older operating systems as well as the 32-bit versions of Windows also cannot be installed on UEFI hardware. However, exactly this compatibility setting often prevents the clean Windows variant needed for the new AMD components during installation.
First you have to check in the BIOS of the motherboard if UEFI or CSM/Legacy is active and if not, make sure to do this step. Only then you can activate and use the resizable PCI-BARs at all, but stop – does your Windows boot at all then? How to convert an (older) disk from MBR to GPT, so that it is recognized cleanly under UEFI, you could read among other things also in the forum, if there are questions in this regard, that leads here now too far.
The fact is that AMD sets the hurdles for the use of SAM quite high and has only communicated this sparsely so far. A current Zen3 CPU is required, as well as a B550 or X570 motherboard with an updated BIOS. The UEFI is then again a small, but immensely important side note. It should also be noted that NVIDIA and Intel have already announced their own solutions or plan to use them in the future. One goes first, the others follow suit, whereas it could have been done long ago. But they didn’t, for whatever reason. Over 12 years of drawer is plenty of wasted time. But better late than never.
Test system and evaluation software
The benchmark system is new and is no longer in the lab, but in the editorial room again. For direct logging during all games and applications, I use NVIDIA’s PCAD and my own development with Powenetics’ software, which increases the comfort immensely. The measurement of power consumption and other things continues to be carried out in the air-conditioned laboratory on a redundant test system that is identical in every detail, but then using high-resolution oscillograph technology..
…and the self-created MCU-based measurement setup for motherboards graphics cards (pictures below), where at the end in the air-conditioned room also the thermographic infrared images are created with a high-resolution industrial camera. The audio measurements are done outside in my Chamber (room within a room).
I have also summarized the individual components of the test system in a table:
RX480
2,042 Kommentare 993 Likes
Praktisch würde ich als Erstes den Fanstopp deaktivieren, ... damit entfällt dann auch das "kurze" Anspringen auf 1600rpm.
(per MPT lässt sich vermutlich minPWM auf 12% setzen, was ja auch auf dem Desktop erträglich wäre und minimales Coilwine übertönt)
positiv
Finde ich, das die Effizienz@Frametimes im Performance-Mode net ggü. dem SilentMode leidet.
(normalerweise würde Es ja ein mue schlechter werden, um so weiter man vom Sweetspot weg kommt)
und
Das die Frametimes@4k anscheinend ordentlich vom besseren Vram(x) und fclk2050 profitieren.
(x) vermutlich gänge sogar noch bis zu ca.2400+MHz@FT2; ... ggf. mal 25mV mehr MVDD erf.
btw.
Die "gleichschnelle" 3090 SuprimX kostet derzeit bei MF schlappe 1969€.
Von Daher ist für reine Rastergamer die Pure keine schlechte Wahl.
(interessanterweise ist der avg.Verbrauch beider Grakas@4k fast identisch und erlaubt nen exakten Vgl., ... gute Wahl von Igor)
ansonsten
Kann man nur hoffen, das die Pure für den Preisaufschlag besser gebinnt ist als die Nitro.
(da gibts leider noch kaum Erfahrungswerte und gar keine Garantien)
Wie ist denn der ASIC-Wert bei der Pure ?
grimm
3,503 Kommentare 2,532 Likes
Ich schließe mich an: im Vergleich zu vergleichbaren Grafikbrettern ist der Preis vertretbar. Meine 6900XT Toxic hat quasi gleichviel gekostet, die mag ich nicht wieder hergeben.
ssj3rd
271 Kommentare 193 Likes
Keine Raytracing Tests beim Gaming? Weil?
Auch im ursprünglichen Artikel der verlinkt wurde finde ich nichts zu Raytracing.
grimm
"NVIDIAs RT-Cores scheinen da allerdings deutlich komplexer vorzugehen, wie ich es beim Turing-Launch bereits ausführlich erläutert habe. Was zählt, ist allein das Ergebnis und genau dafür haben wir auch passende Benchmarks." - hab auch keine gefunden.
Göran
160 Kommentare 63 Likes
Optisch schön und auch sonst gut designed. Aber, versteht nicht mich falsch, im Silent-Modus hat sie nur wenig mehr Leistung als eine 6900XT braucht aber schon bedeutend mehr Energie und im Performance-Modus ist die Leistung signifikant größer aber auch die Energieaufnahme schon in ganz anderen Welten.
Klar könnte man jetzt hergehen und dem Potential für UV argumentieren, aber das hat ja bei der 6900XT im Vergleich auch nicht stattgefunden.
Warum sollte man diese Karte einer 6900XT verziehen ... außer man möchte die maximale Mehrleistung haben und Effizienz ist kein Kriterium ?
Casi030
11,923 Kommentare 2,340 Likes
Weil die Chips noch mal ein klein wenig Effizienter sein sollten bei der 50er.
Klar so sieht man nicht viel davon,aber Optimiert sollten 2,8GHz bei unter 300Watt locker laufen und dann bringt sie doch schon eine ordentliche mehr Leistung on Top.
11,980 Kommentare 23,594 Likes
Metro ist z.B.mit RT High.
A
Arcbound
149 Kommentare 108 Likes
@Igor Wallossek Wäre es möglich, in Zukunft auch die Leistungsaufnahme bei (4k)-Videowiedergabe zu ermitteln? Bzw. würde da evtl auch pro Generation ein Vergleich Nvidia vs. AMD reichen. :unsure:
grimm
Da reiht sei sich dann bei den "1% Low FPS" konsequent (und sehr knapp) hinter der 3080Ti ein. Das ist ja schonmal ne Ansage dafür, dass AMD angeblich kein RT kann ;)
RT ist halt nicht RT. Man kann es sinnvoll nutzen, oder andere totspielen ;)
P
Phelan
225 Kommentare 203 Likes
Optisch und bei der Kühlung bekommt die Karte von mir 100% :)
Fast zu schade um sie in einen Gehäuse einzubauen.
400W ist mir trotzdem zu viel. Speziell weil sie eigentlich 325W TPD haben sollte.
Naja, positiv an den 6950XT allgemein ist das man jetzt einen 6900XT für unter 1000€ kaufen kann ;-)
Casi030
Die Kenner bekommen mit 300Watt mehr Leistung raus.;)
Casi030
Oder so. ;)
War das jetzt so richtig mit 16AF?!Schon wieder vergessen.....
Casi030
Die RX6950XT wurmte mich jetzt,durch das Silent Bios bin ich nur auf 293Watt gekommen bei meiner RX6900XT.Hab dann mal das normale geladen,aber da muss ich schon ein Kompromiss ein gehen zwischen Spanungskurve und Takt.......:mad:
World War Z und Shadow of the Tomb Raider haben einen geringen Takt,Far Cry 6 braucht nen hohen Takt,der macht mir dann die Spannungskurve kaputt.
Das ist durchaus komplex. Deshalb verkacken ja viele für den 3DMark hinoptimierten Karten im realen Einsatz und ich sträube mich da, allgemein gültige Tutorials zu verfassen, weil man vieles mit berücksichtigen muss
jahtari
269 Kommentare 130 Likes
... this. kein kommentar.
oder doch? hmm...
okay jungs, ich habe ein paar dinge zu verkaufen. nen 5800X, eine RX 6800Xt, ein Apple TV4k, n paar Aventho wireless, ..., eine Bruno Söhnle Lagomat Day-Date. Wobei, die behalte ich dann doch. Aber der Rest - wer will, wer will, wer hat noch nicht? :LOL::ROFLMAO::LOL:
O
Onkel Rick
16 Kommentare 2 Likes
Wie sieht es eigentlich mit dem kühler und den Lüftern aus?
Ist das identisch zur 6900xt?
Liebe Grüße, Rick
Follow Igor:
