The H7 Elite is NZXT’s new ATX premium case and promises luxurious features in a classy guise. We will find out whether this is the case in today’s test. As is well known, everyone can tell a lot when the day is long. The H7 Elite is one of three versions launched on 5/25/2022. The other two are called H7 and H7 Flow, and the prices start at 139.99 Euros. We have to dig a bit deeper into our pockets for the H7 Elite, which costs a hefty 209.99 Euros. It doesn’t matter whether we take the white or black version.
At the end of the review I will of course take you on a journey through a themed build via video, so it remains exciting as always.
Scope of delivery
NZXT ships the H7 Elite in a cardboard box printed on all sides with the case pictured. With this, you want to show that it is something special before unpacking, because the other two cases are shipped in a plain brown cardboard box. Inside, the case is well protected with 2 styrofoam blocks and a foil as (unfortunately still) usual.
The case also contains an accessory box with various screws, cable ties and brackets for SSD/HDD mounting.
That’s all there is to it, but that’s enough. Four fans are already installed in the case, three of which are the new F140 RGB fans that we recently tested as a 120 version. The fourth fan, located in the rear, is a simple white flow fan.
At this point there is already (in my opinion) the first quiet criticism, because NZXT advertises with the term Elite – so why not install one of the new fans here as well? What I find worse though is that this fan is not a 4-pin PWM fan, but a simple 3-pin and only DC controlled fan. I would have at least wished for a PWM-controlled fan. On the back is the well-known NZXT fan and the RGB hub, which is also only available pre-assembled in the Elite version. H7 and H7 Flow do not have this stroke.
Technical data
For the very curious, we of course have the data sheet again. And I also have a video of the build at the very end, but spoilers are not cool.
H7 Elite Salestool DE
46 Antworten
