Monitors Reviews
MSI Modern MD272QP Review – An usable office or second monitor without many frills?
So far, we’ve basically only looked at high-end gaming or a content creator monitor. We have not yet tested a pure office monitor. So today is the day. The MSI Modern MD272QP from 2021 faces our test program. It is indeed – a pure office monitor, as you can find it in almost every office. Expectations should not be too high now. However, those who already have a QHD gaming monitor in 16:9 format and are still looking for a second one for Discord chat or other tasks might well be interested.
The MD272QP is certainly not a monitor you want to spend all day gaming on. This is not what this monitor was made for. The installed IPS panel comes from HKC Digital. Yes, that’s exactly how I looked at it. I have never heard of the manufacturer until this test. The subpixel layout is RGB, so text display is no problem at all.
The MD272QP (MD = Modern Series; 27 for size in inches; 2 = 2. Generation; Q = 2560 x 1440p resolution and the P = tilt, swivel and adjustable height), so the code is cracked. It essentially offers 75 Hz refresh rate, AMD FreeSync, 300 nits brightness, 1000:1 contrast, 4 ms pixel response time, and 95% sRGB color space coverage. All further technical data about the monitor is available on the MSI homepage and in PDF form:
Modern_MD272QP_datasheet-v1
If you don’t want to go to the MSI homepage, you can also browse through the following promotional PDF from MSI. Have fun, see you on the next page.
Modern_MD272QP_Infokit_v2
konkretor
260 Kommentare 247 Likes
Mit 144 Hz sofort gekauft. So nicht
FritzHunter01
887 Kommentare 915 Likes
144 Hz beim Arbeiten?
skullbringer
289 Kommentare 291 Likes
Wenn man den Cursor Lauf auf einem Gaming Monitor mit 144 Hz gewohnt ist, merkt man niedrigere Bildwiederholraten sogar auf dem Desktop sofort, zumindest geht's mir so.
Kann man den Monitor evtl. mit einer custom Resolution zu mehr als 75 Hz überzeugen? Manche (günstigere) Display Controller erlauben das ja, wäre zumindest interessant.
FritzHunter01
Da ich hier mit bis zu 360 Hz "arbeite" merke ich mittlerweile jede kleine Veränderung bzgl. der Bildwiederholrate. Dennoch, es ist auch Kopfsache. Ich sage mir, das ist jetzt so, weil der Monitor das halt nicht kann. Ein paar Minuten der inneren Trauer und schon hat man sich an die 75 Hz gewöhnt. Bei Arbeiten kein Problem...
Zocken unterhalb von 100 Hz/FPS geht gar nicht... da sehe ich jeden Pixelmüll, und Bildfehler alá DLSS 3 Frame Generation... Nervig
Bzgl. Overclocking des Panels, keine Ahnung - das habe ich nicht getestet.
P
Phoenixxl
144 Kommentare 106 Likes
Ich bin mir nicht sicher, aber braucht man für KVM nicht zwingend ein Thunderbolt Kabel mit USB-C Anschluss?
Ich habe einige USB-C Kabel an meinem KVM getestet (z.B. das Ladekabel von OnePlus, mit dem natürlich auch Daten transferiert werden können).
Geklappt hat es aber erst mit einem Thunderbolt Kabel, was ganz schön dick und teuer war.
Oder ist Display Signal über USB-C mittlerweile so weit verbreitet?
Oder ist es Teil von USB X.Y?
Ich gehöre zum Kreis der Verwirrten und ihre mich hier gerne.
Ansonsten wäre es super, wenn man in den Berichte genau drauf achtet die Kabel richtig zu bezeichnen, nicht das ein Leser dann 5 Mal zum Saturn rennen muss :)
FritzHunter01
Stimmt, darauf sollte ich achten. Man benötigt ein:
USB 3.2 Gen2 Typ C Monitorkabel USB Kabel (oder vergleichbar)​
Kosten ab 20 Euro aufwärts....
Tim Kutzner
633 Kommentare 450 Likes
Ich habe daheim 165 Hz und auf Arbeit 60Hz, dafür aber 16:10
Also einen spürbaren Unterschied im Office Betrieb merke ich da überhaupt nicht
konkretor
Na klar beim Arbeiten, man merkt schon einen Unterschied. Ich will nicht mehr ohne sein
Sephiroth Nikon
48 Kommentare 7 Likes
Klar, wenn du zum Beispiel mit Pro/Engineer arbeitest.
D
Daedalus
109 Kommentare 82 Likes
ich hatte den Monitor vor ein paar Tagen im Angebot gekauft, leider zeigt er bei mir ein lautes Spulenfiepen, sobald man ein DP/HDMI-Kabel anschließt und ein Bild übertragen wird.
Das stört schon sehr, ich werde ihn daher umtauschen. Ansonsten aber wirklich ein schönes Gerät, aber das Gefiepe/Gesurre ist echt ein no-go, gerade für ruhige Büroarbeit.
Hat noch jemand diese Erfahrung mit diesem Modell gemacht oder hatte das Testgerät das auch @FritzHunter01 ?
FritzHunter01
Hallo,
das ist natürlich nicht schön. Umtauschen! Bei meinem Test war kein Pfeifen zu hören.
Tim Kutzner
Der Testmonitor ist mittlerweile bei mir ist Einsatz, das Fiepen habe ich auch.
Aber nur die 1-2 Sekunden, wenn ein Gerät via HDMI angeschlossen ist und noch kein Bild angezeigt wird.
Via Displayport habe ich das überhaupt nicht.
Vielleicht hat @FritzHunter01 besseren Strom als ich :D
D
Daedalus
Bei mir war das Fiepen leider dauerhaft. Das scheint bei dem Gerät auch öfter aufzutreten, wenn man zumindest einigen Kommentaren auf mydealz glauben möchte.
FritzHunter01
Bei mir hat nix gefiept. Komisch!
Fritz Hunter
