Monitors Reviews
Basics for our monitor and display tests – Portrait Displays Calman Ultimate
Today I will introduce you to the new SDR measurement standard for our monitor tests regarding color performance. Regarding HDR, there will be a separate article. Nevertheless, from now on it’s “We used the Calman color calibration software from Portrait Displays.” All previous monitor tests are still valid. The results were/are valid and basically comparable with other test results. Therefore, there will only be night tests in the background so that I can create a comparison overview. With Calman Ultimate, testing is basically simplified and of course significantly expanded.
Since Calman Ultimate is one of the most powerful calibration and analysis tools on the market, we limit ourselves to the necessary SDR aspects of the software. We only measure what is important to a monitor and you, the reader, in the end. Basically, I measure the same thing as before. Only now it can be differentiated much better and presented more clearly. Let’s get started then…
SDR-Toolkit @ Calman Ultimate
Anything with a cross here, we’ll look at every monitor test. Regarding the options: There, the focus is on sRGB. Because every monitor has to be able to do exactly that. Why? Because almost everything on the Internet – is mastered in sRGB or Rec. 709 color space. (Web pages, YouTube, standard apps like Excel and PowerPoint, etc.). This then looks like this:
If the monitor to be tested has a wide gamut (e.g. P3 > 90%), then I reserve the right to additionally adjust the settings for the color space and of course to perform all tests in the corresponding color space. As a rule, this will only be the case if the corresponding monitor via the OSD or a software, dedicated to such color spaces. Example:
The MSI Summit MS321UP can be set (fixed) to the sRGB, Display P3 or Adobe RGB color spaces via the OSD. The manufacturer suggests that the respective color space, gamma, white point, color saturation and color fidelity should be correct via such a profile. With Calman Ultimate I now have the possibility to check exactly that. With the old measurement method this was not possible.
If I extend my measurements to other color spaces, the settings will be adjusted accordingly. The SDR toolkit and tests remain the same as above. Example:
Why I choose this setting for the DCI-P3 color space, I explain in the basics article part 2: click here!
Everything about colors, gray scaling and other special features | Part 2 Monitor Basics
big-maec
1,028 Kommentare 610 Likes
Habe wieder was gelernt, dadurch werde ich auf Sachen achten, die ich vorher so nicht wusste. Beim nächsten Monitortest werde ich mal schauen, was davon hängen geblieben ist. Jetzt muss ich mir nur noch einen Merker setzten.
Kann man eigentlich einen Merker setzen, um interessante Artikel oder Tests leichter wiederzufinden?
12,214 Kommentare 24,227 Likes
Nope. Aber einen Bookmark ;)
ipat66
1,643 Kommentare 1,801 Likes
„Jeder Monitor wird vor dem Messen auf die Werkseinstellungen zurückgesetzt und für min. 30 Minuten aufgewärmt – im Sinne von angeschlossen und angeschaltet.“
Hast Du befürchtet, dass jemand seinen Monitor in den Ofen stellt :D ?
Danke für diese nette Einführung und die Vorstellung des Messtools.
Freue mich auf die nächsten Monitor-Reviews.
FritzHunter01
1,398 Kommentare 1,891 Likes
Nein, aber ich möchte Missverständnisse vermeiden... nachher denk wirklich noch jemand, dass ich die Monitor in den Ofen stelle oder mit einem Föhn warm mache...
N
Novasun
125 Kommentare 75 Likes
Neues Spielzeug für IgorsLab incoming!!! :)
Lagavulin
316 Kommentare 265 Likes
Vielen Dank für den hohen Aufwand der für die Messungen betrieben wird und die detaillierte Beschreibung des Vorgehens.
Eine kleine Anregung hätte ich: Die „Farbwahrheit“ steckt im Messgerät, bzw. in seinen Farbfiltern und der möglichst genauen Kalibrierung des Colorimeters beim Hersteller. Bei den Filtern gibt es zudem organische und anorganische, wobei letztere weniger unter alterungsbedingter, schleichender Farbabweichung leiden. Vielleicht wäre es sinnvoll, zu Beginn einmal die Messwerte des Colorimeters mit denen eines anderen Herstellers zu vergleichen um sicherzustellen, dass man keinen Ausreißer erwischt hat. Mein Colorimeter überprüfe ich entsprechend halbjährlich (ok, um das perfekt zu machen müsste man mit einem besonders präzise kalibrierten, professionellen Messgerät vergleichen, aber für mein Fotohobby reicht mir das um zu erkennen, ob mein Gerät plötzlich Abweichungen zeigt).
FritzHunter01
Danke für den Hinweis!
Darüber habe ich mir auch schon gedanken gemacht. Noch ist der SpyderX "neu". Also kein Problem. Außerdem wiederhole ich jede Messung 3x um etweige Ungereimtheiten zu erkennen. Das macht einen schleichenden Altersprozess zwar nicht sichtbar, aber besser als gar nix. Ich bin schon in Kontakt mit Data Color, um hier mehr Informationen zu dem Thema zu bekommen.
Des Weiteren tausche ich mich auch mit Tim (Hardware Unboxed) regelmäßig aus.... Das Thema werde ich mit ihm auch mal durchsprechen.
Das Problem ist:
Ich mache alle meine Artikel privat und freien Stücken (ich verdiene damit kein Geld) und vieles ist auch privat bezahlt worden (z.B. der SpyderX Elite), ich mache das als Hobby und für die Community. Beim Thema Monitor bin ich ein Zicke und lege Wert auf Qualität vor Kosten. (Das Verhältnis muss aber dennoch im Rahmen bleiben) Ein Monitor ist eine Langzeitinvestition. Da will man ungern zweimal kaufen.
Ergo: Ich kann nicht noch mehr Kolorimeter kaufen, da leidet irgendwann auch meine Familie darunter, ich investiere schon sehr viel Zeit für das alles hier.
Vielleicht fällt mir da noch was ein. Man braucht am Ende nur Rot, Grün, Blau als Referenz (Nullstück) welches immer Gleich ist, dann kann man regelmäßig messen und sieht, wenn die Abweichungen kommen.
Lagavulin
Nochmal vielen Dank für Dein hohes Engagement! Ich freue mich sehr auf die kommenden Monitortests und hoffe, dass Du zukünftig auch OLED-Monitore von den Herstellern zum Testen zur Verfügung gestellt bekommst. Im nächsten Jahr soll da ja auch endlich was von LG (27" und 32") kommen. Ich bin übrigens auch nicht so verschwenderisch, mir zwei Colorimeter zu kaufen - ich leihe mir halt ab und zu mal eins von einem Bekannten (bzw. wir tauschen für ne Woche) zum gegentesten.
FritzHunter01
Der Kollege Tim von HW UB hat ganz anderes Equipment als ich... Sein Messtool für Calman Ultimate kostet weiter über 5.000 $ da is mir fast das Herz stehen gebleiben :eek:
x
xavyer.keiren
25 Kommentare 6 Likes
Software für 3000$ nutzen und dann so was ...
"Mess-Tool
Das bleibt weiterhin der SpyderX von Data Color"
Das Colorimeter ist nachweislich das absolute Einstiegsgerät und liegt Klassen unter den X-Rite Geräten die irgendwo im unteren Mittel angesiedelt sind.
Absolut Sinnlos so was! Bei so einer Sinnlosen Zusammenstellung gehe ich mal davon aus dass die Software nichts gekostet hat.
Lagavulin
@xavyer.keiren
Zu Deinem Tonfall sage ich besser nichts – das wäre justiziabel.
Wer Xrite Colorimeter als untere Mittelklasse abqualifiziert, der lässt erkennen, dass er entweder keine Ahnung von der Materie hat oder einfach nur ein wenig herumstänkern will. Es gibt genug Berufsfotografen, die diese Geräte einsetzen.
Und ob ein Spyder X Elite schlechter ist als ein Xrite i1 Display pro müsste ein unabhängiger Test zeigen. Mir ist nur ein Bericht bekannt, der beim Spyder im Vergleich zum Xrite „winzige Nuancen“ Abweichung bei Hauttönen ausweist.
Mit den Colorimetern ist es wie mit Lautsprechen. Wenn ich mir privat Boxen für den Wert eine neuen Kleinwagens ins Wohnzimmer stelle, schreien alle Verrat und Blasphemie, Geldvernichter und Größenwahnsinniger. Nur reichen mir die Teile, weil ich kein Goldohr bin und mir meine musikalische Bildung und das Altern ein wenig die Marschrichtungszahl vorgeben. Trotzdem sind die Dinger schon weit, weit über Durchschnitt. Klar kann man auch Teile für 30k pro Stück und mehr kaufen. Nur wage ich zu bezweifeln, dass 99.9 % der Hörer da noch einen echten Unterschied wahrnehmen können. Schlangenöl eben. Das ist bei den Colorimetern nicht anders, wenn man deren Eigenheiten kennt.
Die eigentliche Schwachstelle beim SpyderX ist nachweislich die sehr schlichte Software. Die als Erstes zu ersetzen ist wichtiger, als über die Colorimeter zu schwafeln. Die günstigen X-Rite sind jetzt als Calibrite auf dem Markt, aber wirklich besser sind die auch nicht. Das X1 sollte in Nuancen besser sein als der SpyderX, aber das echt schon Erbsenzählerei unter Profi-Fotografen, die Ihre Edel-Monitore jeden Tag neu beweihräuchern.
Diese Homepage bietet kostenlose Inhalte für die Leser, ist bewusst unterdurchschnittlich monetarisiert und versucht trotzdem, mit den möglichen Ressourcen noch das Maximum zu erreichen. Sicher kann man auch Verträge mit den Firmen machen, bis hin zu gesponserten Colorimetern, nur ist das dann die Art von Abhängigkeit, die ich hier nicht wirklich möchte.
Ein schönes Beispiel ist unsere Lüftermessung, weil es immer wieder belustigend ist, wenn wir Firmen mit sauteuren Messkammern Fehler nachweisen können. Man kann auch mit zweckmäßig ausgesuchten Messgeräten und einer sehr guten Kalibrierung recht gut an die Extremlösungn rankommen. Man wird es nicht ganz erreichen, logisch, aber für die angepeilten zwecke reicht das völlig aus.
Antwort 6 Likes
FritzHunter01
Sorry, aber wenn du schlechte Laune hast, dann solltest du vorher auf einen Boxsack einschlagen. Mich ohne Hintergrundwissen so anzfahren, das finde ich schon echt dreist und unangebracht. Mir ist sehr wohl bewusst, dass der SpyderX nicht die Spitze des Eisbergs darstellt. Mach dir da mal keine Sorgen!
Dir scheint nicht bewusst zu sein, dass die Firma Portrait Displays - das höhste Ansehen in der Branche genießt. Alle großen Namen (LG, Samsung, Sony und die Hersteller wie MSI, ASUS etc.) arbeiten mit Calman.
Um eine Hardwareunterstützung in Bezug auf die Software zu bekommen, werden die Colorimeter von Protrait Displays geprüft. (Wie bei NVIDIA mit G-Sync, das steht auch nicht auf jedem Bildwiedergabegerät) Schließlich hat Portrait Dispalys seinen guten Ruf zu verlieren, wenn man mit jeder x-beliebigen Hardware rumkalibiert und ein Protokoll mit dem Namen Portrait Displays Calman Ultimate bekommt. Welches einem garantiert, dass die erreichten Werte des Displays stimmen müssen. Ebenso hat auch die Firma Data Color einen Namen in der Branche!
Schau dir die Homepage von Portrait Displays mal genau an und unter Calman Ultimate findest du die Spezifikation. Wer lesen kann ist klar im Vorteil.
Des Weiteren stehe ich im engen Austausch mit anderen Kollegen, die ebenfalls solche Artikel/Reviews machen. Bisher hat keiner gesagt: Ooooohhhh das geht aber gar nicht... Das einzige, was beim SpyderX problematisch wird ist der Kontrast jenseits von 20.000 : 1. Das liegt aber nur am Black Level. Das Problem haben auch die X-Rite Colorimeter!
Für OLEDs und HDR Messungen wo es auf dynamischen Kontrast ankommt, da braucht man dann im Zweifel sowas: Colorimetry Research CR-100
Auf dem Level sind wir noch gar nicht angekommen. OLED und das weiß jeder, hat im Grunde unendlichen Kontrast. Bei VA- Panel (TVs) native > 20.000 : 1 und dynamisch > 100.000 : 1 kommt es auf solche Geräte ( wie das CR-100) an. Und auf das Kontrast-Problem habe ich deutlich hingewiesen.
SDR ist doch schnulli-pups, das könnte das geschulte Auge auch mit einer Farbtabelle neben dem Monitor ermitteln, nur dann glaubt es mir wieder keiner.
Aber solche Aussagen nehme ich sportlich, ich besorge mir ein::
Calibrite ColorChecker Display Pro​
Dann mache ich Vergleichsmessungen. Da freue ich mich schon drauf...
F
FcryCola
82 Kommentare 6 Likes
Klasse dass ihr jetzt mit der besten Software am Markt testet.
HUB ist nach wie vor für mich die Referenz.
Ich selber träume schon lange von einer Ultimate-Lizenz aber der Preis ist für das Private wirklich heftig.
Besteht eventuell die Möglichkeit bei Portriat mal anzufragen, ob sich da etwas bei Sammelbestellungen intern hier übers Forum machen lässt ?
Gerade HDR und TV kalibrieren ist der große Reiz bei mir und Home langt dafür nicht.
FritzHunter01
Grundsätzlich denkbar, dazu müsste man aber erstmal wissen, wie viele die Software haben wollen?
MeinBenutzername
214 Kommentare 75 Likes
Die Ausgabe wirkt sehr detailreich, aber dennoch strukturiert genug um einen guten Überblick auf alles Nötige zu haben.
F
FcryCola
Können wir dazu einen Aufruf machen?
Es gibt halt leider bei Calman nur all-in oder Home. Gut Home funktioniert auf dem LG bei mir daheim aber der AW3423DW will trotzdem gerne vollständig kalibriert werden und gerade ältere TV sagen auch danke.
FritzHunter01
Das geht auch mit DisplayCal
F
FcryCola
Aber ziemlich umständlich. Falls du Lust hast eine Anleitung gemeinsam zu erstellen würde ich sehr gerne dazu helfen.
Alle nötigen Informationen gerade für HDR und Displaycal muss man sich mühselig zusammensuchen.
Auch das Thema DWM und 3D-Lut ist sehr interessant aber kompliziert.
Fritz Hunter
