Graphics Monitors Practice Reviews
LG UltraGear 27GN950 in long-term test – UHD gaming with 144 Hz – in good and cheap?
Today there is my second test monitor, which I use for my articles concerning DLSS/FSR etc.. UHD gaming is becoming more and more popular and thus you also need a monitor that can reproduce this resolution natively. Thankfully, LG supported me here and provided me with the LG UltraGear 27GN950. The LG 27GN950 dates back to 2020 and had an MSRP of 899 Euros. In the meantime, there is already a successor, to which I will refer here and there. Today’s corpus delicti, however, is the LG 27GN950. It should be on the list when you think about buying a UHD gaming monitor.
The monitor is from LG Electronics and the panel is from LG Display. This is a nano IPS panel with a max resolution of 3840 x 2160p and RGB subpixel layout. LG lowered the RRP to 599 Euros, which sounds much better. Now the monitor just has to prove its gaming suitability. Hoping that the LG 27GN950 can also be used for working in the sRGB and P3 color space. But one after the other… My test sample was passed on to me with already more than 1,500 operating hours on the panel – so to speak. God knows who was allowed to run riot on it.
But that doesn’t matter, because I can show you the performance of this monitor in the long run. You can compare this with other tests from 2020/2021, it will be interesting. The most important features are listed in the usual overview: More can be found on LG’s website (click here)
So, let’s collect briefly. The display is supposed to have a real 10-bit color depth? I’m not so sure about that and say that the display uses 8 bits + FRC. It doesn’t matter if it’s 10 bit or 8 bit + FRC, it doesn’t make a difference. If you want to use the 144 Hz in UHD, you have to have a GPU that supports DP 1.4 with DSC. Otherwise, the 144 Hz or 160 Hz won’t work. Yes, you read correctly: The LG 27GN950 can also run at 160 Hz with overclocking enabled. But only from firmware greater than v3.03, 5.57. I will return to this topic at the very end. Grrrr…
Since I don’t have a decryption of the Da Vinci code for the LG 27GN950, we’ll leave that out today. Likewise, I don’t have a PDF from the manufacturer to show you more specifications. Therefore, today only a picture from the LG homepage:
On paper, the monitor does have a lot to offer. Then let’s see what will come true in the end. We start with the external impression, cables and fuss. One page further please…
Xoodo
32 Kommentare 13 Likes
Danke für den Test, ich bin auf der Suche nach einem 4K Monitor und auch schon auf einer anderen Seite auf diesen Monitor gestoßen.
Hat das getestete Modell auch so schreckliche Schwarzwerte und stark ausgeprägtes Backlightbleeding? Und falls ja, sind diese nur bei sehr dunklen Bildern zu sehen? Siehe Bilder unten.
T
Thorsten Heldt
33 Kommentare 17 Likes
Hört sich gut an. Ein Test des DELL 2721DGFA wäre mal nicht schlecht. Ist zwar nur WQHD, aber mit allem was es so gibt. FREESYNC PREMIUM PRO, G-SYNC, HDR, 165 Hz, aber wohl kein sRGB, wenn ich es richtig vertstanden habe. Preis momentan 380 EURO, zu Blackfriday letztes Jahr 299,. Dell bietet wohl auch 3 Jahre Garantie, 0 Pixelfehler Garantie etc, wenn beio Dell regestriert wird, egal wo gekauft. Panel ist auch LG. Wäre vielleicht mal wert zu testen.
Gruss Thorsten
M
Moeppel
944 Kommentare 359 Likes
Nutze den Monitor mehr oder minder seit Release. Dank einem FW Update sind technisch sogar 165hz möglich, zumindest unter Windows. Den Lüfter habe ich persönlich noch nie gehört/wahrgenommen, kann allerdings Lotto sein.
Unter Linux bleibt mein Bildschirm mit 165hz schwarz, also maximal 144hz möglich. Gibt es ggf. Lösungen für, habe ich mich aber nie mit auseinandergesetzt. Ohnehin ist es recht schwierig mit der current gen die jeweiligen Threshold zu treffen, oder gar konstant zu halten. Je nach Titel versteht sich.
Je nach Titel präferiere ich 1800p als stop gap, um die extra FPS mitzunehmen.
Bisweilen bin ich auf rund 6500 Betriebsstunden und habe keinerlei Beschwerden.
Mein nächstes Upgrade wird OLED sein.
Wann, wie und wo steht allerdings noch in den Sternen, da es recht zäh voran geht bzw. oftmals allenfalls in schreibtischuntauglichen Größen.
grimm
3,572 Kommentare 2,618 Likes
Danke für den Test, ich hab den 850 auf dem Schreibtisch. Der kann weniger, macht aber auch, was er soll.
FritzHunter01
1,410 Kommentare 1,896 Likes
Welchen 850 gl/gn/gp?
FritzHunter01
So extrem konnte ich das nicht wahrnehmen. Das ist immer ein Thema bei IPS. Beim GN950 ist das aber echt nicht so schlimm.
Schau dir andere Reviews auch international an… ich gehe davon aus, dass das für deine Ansprüche passen sollte.
Weiter unten hat @Moeppel bereits 6500 Std auf den Panel. Hat der Kollege Probleme mit Backlight bleeding?
x
xavyer.keiren
25 Kommentare 6 Likes
Ich habe den 38GN950 dank gleicher End-Nr. gehe ich mal von einer gemeinsam (Firmware-)Basis aus ...
Die RGB Steuerung funktioniert bis heute nicht! Ohne Windows-Software überhaupt nicht nutzbar und auch nicht konfigurierbar.
Das tolle ist das vom Werk ein Disko-Effekt eingeschaltet ist ... Dauerhaft. Deaktivierung übers OSD vom Monitor ... nicht gegeben!
Unter Windows 10/11 startet der Monitor nach konfiguration über die Software absolut immer mit statischem Licht, hatte das Ding eigentlich wegen dem "Ambi-light" gekauft! Darf man dann bei jedem Start wieder händisch über die Software aktivieren. Der Effekt hält mit den alten Versionen von der LG-Software einige Stunden und mit den akzuellen genau 2min, danach hat man wieder die statische Anzeige. Schaltet man das Licht komplett aus schaltet es sich nach ein paar minuten wieder autark ein! Wenn man diesen Schwachsinn nicht zum laufen bekommt hätte ich doch gerne im OSD einen Punkt um das Ding komplett zu deaktivieren ohne Software! Als Linux nutzer hat man Dauerhaft also Disco ohne jede Möglichkeit es abzuschalten! Im OSD gibt es "tolle" Energiesparfunktionen, Null Dokumentiert was hier der Unterschied sein soll, Null Antwort von LG. Auch kann oder besser man kann eben nicht im Menü ein paar Fadenkreuze dauerhaft überlagert auf dem Bildschirm aktivieren als Zielhilfe für PengPeng-Spiele ... der Punkt hat keine Funktion. Genauso kann man im OSD Ton für das Bildschirm-Menü Einstellen, meine vorherigen Monitore haben da immer schön ein Klickgeräusch beim Menüwechseln gemacht, der LG macht überhaupt rein garnichts.Funktioniert das Zeug auf dem 27er?
Ich habe den Monitor quasi ab Tag 1 das erste 3/4-1 Jahr war der Monitor mit der LG Sofware fürs Licht (LG Control Center) überhaupt nicht nutzbar weil er nicht erkannt wurde an einer Nvidia GPU während man fröhlich über OnScreen Control schalten und walten konnte. Herrlich dass man min 2 Stück Software braucht um das Ding richtig zu nutzen! Urplötzlich haut Nvidia einen neuen Treiber heraus und oh Wunder es geht. Mit einer AMD GPU wurde der Monitor erkannt auch wenn er da das gleiche Fehlverhalten mit dem Licht hatte.
x
xavyer.keiren
Ach ja und bzgl. Betriebsstunden ... die kann man übers versteckte OSD einfach wieder auf Null setzen wenn jemand einen gebrauchten Kauft.
Da gibts noch ne Latte an EInstellungen ohne Doku.
M
Moeppel
Sofern ich dran denke, werde ich heute Abend mal nachsehen.
Prinzipiell bin ich aber auch niemand, der es präferiert im dunkeln zu sitzen/daddeln. weshalb mich ein mögliches BLB recht wenig tangiert.
Augenprobleme habe ich bereits genug :D
IPS Glow/BLB liegen allerdings auch in der Natur der Technik. Wo da jemand seine Grenzen hinsichtlich Akzeptanz zieht, variiert gerne recht stark. Ähnlich stark wie bei Panels, je nach QA 🤡
Zu RGB Bling kann ich nichts sagen, erste Amtshandlung war, den Krempel auszustellen.
grimm
FritzHunter01
@Moeppel ist ein RGB Leugner… unglaublich! 😂
aber wenn RGB dann schon richtig wie beim GN950, sonst können sich die Hersteller es auch sparen…
Ist halt Geschmacksache
Ghoster52
1,700 Kommentare 1,362 Likes
Danke für den Test! (y)
Ich habe ein LG UltraGear 32GP850-B, 31.5" mit 1725 Betriebsstunden, der kann 1440p @ 180Hz (OC-Mod)
Am HDMI Port geht auch 4K @ 60Hz, was so nicht im Datenblatt steht.
FritzHunter01
Wie jetzt das 1440p Panel kann nativ 2160p??
Ghoster52
Ja, Windoof und Linux starten in 4K an der HDMI-Strippe, mit Display Port geht nur 1440p
Case39
2,689 Kommentare 1,057 Likes
Danke für den Test. Der Monitor war auf der Liste der potentiellen Nachfolger für meinen Viewsonic. Werde aber bis zum bitteren Ableben abwarten, einen Neukauf zu tätigen.
Xoodo
Ja schaue Monitortests meistens bei prad und rtings vorbei, von dort stammen auch die oben geposteten Bilder, allerdings scheint es, als ob die dort einfach eine Montagsproduktion erwischt haben.
Ich glaube du unterschätzt meine Ansprüche ein wenig @FritzHunter01 xD, ich suche eigentlich einen 4k Monitor mit 27" mit dem Kaliber eines Samsung Odyssey Neo G8 G85NB, GIGABYTE M32U, AOC Porsche Design Agon Pro PD32M, aber das Problem ist, dass es die Dinger nur in 32" gibt :( .... Auch wenn ich keine großen Hoffnungen in die neuen Cooler Master Boliden setze, bin ich mal gespannt was der Miniled Monitor Tempest gp27u zu leisten vermag, wenn man schon so tief in die Tasche greift und sich eine 4090 anschafft, dann lohnt sich das auch nur mit den richtigen Monitor, wenn man Geld sparen kann und für ~600€ einen sehr guten Monitor bekommt, dann freut man sich über das gesparte Geld, aber sobald HDR ins Spiel kommt, spielen die Monitore leider immer in einer ganz anderen Liga (HDR 1000+).
Hab zwar einen OLED Fernseher von LG hier stehen, aber das nervt schon alle 4 Stunden das Ding 10 Minuten ausmachen zu müssen, damit der Pixelrefresher arbeiten kann. Aber wenn man einmal unendlichen Kontrast genossen hat, will man das eigentlich nicht mehr missen, aber bei einem Computermonitor geht die Dauernutzung für mich persönlich vor, da sucht man halt einen guten Kompromiss.
Naja kleiner als 27" werden die neuen Monitore wohl nicht werden bei 4k (Alles über 160PPI ist eh schwer Unterschiede zu erkennen), aber ich
Ich bin auch auf das Release von der neuen PIMAX 12K gespannt, denke aber, dass die 4090 auch nicht genug power hat, die vernünftig zu befeuern. Da muss man schon schauen was DLSS 3.0 reißen kann.
Averomoe
11 Kommentare 5 Likes
Ich will dieses mal ein Auge zudrücken, jedoch endet meine Nachsicht bei seit/seid... *seine Augen in klarem Wasser auswasch*
P
Phoenixxl
162 Kommentare 126 Likes
Ich habe vor ein paar Monaten den M32U bin Gigabyte gekauft und bin sehr zufrieden.
Ich benutze ich ni hat zur Bildbearbeitung und kann nicht sagen, ob die Farben akkurat sind, aber das Bild sieht super aus.
HDR nutze ich nicht.
Der KVM zickt manchmal rum, aber mit an und wieder aus konnte ich bisher noch jedes Problem lösen
M
Moeppel
Siehe Anhang.
Die Kamera tut dem ganzen keinen Gefallen, es nicht ansatzweise so schlimm, wie dargestellt (IRL dunkler als abgelichtet). Dennoch offensichtlich auch alles andere als uniform oder gar BLB-frei. Immerhin scheinen die vier Ecken ziemlich gleichmäßig zu bluten 💃
Auch ist der Kontrast bzw. die "Schwärze" in keinster Weise mit der eine OLEDs vergleichbar.
Contrast 50, Helligkeit 90, Black Stabilizer 50.
Auch wenn es den Eindruck macht, dass ein weißes Bild angezeigt wurde: Es war schwarz und wurde ohne Blitz aufgenommen 🤡
Fritz Hunter (Stefan Bauer)
