GPUs Graphics Reviews
In review: AFOX HD 7850 – nimble Radeon flatscreen in single-slot design | Retro 11 years ago
Of course, we still remember the Radeon HD 6850, which was also slimmed down by AFOX. This time, the diet hits the new Radeon HD 7850, a card that virtually offers itself in terms of performance and waste heat. The first sample of this new card contained a rather unusual surprise, which we already presented in detail last week in the article “AMD’s Pitcairn with 768 SPs in the test: The chip, which unfortunately was never allowed to exist as Radeon HD 7830” and which also stirred up a lot of dust. So now the real card, which will also go on sale in this form. In order to get a proper impression of this extremely flat card, we also relied on videos this time and acoustically evaluated the different load conditions of the card.
Since AFOX has already contacted distributors in Germany, you can be confident that you will be able to purchase this somewhat exotic solution without having to import it yourself in the foreseeable future, even though there are now sources of supply in the Netherlands and the UK. Reason enough for us to take a closer look at this card. Single-slot solutions unfortunately have the reputation of not being the quietest card solutions – we’ll find out if this assessment still holds true, or if the new graphics card generation can perhaps even deliver contrary results due to the reduced consumption.
Sex sells – that’s probably what AFOX thought, when they used a newly designed packaging for the first time this year, which follows the general trend and now also uses its own female fantasy figure. This result is definitely better than the sausage-like plastic bride from Lucidlogix.
What we liked inside the package, as with Sapphire, was the lack of injection molded plastic. Except for the blister foil and a soft foam insert, the outer packaging is made entirely of cardboard and is thus also easily recyclable. A small manual and an inserted driver CD belong to the accessories.
If we look at the present technical data, then the surprise is missing this time. The Tahiti Pro chip’s full shader expansion with 1024 shader units lets us expect the usual results, especially since all clock rates correspond to AMD’s reference model. Of course, the unusual cooling remains as a unique selling point.
Let’s take another look at the comparable cards:
  HD 7770
Engineering Sample
768SP
HD 7850
HD 7870
Stream processors 640 768 1024
1280
Texture units 40 48 64
80
Full Color ROPs 16 32 32
32
GPU clock 1000 MHz 860 MHz 860 MHz 1000 MHz
Texture fill rate 40 Gtex/s 41.3 Gtex/s 55 Gtex/s
80 Gtex/s
Memory clock 1125 MHz 1200 MHz 1200 MHz
1200 MHz
Memory bus 128-bit 256-bit 256-bit
256-bit
Memory throughput 72 GB/s 153.6 GB/s 153.6 GB/s
153.6 GB/s
Video RAM 1 GB GDDR5 2 GB GDDR5 2 GB GDDR5 2 GB GDDR5
Transistors (billions) 1,5 2,8 2,8
2,8
Structure size 28 nm 28 nm 28 nm
28 nm
Power connections 1 x 6-pin 1 x 6-pin 1 x 6-pin
2 x 6-pin
Power consumption (max) 80 watts 120 watts* 130 watts 175 watts
*) please note that this is not a final GPU
Card views
A single-slot design is always something special in this performance class. Reason enough to take a closer look at the review sample. The flounder look is quite appealing for many a spatially very limited system and often enough the only possible solution. Unfortunately, representatives with this small hip circumference have become very rare. The board on the other hand is a normal standard solution, whose layout does not hold any big secrets.
DrDre
354 Kommentare 195 Likes
Hatte damals die HD7870 (Sapphire Puls) jahrelang mit ei em max OC Bios laufen. War ne schöne Karte.
Irgendwann wollt sie nimmer und ich hab abgeplatzte Elektronic Teile gefunden :(
matz86
28 Kommentare 9 Likes
Ich hatte bis vor einem Jahr noch eine Sapphire HD6970 im 2. Rechner in Betrieb.
Diese wurde jetzt für die Jährliche LAN Party durch eine 5700XT ersetzt.
Die HD6970 hat irgendwann den Kühler einer Asus DirectCU 7950 bekommen die Verstorben ist.
Die Sapphire läuft trotz max. OC immer noch einwandfrei.. aber säuft auch wie ein Loch! 🙂
A
ArcticWolf
60 Kommentare 26 Likes
Ich will alle meine bisherigen Grafikkarten in einer Art Vitrine stellen. Dachte im ersten Moment, dass hier eine Ati 9700 getestet wurde. Hatte mal eine von Connect3d. Doch die hier sind ja quasi Jungspunde dagegen.
Die 9700 fehlt mir nämlich noch für meine Sammlung, neben einer Riva TNT1. Gar nicht so leicht zu bekommen, zumindest bei Kleinanzeigen. Naja, ist ja auch eher was für den Schrottplatz im Normalfall.
Guest
Hi!
ich glaube noch eine verpackt eingelagert zu haben.. Wenn ich sie finde, schick ich sie.. ( Geduld)
Kann auch sein, dass sie bei einem meiner MC GYVER EXPERIMENTE ko ging.
( zb im Sommer baust du Spiegel Laserkanone nach und röstetst alte Technik oder bohrst Löcher in 10 mm Stahlplatten)
( Sicherheitshinweis : DAHINTER BITTE BETONWAND, kein WALD und nix brennbares)... und KOpfkörer.. es wird laut. lol peace :)
A
ArcticWolf
Cool, danke. Nehme ich gerne an. Sie muss nicht funktionieren. Bohrlöcher wären etwas schräg aber besser als nichs. Rest dann per PN.
LurkingInShadows
1,473 Kommentare 632 Likes
Die 7970 Vapor läuft hier noch 10 Stunden am Tag^^
2,460 Kommentare 1,612 Likes
Nur indirekt damit zu tun, aber ich wünsche mir (immer noch) eine gute Mittelklasse GPU mit 16 GB RAM, die weder übermäßig lang noch dick (2 Slot maximal ) ist und (hier kommt die Stahleierlegende Wollmilchsau) als Blower ausgeführt ist. Wenn's geht, keine (teure) "Profi" Karte und einigermaßen leise. Wär ich glaube ich nicht der einzige, der sowas attraktiv finden würde. Träumen darf man ja😀
Steffdeff
945 Kommentare 908 Likes
Hat zwar keine 16 GB aber ist schon nah dran!
Follow Igor:
