Aircooling Basics Cooling Editor's Desk Measuring instruments and tools Practice Pro Raffle Watercooling
Our new TDP simulator was born – Even better measurements for coolers, water blocks, radiators, thermal pastes and pads | Practice
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
We all know that Igor’s LAB and reliable measurement technology go together like a riot and it still captures the meaning quite well. I, Bernhard from CrankzWare, was consulted by Igor and asked for practical help to jointly develop a measurement prototype as a TDP simulator and, as it were, to bring it into the world in real existence. Of course, I like to support my dear friend with expertise and manufacturing know-how, so that this project was not only a lot of fun in the end, but also cost a lot of nerves – just as it should be for a demanding project. Otherwise life would be dull and boring.
But what are we talking about now, specifically? Igor would like to test cooling components and heat conduction media, whether air- or water-bound, reliably and also reproducibly. The primary focus of this project is the precise control of the waste heat in watts, and secondarily, of course, the traceability and suitability for use in a laboratory environment. In short, it is a matter of converting electrical energy into thermal energy. What is particularly exciting about this project is that I have to intentionally emit exactly what chips actually only emit as an annoying side effect, namely heat.
The following maxims were prescribed for me as specifications:
  • Safe operation
  • High load capacity
  • Accurate measurement tolerances (</=1%)
  • High reproducibility of all tests
  • Scalability and editability of the superstructures
  • Predefined TDP levels for common waste heat classes with fine tuning
  • Universal attachment to enable a wide range of measurements, even across divisions
Since I’m not a metalworker and I’m sure I never will be, Igor will (have) further developed and manufactured the more advanced work such as special support surfaces for heat conducting pads with special sensors and pressure adjustment. My part is that of a heat sling as accurate as possible as a reliable and durable base. The rest is then a pure accessory development and not my thing anymore. But also the construction of the heating station has become a bit trickier than initially thought. But I don’t want to get ahead of myself.
The conception
When electricity is to be converted into heat, one always thinks first of the temperature resistance of possible components and assemblies. Of course, in this context I decided to use an aluminium housing, because a thermal decoupling between heater core and housing can never really be 100% successful. The next thought was then how to make this prototype safe in operation. The answer is quite simple, at least with functioning building services: An input fuse, as well as a decent grounding of the housing are the usual minimum requirements.
We continue with the general electronics: We use power supply modules that convert our 230V alternating current to 12V direct current. The heater core will then use this 12V to efficiently convert electricity into heat. There are two basic ideas here: either use heater cartridges to fire the heater core, or load resistors. Both should work, but in the end I decided for the second one, the reason you will find out later.
Most of the work is done by the control system. This should be fast, precise and comprehensible. Of course it is good in the first step if we have thought out the energy conversion in general, but performance without control is also worth nothing. Since we are dealing exclusively with heating cartridges or load resistors as “consumers”, my solution is: power amplifier, PWM controlled on low-side.
Since the status and the settings of the device have to work quickly and reliably even in rough environments (and because my software developer is on his last legs in terms of capacity), we stick to analog technology here. Of course, a programmable display would also be a good idea, but that would require a lot more development time, so in this case, LEDs and a potentiometer, as well as a few illuminated LCDs will do for now.
I had my fun planning and assembling it, you have it now (hopefully) reading it. And I can promise you now, it will certainly be interesting and anything but too theoretical and boring. We are still craftsmen and developers, not politicians 🙂
RedF
5,252 Kommentare 3,050 Likes
Danke für die einblicke in das Projekt.
Jetzt kann ich erste messungen kaum abwarten : )
ipat66
1,519 Kommentare 1,587 Likes
Freue mich auch schon auf die Ergebnisse.
Geiles Projekt !!!
Danke Igor,danke Bernhard.
Eine Frage kam mir aber in den Sinn,als ich das Photo des fertig montierten TDP-Simulator sah.
Wie lange wird die (scheinbare) Obergrenze von 240 W ausreichen?
Der immer größer werdende Energiehunger von CPU und GPU ist ja, gelinde gesagt, extrem.
Auf der anderen Seite,bleibt ja anscheinend noch Platz für ca. 3 weitere Dioden rechts von 240 W...:)
11,515 Kommentare 22,131 Likes
Für das, was ich hier testen werde, reicht das mehr als aus. Denn selbst GDDR6X hat ja nur 3 Watt pro Modul und CPUs liegen unter 200 Watt. Und es ist ja erst einmal mehr nur der Prototyp. Das lässt sich später noch erweitern.
D
Deridex
2,230 Kommentare 867 Likes
Schönes Projekt. Ich denke damit lässt sich zumindest feststellen wie es um die allgemeine Wärmeabfuhr steht. Jedoch denke ich, dass das den Test auf der CPU/GPU nicht ersetzen kann.
Ein paar Details sind mir beim In-der-Mittagspause-kurz-überfliegen aufgefallen:
- Das EDA Tool sieht mir stark nach Eagle aus. Verwendest du das wirklich auch für 8Layer?
- Ich glaube die Pins beim Footprint der Mosfets sind zu weit auseinander. Wenn es um den Abstand geht, rate ich dazu, die Pins auf der dünneren Seite des Materials (sind normalerweise rechtwinklig und nicht quadratisch) zu biegen.
- Habt ihr einen Lüfter im Gehäuse? Fals nicht würde ich dringend dazu raten.
Edit: Punkt gestrichen und etwas ergänzt
ipat66
Im Gehäuse sind keine...
Rechts und links am Gehäuse aber schon ( 2x80er Lüfter )....:)
Sieht man auf dem letzten Bild und bei der Beschreibung der Inbetriebnahme.
D
Deridex
Ops, habe ich übersehen :)
ELITKon GmbH
27 Kommentare 37 Likes
Yep, da hast du recht. Ich mache öfter mal viele Layer mit EAGLE aber ab 6 wirds unschön :) Die Vias für die MOSFETs sind tatsächlich 5,08 mm Rastermaß und nicht 2,54, wie es sich für TO220 eignentlich gehört. Das habe ich in diesem Fall aber so machen müssen, da die Traces zu dick waren und ich keinen Aufpreis für das PCB für doppelte oder dreifache Kupferlage bezahlen wollte.
T
Tombal
113 Kommentare 28 Likes
Ganz schön mutig, die beiden Open-Frame-Netzteile einfach so parallel zu schalten. Wie soll den so eine gleichmässige Lastverteilung erreicht werden? Ist die Spannung des einen Netzteils nur einige Millivolt höher, als die des anderen, dann übernimmt es die komplette Last. Bei vielleicht 180W wird es dann Überlast erkennen und sich abschalten, dann übernimmt Netzteil #2 und schaltet sich wenige Millisekunden später auch ab. Nummer #1 ist inzwischen wieder gestartet und die ganze Schaltung schwingt wie verrückt.
Die Schaltung würde ich daher so abändern, dass jedes Netzteil getrennt jeweils die Hälfte der Lastwiderstände betreibt. Und ich habe gesehen, dass beide Netzteile direkt übereinander montiert sind - da wird sich das untere nicht besonders wohl fühlen und sich rasch aufheizen.
ELITKon GmbH
Die Netzteile wurden natürlich vorher aufs Zehntel Millivolt genau eingestellt mit geeichtem Multimeter. Schwingen kommt nicht vor, da die Netzteile für mehrfachen Parallelbetrieb ausgelegt sind realisiert wird das durch einen Komparator. Die Netzteile werden nicht wärmer als 35 Grad oben und 45 Grad unten bei Zimmertemperatur wenn die Lüfter laufen.
jahtari
259 Kommentare 123 Likes
Für mich als ausgebildeten Informationselektroniker und Industriemechaniker ziemlich spannend und auch direkt zu Beginn schon amüsant:
Passiert Dir bestimmt kein zweites mal. Ich wette, beim nächsten Projekt wandert das Gehäuse unlackiert beim Schlosser. :p
So und jetzt les ich erstmal weiter. ;)
Guest
Ja, sehr interessant, danke an Bernhard und Igor. Als alter Metaller (jo, auch handwerklich ;)) fand ich die Umsetzung auch sehr angemessen. Auch wenn man die Stellen dann nach dem Einbau der Displays nicht mehr sieht, aber so pingelig, wie ich da bin, wäre ich wohl nochmal sauber drüber gegangen.
Mir geht es da wohl entgegengesetzt zum Autor, da ich mich mit der Arbeit mit Metall immer wohler gefühlt habe. Elektrotechnik habe ich wegen meinem Techniker zum Glück nur marginal machen müssen. Und auch da: auch wenn ich liebend gerne an PC´s rumbastle, was ja letztendlich auch in dieser Richtung ist, kann ich mich für die Feinheiten dahinter nicht so begeistern. Deswegen sind dann auch viele Begriffe nicht so geläufig.
Aber Geschmäcker und Vorlieben sind ja zum Glück verschieden.
Und das Lesen des Artikels hat wirklich Spaß gemacht, auch wenn ich nicht alles gleich verstanden habe. Aber Igor wird das restliche dann mit seinen Tests erledigen, da muss ich mir keinen Kopf machen.
Bin auch schon auf ersten Messungen gespannt.
D
Deridex
Hm, wenn ich so drüber nachdenke, habe ich auch Zweifel bei den Netzteilen. Ich habe bei Meanwell (glaube solche Netzteile sind es oder?) keine Info darüber gesehen, ob die für den Parallelbetrieb geeignet sind.
k
kermit_nc
51 Kommentare 19 Likes
Ich habe in meiner Firma mal was ähnliches zusammengestellt, nur durfte ich mich nicht so austoben sondern musste auf fertige Dinge zurückgreifen. Die Quelle war da ein EA-PS9040-20T das über die EA Control SW gesteuert wurde. Mit 1200EUR nicht ganz billig aber sehr gut ausgestattet.
S
SnailSoft
10 Kommentare 16 Likes
Ja wenn das so ist...
Ich tue mich auch schwer damit Schaltnetzteile einfach parallel zu betreiben, nach schnellem googlen wurde wenigstens empfohlen identische Netzteile erst an der Last zusammen zu schalten und auch nicht übereinander zu verbauen, wegen den unterschiedlichen Temperaturen und den daraus resultierenden Abweichungen innerhalb der Netzteile...
Es soll spezielle Netzteile mit Load-Balancing geben, die haben dann aber auch weitere Messleitungen dafür, das hier sieht nach Meanwell aus,
ich verbaue die auch gerne selber, aber dieser Parallelbetrieb ist mir auch höchstgradig suspekt.
Und da 2 Netzteile in der Regel teurer sind als eines erschließt mir der Sinn nicht ganz:
Leistungsklassen mäßig ist man ja auch noch lange nicht am Ende.
Von der Herstellergarantie mal ganz abgesehen...
N
Name
75 Kommentare 14 Likes
Interessanter Artikel und immer toll wenn man auch die Hintergründe zu den Messeaufbauten erklärt bekommt.
Nur stellt sich mir jetzt eine Frage:
Wie vergleichbar sind diese Test dann mit einem Test der auf der auf einer CPU durchgeführt wurde? Bzw würde eine CPU die 200W "ausspuckt" aber bestimmte Hotspots hat und auch bestimmte Unebenheiten auf dem Heatspreader hat (z.B.: Konkav, Konvex) auf den jeweiligen Kühlern nicht eventuell ein anders Ergebnis bringen als auf dem TDP Simulator?
Falls ich hier Grundlegendes nicht verstanden habe wär es nett wenn mir das jemand näher bringen kann.
RedF
So hast du eine immer gleiche Platform, wie du schon geschrieben hast ist jede CPU anders.
Vorallem aber ist das super um Wärmeleitpads und Pasten zu testen.
LEIV
1,599 Kommentare 674 Likes
Genau, geht ja darum, alles vergleichen zu können, jeder Prozessor kann geringfügig andere Wölbungen haben, die Kühler sind ja vielleicht auch nicht 100% plan - so hat man wenigstens nen theoretischen Vergleich, der sehr dicht an die Praxis heran kommen dürfte
ipat66
Ich denke mal,dass zum messen der Leitfähigkeit von Pads und WLP aussagekräftige
Vergleiche gezogen werden können.
Natürlich wird dies vielleicht nicht 1zu1 übertragen werden können (eben wegen solcher GPU und CPU Hotspots), aber zumindest gibt es schon eine Vorauswahl von qualitativ hochwertigen Produkten.
Die Hotspot Problematik und Wärmedichte,bleibt so oder so erhalten.
Zumindest weiß man dann ob die Produkte die angegebene Wärmeleitfähigkeit einhalten.
Außerdem muss man dann nicht jede GPU 20 mal auseinander schrauben...
Ist dann doch schonender für die Hardware.
Würde mich nicht wundern,wenn es dann doch einige Überraschungen geben wird.
N
Name
Bernhard Baumgartner
