Audio/Peripherals Keyboard Reviews
NZXT Function 2 Mechanical Keyboard(s) in test – Can the second generation with optical switches and PBT double-shot keycaps attack the upper class?
With the Function 2 series, NZXT has given its mechanical keyboards an extensive makeover. Adjustable optical switches, PBT keycaps and 8000Hz polling are just the tip of the iceberg. Read our test to find out how the bolides perform in everyday use.
First of all, I would like to briefly mention that the mice from NZXT have also received an extensive refresh and are being launched at the same time as the keyboards. You can already catch a brief glimpse of them in this article, but I have decided to publish a separate review next week.
When I was offered the new input devices from NZXT for testing, I naturally couldn’t say “no”. Not only out of curiosity and because of the appealing design, but above all because the new series once again features a full-size keyboard – something we haven’t had for what feels like ages. If you compare the technical data of the Function and the Function 2, there is hardly any overlap. This suggests that a lot of work has been done under the hood. But before we get to the technical details, let’s take a look at the keyboards first.
Unboxing
The outer box of the Function 2 has the typical NZXT design, with the familiar “purple” accents and a picture of the product.
The technical data and the most important features are listed on the back.
The cover is on and as you can see, you can’t see anything. The keyboard is safely protected from dust in a textile bag.
Everything taken out of the box:
And freed from the halfway environmentally friendly plastic film:
In terms of accessories, we find a fairly tight USB-C cable, keycap and switch pullers and four alternative Gateron switches each (30g and 45g), with which you can, for example, customize the WASD keys to your own preferences.
And – unfortunately only included in the “full-size” version – a magnetic palm rest. The picture already shows how dust-sensitive the rubberized surface is.
Let’s take a look then.
Joking aside, here’s the thing in all its glory. Very simple, no frills, that’s just what NZXT is good at.
Unfortunately, the thick aluminum plate doesn’t really come into its own, as the paintwork blends seamlessly into the black plastic landscape.
The underside is also very spartan, with nothing to be seen apart from a few rubber feet.
Except for the adjustable feet for angling the keyboard, of course.
The Function 2 in profile. As with the K65 Plus tested yesterday, the NZXT also has buttons on the side with which you can control the lighting, among other things. As we said yesterday with the Corsair, today again: an absolutely unfavorable positioning for keys – every time you move the keyboard, you switch off the lighting.
There is only one USB-C port on the back.
Although the supplied cable is quite tight, I can imagine that such an unprotected connection can quickly become a weak point.
The rotary dial for adjusting the volume once again in detail. This position is fine for me, but it is also a little unusual, because 9 out of 10 keyboards with a button/roller for adjusting the volume have it on the right-hand side.
Next, let’s take a look at the keycaps and the switches.
PBT double-shot, rough surface, translucent symbols. Perhaps not the highest quality design, but otherwise everything done right!
The NZXT Swift Optical switches are used.
Here are the slots for the switches. Optical switches have no connection pins and can therefore only be replaced by other optical switches – you should keep this in mind. You can see from the smearing around the opening in the aluminum plate that NZXT has not skimped on “lube”.
The stabilizers of the space bar:
Function 2 MiniTKL
Here are a few photos of the “small” Function 2, which not only lacks the number pad, but also the palm rest. Compared to the full-size version, the TKL costs only 10€ less, in my opinion too small a price difference.
Otherwise, the TKL has the same features, including the PBT keycaps.
The switch configuration is also identical.
Finally, a small weight comparison:
Saschman73
586 Kommentare 368 Likes
Da schwemmt es ja gerade eine Tastatur nach der anderen an! 😅
Antwort 5 Likes
N
Nixwiss
24 Kommentare 14 Likes
Funktionieren solche Tastaturen auch im reinen Bios Mode also beim starten des PC?
Guest
Danke für den Test! Vortest!
Was ist OBER KLASSE?
Und warum bemüht man sich ständig solche buzzi s raus zu haben? ( VW mit seinem Passat, will 60.000 Euro..aber hallo das
is ein Vooolchswoochen! Du bekommst in echt 15.000 Euro Auto, der Rest ist SADOMASOCHISMUS.. haben die Kopfweh?)***
Bei der Tastatur ist DAS KABEL nicht fix. nogo hoch 3.
DAS KABEL IST FIX MASSIV und 3 METER lang. Ein Wackelkontakt ala (..... setzen Sie Produktnamen ein ...) ist herb.
Und über Design kann man reden. Da der Purismus eines BERTONE eher selten seinen Weg findet, wird dann hybsch davon
geredet dass.. na ja.
Schön das es die gibt. Wieder eine mehr. PEACE :)
*** disclaimer : das ist ein Beispiel: oder wenn man mit 60.000 Euro 68 % eines Maserati Quattroporte bekommt.
oder wenn man bei LIDL 200 Kilo Kabelbinder um 20 Euro kauft ( lecker und jünsdich) dafür bei BARILLA 2kilo Spaghetti nr5 bek ä meee.
es ist pervers. sieh Timo und Chinabloatware verstopft den Handel..
peace 2
2,375 Kommentare 1,550 Likes
@Alexander Brose : Eine richtige Welle von Keyboard Tests, find ich gut! Das 100% Keyboard (Vollausführung) hier gefällt mir eigentlich auch gut, Dein Test liest sich auch entsprechend. Bei dem USB Anschluss würde ich gerne irgendeine Sicherung gegen versehentliches Rausziehen, und, wie von Dir (@Alexander Brose ) erwähnt, auch gegen Bruchgefahr am Gehäuse wenn etwas auf den Stecker fällt. Und das mit dem Gewicht: ich hätte auch lieber noch ein paar hundert Gramm mehr an Masse, vielleicht auch noch so verbaut, daß es das Keyboard nochmal versteift und zB auch den USB Anschluss gegen Beschädigung sichert. Aber, schön anzuschauen ist das NZXT schon, und wenn sie jetzt noch den Preis etwas senken, wär es noch interessanter.
@NZXT: Gibt's die Möglichkeit, das ihr das hier getestete Keyboard auch für den Betrieb mit ohne Kabelanschluss (USB oder Bluetooth, und bitte mit Wechselakku) baut? So eins würde ich mir kaufen.
E
Eribaeri
159 Kommentare 66 Likes
Kinder, Bildung ist wichtig. Merkt euch das.
E
Eribaeri
Ich habe die Wooting60HE, selbes Prinzip, mit USB-C. War die erste ihrer Art.
Der USB-C Anschluss rastet gewissermaßen ein und hat einen höheren Widerstand gegen das Herausziehen.
S
SpotNic
1,342 Kommentare 606 Likes
Was macht ihr mit euren Tastaturen? Was soll denn da drauffallen, und warum soll der Stecker aus versehen rausrutschen?
E
Eribaeri
Na dann denken wir mal gemeinsam Deinen Gedanken zu Ende. Nicht in den falschen Hals kriegen aber come on...
Diese Tastatur spricht mit ihren optischen Switches, ihrer hohen Abtastrate und ihrer reduzierten Größe verstärkt competitive Gamer an.
Der durchschnittliche competitive Gamer hängt an seinem Aim wie ein Baby an der (....) und benutzt deswegen niedrige DPI-Einstellungen.
Wenn jetzt mal ein hektische 180-Grad Drehung kommt, kann die Maus schonmal gegen die Tastatur kommen. Das knallt dann auch mal. Klingt komisch, ist aber so.
Wenn die Maus jetzt keine gummierten Füße hat und das Kabel nicht ordentlich einrastet, wars das mit dem Movement.
Ist dann ähnlich frustrierend, wie ein Disconnect. Den kennt jeder und will keiner.
S
SpotNic
Gut, da bin ich raus aus dem alter.
E
Eribaeri
Das wissen wir doch ;)
hansmuff
91 Kommentare 59 Likes
Keychron Q65 Gewicht: 1895g, gerade gemessen. Kein Angeben, nur ein Vergleich!
Ist 'ne ordentliche Tastatur, hat aber das selbe Problem wie die Corsair Tastaturen: jeder will seine eigene Software/Hub. Macht den ganzen seg einfach VIA/QMK kompatibel und Ende aus. Alles andere ist, für diesen Preis, einfach Quatsch wenn auch außerhalb der Software gut.
Makami
27 Kommentare 26 Likes
Die Marke stimmt, aber die Wooting One gab es bereits ein paar Jahre früher.
Abgesehen von den Schaltern und der Software eine bescheidene Tastatur, da fürchterlich laut und klapprig.
Und bereits lange davor gab es Hall Effect Schalter mit einer Haltbarkeit/Lebensdauer, die keiner von uns erreichen wird:
Solltest Du Dich nicht verschrieben haben, verstehe ich dies nicht, da die Q65 VIA/QMK kompatibel ist.
Roland83
973 Kommentare 770 Likes
Man könnte die Anschlüsse einfach im Boden versenkt ausführen... mit etwas Kabelführung bzw Zugentlastung wie man das früher bzw. schon immer auch mit den fixen Kabeln bei Keyboards gemacht hat... Das hat dann eben auch noch den Vorteil das man das Kabel zentral, links, rechts ... herausführen kann - wie es einem halt passt. Der Anschluss und dessen Positionierung mit den Schaltern am Rand allein ist eigentlich ein absoluter Ausschlussgrund - und das ist dann Oberklasse um schlanke 160 Euro. Ich kann auch die "Ästhetik" so einer Verkabelungsvariante nicht nachvollziehen, denn die hat maximal den Flair eines Smartphones am Ladekabel....
D
Der Do
111 Kommentare 60 Likes
Freu mich schon auf den Symm 2 Test!(y)
Alexander Brose
845 Kommentare 612 Likes
Ist in Arbeit und dürfte nächste Woche live gehen. Aktuell habe ich leider so viel zu tun, dass ich kaum allen gerecht werden kann.
Grüße!
Alexander Brose
