GPUs Graphics Reviews
KFA2 GeForce RTX 3070 Ti SG 8GB Review – More than just a butter-and-bread model?
With the KFA2 GeForce RTX 3070 Ti SG (One Click OC), where the SG stands for Serious Gamer, KFA2 offers an amped graphics card that is subject to LHR restrictions and is rather unsuitable for mining Etherum. That’s probably the reason for the abbreviation SG, which verbally excludes the sideline at least with this special cryptocurrency, but otherwise has no influence on the normal behavior of the card in games and applications. With currently 879 Euros, the card is even cheaper than some (somewhat slower) GeForce RTX 3070, after all.
For the GeForce RTX 3070 Ti, NVIDIA now uses all 48 SM units (the RTX 3070 used 46), resulting in a total of 6144 CUDA cores (up from 5888). In addition to the CUDA cores, NVIDIA’s GeForce RTX 3070 Ti is of course also equipped with 48 next-generation RT cores (up from 46) (ray tracing) and 192 Tensor cores (up from 184). In addition, there is the prestigious GDDR6X memory, which, however, turns out to be quite narrow with 8 GBytes. But there will be more to write about that, too.
However, the gap between the already launched RTX 3070 and the GeForce RTX 3080 is large, so many have been dreaming of a GeForce RTX 3070 Ti with an even more stripped down GA102 until now. But now NVIDIA tries it from below and releases the GA104 completely. However, with only 2 SM more, even on paper it will probably be rather hard to really fill the gap between the two cards in the middle, even if you want to speed it up even more with the help of the faster memory. But let’s see what KFA2 can offer with a slightly higher power limit.
Optics and haptics
The card looks much simpler than many a competitor’s product, but that doesn’t have to be a disadvantage, on the contrary. RGB yes, but eye-killing it is not. The KFA2 GeForce RTX 3070 Ti SG 8GB weighs 1147 grams and is thus not much heavier than the reference card, but still offers something like a graphics card holder with RGB in the scope of delivery. It is also much longer with its stately 31.5 cm, not quite as cantilevered 10.5 cm high (installation height from PEG) and in addition 5.2 cm thick (2.5 slot design), whereby a backplate and the PCB with a total of five additional millimeters are added.
The KFA2 GeForce RTX 3070 Ti SG 8GB is powered via two standard 8-pin sockets, so everything as known and used, when a card has 310 watts (optionally up to 330 watts) power limit. We also see the vertical orientation of the cooling fins and the board reinforcement in the form of a backplate without a further frame. Three 9 cm fans (rotor blade 8.5 cm) provide the necessary fresh wind for cooling, which has been proven to be sufficient.
The slot bracket is perforated, carries 1x HDMI 2.1 and three current DP 1.4 connectors. The USB Type C port, on the other hand, is missing. More about the construction, the cooler and the assembly will follow soon.
Technology
While the base clock is specified with 1575 MHz, the boost clock is 1800 MHz (FE at 1770 MHz), which is even reached. The card relies on 8GB of GDDR6 at 16Gbps, but we’ve been over that. For the rest of the key data, please refer to the GPU-Z screenshot…
… and the tabular overview (where the values of NVIDIA’s RTX 3070 Ti FE were put in brackets).
  GeForce RTX 3070
GeForce RTX 3070 Ti
GeForce RTX 3080 GeForce RTX 3080 Ti
GPU GA104-300 GA104-400 GA102-200 GA102-225
Process node Samsung 8 nm
The Size 395.2 mm2 628.4 mm2
Transistors 17.4 billion 28 billion
CUDA Cores 5888 6144 8704
TMUs/ROPs 184/92 192/96 272 / 96 320/112
Tensor/RT 184 / 46 192/48 272 / 68 320 / 80
Base clock
1545 MHz 1575 1440 MHz 1365 MHz
Boost clock
1740 MHz 1800 (1770) MHz
1710 MHz 1665 MHz
Memory 8 GDDR6 8 GDDR6X 10 GB GDDR6X 12 GB GDDR6X
Interface 256-bit 320-bit 384-bit
Throughput 16 Gbps 19 Gbps 19 Gbps 19 Gbps
Bandwidth 448 Gbps 608.4 760 Gbps 912.4 Gbps
TGP 220 W 310 (290) W 320 W 350 W
Launch 15.10.2020 09.06.2021 17.09.2020 02.06.2021
KFA2 GeForce RTX 3070 Ti SG (1-Click OC), 8GB GDDR6X, HDMI, 3x DP (37ISM6MD4BSK)
DrWandel
91 Kommentare 75 Likes
Ich frage mich ob die achteckigen Aussparungen um die Lüfter herum zu Verwirbelungen beitragen und damit etwas mehr Geräusch erzeugen als wenn die Rahmen um die Lüfter gleichmäßig rund wären?
11,973 Kommentare 23,567 Likes
Nein, das stört nicht bis kaum, wie es auch die Frequenzanalyse zeigt. Die Lüftermodule von KFA2 erzeugen das gleiche Geräusch auch mit demontierter Abdeckung. Solange die Öffnung nicht zu klein ist, so wie bei Palit, kann man das durchaus machen. Be Quiet! setzt beim Silent Wings 3 ja auch auf ein Hexagon :)
DrWandel
Danke; wieder was gelernt. Im übrigen, um das mal zu sagen, Igor's Lab ist für mich zusammen mit PCGH (da habe ich ein Heft-Abo; bin halt ältere Generation und freue mich, mal was 'in die Hand nehmen zu können' anstatt alles am Bildschirm zu gucken) die beste und zuverlässigste Quelle für Gaming-Hardware-Tests in Deutschland. Danke und Kudos!
M
McFly_76
414 Kommentare 149 Likes
Der Abstand zwischen der Backplate und der Platine wo sich die VRMs befinden ist sehr klein und dort würde ich nachträglich ein Wärmeleitpad anbringen ( es hätte mir keine Ruhe gelassen ) 😁
Vom Preis ist die RTX 3070 Ti attraktiver als die RTX 3070 Modelle.
DrWandel
Wobei es natürlich schon gewagt ist, bei den aktuellen Mondpreisen (wenn auch nicht mehr ganz so schlimm wie noch vor Monaten) von "attraktiv" zu reden; das gilt wirklich nur im Vergleich ;-)
M
McFly_76
Ja, mehr Leistung zum gleichen Preis oder noch günstiger ist ein guter Anfang.
Richtig Attraktiv werden die Grafikkarten erst dann wenn die aktuellen Preise um 1/3 gefallen sind, nicht wahr ? ;)
grimm
3,503 Kommentare 2,532 Likes
Also die damals auslaufende 2080S gabs für nen Hunni weniger - müsste mit dieser Karte ungefähr gleichauf liegen. Also gemessen am UVP sind die Preise sicher zu hoch, Preis/Leistung wird aber besser. Ich kann die Empfehlung nachvollziehen. Für WQHD aktuell sicher eine sehr gute Wahl.
2,392 Kommentare 1,562 Likes
Für fast € 900 ist die Karte natürlich schon eine spezielle Butterbrot Schnitte 🙂
Aber ernsthaft, was ist denn da los mit NVIDIA und GDDR6X überall, auch da, wo es eigentlich auch ohne (und sparsamer) geht? Ist GDDR6 so im Preis nach oben gegangen, daß die gleiche Bestückung mit GDDR6X billiger ist, oder hat NVIDIA hier Abnahme Verpflichtungen zu Micron die erfüllt werden müssen, egal ob es eigentlich Sinn macht? Denn, wenn reguläres GDDR6 pro GB eigentlich billiger ist, wäre mir mehr RAM (12 oder 16 GB, je nachdem was mit den erhältlichen Speicher Bausteinen ginge) mit etwas weniger Bandbreite zum gleichen Preis lieber. Aber vielleicht will sich NVIDIA nicht selbst Konkurrenz machen?
GDDR6X ist aktuell besser verfügbar, da NV exklusiv.
C
Chafi9
3 Kommentare 0 Likes
Hallo IgorsLAB Familie,
ich weiß nicht genau, ob ich hier eine Frage stellen darf. Ich möchte mir einen Rechner zusammenstellen, mit dem ich hauptsächlich 3D machen möchte in Blender. Ich tendierte nach langer Überlegung zu einer RTX 3080ti, aber nun frage ich mich, ob es nicht besser wäre statt einer RTX 3080ti zwei RTX 3070ti zu nehmen. Als Basis soll ein i7 12700K dienen und 64GB RAM (DDR4 natürlich). Photoshop soll auch zum Einsatz kommen, aber ich bin absolut kein Gamer und auch kein Miner.
Falls ihr zu den zwei 3070ti ratet, was brauche ich da für ein Netzteil? 1000 oder gar 1200W?
Falls die Frage nicht hier hin gehört, bitte ich um Entschuldigung, ansonsten bedanke ich mich sehr für diese Seite (und den Youtube Kanal dazu) und wünsche allen Lesern das schönste Wochenende.
In diesem Sinne,
Gewinne, Gewinne
grimm
Auf keinen Fall zwei 3070 TI. Lieber 1 3090. Und NT ab ca. 850 Watt, besser 1000 ist okay
C
Chafi9
Hallo grimm,
vielen Dank für die Antwort. Ja ich hatte zwischen 3080ti und 3090 überlegt, aber die 3090 ist mir dann doch zu teuer im Vergleich zu dem, was sie mehr lestet als die 3080ti.
Dann denke ich, werde ich zu der 3080ti greifen mit einem 850W Netzteil. OC ist kein Thema für mich eher vielleicht etwas runter volten, um kühler, leiser zu bleiben und ein bisschen Strom sparen (:
grimm
Also zwei 3070 TI sind mittlerweile so teuer wie ne 3090, die gibt es hin und wieder für 2.000.
Ne 3080Ti läuft komplett am Limit und hat "nur" 12 GB. Wenn es um Geld geht, dann greif zur normalen 3080 mit 12 GB, das wirst du kaum merken und sparst - die liegt im 1.200€.
Wenn es um die Render-Performance geht, dann 3090.
C
Chafi9
Danke, dann gehe ich in mich und beobachte mal den Markt.
Wünsche dir ein erholsames Wochenende
Follow Igor:
