3D-Printer Cooling Reviews
Lian Li O11 Dynamic improved – Cool ideas against hotspots, hot plates and for a better airflow
What follows is a solution to a mix of a homegrown problem, weekend project, and experimentation. I've summarized the results and how to get there in this article, in case anyone else falls right into that niche. But even if not, it should still be interesting for the rest.
Problem
Any good problem solving should start with an analysis and description of the problem, so let's start with just that. My system is in an O11 Dynamic because that type of case just lends itself to the position on my desk. Not very original, the case has felt everyone, I know.
But who still remembers, I have this type of housing for a long time and also like to use it. My Inter-Tech C701 was just starting to get a little small, hence the change.
Lüfterbestückung in einem Gehäuse samt Überdruck-Konzept – Wie viele Lüfter braucht man eigentlich wo? | Kurztest
As you can see here quite well, I have configured the top and bottom fans as Intake, only the side fans act as Exhaust. Why, when other arrangements might be better for temperatures?
Simply because that's how I think it looks best. I care about the look of my system and I'm still going back and forth a lot. First custom sleeve attempts included. But now to the actual disadvantage of the fans blowing out from the side. The air heated up by the 5800X (120 watts) and RTX 3090 (370 watts) is transported to the second chamber of the case, where it affects the PSU and especially the hard drives.
And so it happens that my two 4TB HDDs do start to sweat at normal room temperature. CrystalDiskInfo throws out a warning from 50°C, by the way, as I had to find out. By the way, hard disks are designed for up to 60°C, but less won't hurt, of course.
I test my various approaches with a simulated load from MSI Afterburner in combination with CPU Burner on 8 cores.
Tim Kutzner
635 Kommentare 451 Likes
Heute mal etwas ganz Anderes :D
v
vonXanten
779 Kommentare 323 Likes
Danke für die Test, erinnert mich ein wenig an mein Optimieren an diversen Gehäusen. Allerdings mit viel weniger bling bling (aber das ist ja eh eine Geschmacksfrage).
Das es mit den 3D Druckern einfacher geworden ist solche Mods umzusetzen ist gut, aber eigentlich auch ein wenig schade, dass das die Hersteller nicht schon solche Luftleitsysteme vorsehen.
Wie gut sind die invertierten Lüfter? Oder hat Pascal einen abbekommen zum testen?
ApolloX
1,387 Kommentare 758 Likes
Ohje @Tim Kutzner da hast n kontroverses Fass aufgemacht. Warum gehen die Physik arbeiten? "Ganz einfach, weil es meiner Meinung nach so am besten aussieht." :)
Ich denk, wenn die Lüfter volle Pulle laufen ist es egal, wie wild man die anordnet, aber wenn die grad mit minimalen Drehzahlen oder teils garnicht laufen, dann sollte man nicht gegen den Effekt arbeiten, dass warme Luft nach oben steigt. Zumindest so die Theorie.
Und das seitliche Ausblasen zu den Festplatten ist dann ja auch eine direkte Folge des in meinen Augen falschen Belüftungskonzepts.
Das wäre jetzt für mich interessant, wenn du die Lüfter mal in recht niedrigen Drehzalen betreibst und dann für die Innentemperaturen wie z.B. CPU oder GPU den Vergleich zwischen oben Einblasend vs. Ausblasend vergleichst. Oder ist der physikalische Effekt so gering, dass mans getrost vergessen kann - da gibts ja viele Meinungen (wie meine eigene) aber ich hab dazu bislang keinen richtig validen Vergleich gesehen.
Der Aspekt des 3D-Drucks ist interessant, weil man das im eigenen Gehäuse ja auch immer wieder mal merkt, dass man hier und da was drucken könnte, wenn man denn einen hätte. Danke für den Einblick! - auch wenn ich jetzt aus Gründen der Soundkulisse niemals 4 zusätzliche 60er Lüfter empfehlen würde.
D
DommeP
98 Kommentare 26 Likes
Danke, finde so Basteleien immer interessant.
Bei meinem Rechner ist Optik und RGB nicht so das Thema (aka: Kein Thema) - ich bin aber am WE zufällig über Lüfter mit dem gegenteiligen Reverse-Ansatz gestolpert, die DeepCool MF120 GT. Fand ich auch sehr interessant, ich bleib aber bei den Arctic xD
Tim Kutzner
Ohne jetzt genau geforscht zu haben, sollte das bisschen thermische Konvektion durch jeden Lüfter in der Nähe übersteuert werden. Jetzt einfach mal so dahin gesagt :D
Ich glaube um das richtig testen zu müssen Bedarf es dann doch eher einem richtigen Labor, die Lüfter so weit runterzuregeln wird bei starker Hardware auch kaum möglich sein.
Beim O11D sind es ja nur 2x 60mm und die hört man wie erwähnt überhaupt nicht, auch im Idle nicht.
Casi030
10,829 Kommentare 2,046 Likes
So ein 3D Drucker macht kreativ........
Man darf aber auch nicht vergessen das das O11 für Wasserkühlung konzipiert ist so das CPU und Grafikkarte unter Wasser sind.
Auch das du den Radi so verbaust mit den Lüftern ist auch nicht gut was man an den Raumtemperatur sehen kann.
So hast natürlich einen deutlichen Überdruck im Gehäuse und da breitet sich die Wärme überall aus,auch Richtung HDDs.
Unten Rein,der Radi neben das Mainboard und die Lüfter saugen raus.Oben ziehst die Wärme mit raus bringt deutlich bessere Temperaturen fürs Gesammtsystem.
Wenn es ein 30er Radi ist hättest dann nur noch einen Rand zur Seitenwand von rund 1,7mm machen müssen um Bündig ans Seitenteil zu kommen.
Was hast für HDDs,2.5 oder 3.5?
2.5 kannst auch einfach hinten an die Schlitze Schrauben über oder unter das Netzteil,bzw mit Entkopplung sonst wird es bestimmt nervig.Wenn du dann noch auf den Rest verzichten kannst noch besser.
Wie Tief hast die Lüfterröhren gemacht,47-48mm?!
Tim Kutzner
Naja, der Unterschied je nach Lüfterkonfiguration bewegt sich ja noch im Rahmen, das habe ich ja schonmal getestet.
Ich habe 2x 4TB 3,5" HDDs hinten im Käfig drin. Die Röhren gibt es in 31.5 oder 56.5mm, ich hatte glaube ich die großen gedruckt. Radiator und Lüfter sitzen bei mir beides vorne.
K
Kobichief
666 Kommentare 199 Likes
Tolle Geschichte, ich schaue immer, dass ich einen aktiven Luftstrom frischer Luft über meine HDD's habe. Seitdem auch keine Ausfälle der HDD's mehr gehabt, was früher in irgendwelchen Bratferkelgehäusen doch recht häufig der Fall war.
Casi030
Stimmt da war was,da hatte Ich bestimmt auch was zu Nörgeln......;)
Ok die großen Platten sind natürlich was anderes,die kann man nicht so leicht irgend wo fest Schrauben.
56,5mm.....Wenn ein 25er Lüfter und ein 30er Radi nicht passen?!
Aber ja,du hast mit 120mm ja nicht die breite eines Radis der vorne an die Verriegelungsschiene vom Seitenteil dran kommt und deswegen nicht passt.
Am Handy etwas schlecht zu sehen und bin jetzt von ersten Bild aus gegangen, Radi Oben.
Aber bei einem Bild hast Radi vorne,dann Lüfter in der hinteren Kammer und dann das kurze Rohr.
Wir wäre es mit Leit"blechen" ein mal für 30er und ein mal für 45er Radis die in der hinteren Kammer sind für 240er und 360er Radis?
EDIT:
Du meinst diesen Test?!
Da hast keine Ram Temperaturen und der gleichen.......
Auch hast nur oben und unten Rein und neben dem Mainboard raus,aber nicht die Variante unten Rein ,Oben und neben dem Mainboard raus in Verbindung mit der gesammten Systemtemperatur,Mainboard, Ram,Festplatten......
Tim Kutzner
Bei dem Lüfterbestückungs-Test hatte ich die Lüfter in der vorderen Kammer, den Radiator in der hinteren Kammer, Gehäuse war ein C701
Jetzt im O11 habe ich den Radiator oben im Gehäuse. Die Konfiguration mit den invertierten Lüftern verwendet den Boden und die Seite als Intake, durch den Radiator im Deckel ist dann der Exhaust.
Naja wie dem auch sei, ich habe erstmal genug hin und her gebaut :D
Vielleicht teste ich da nochmal verschiedene Konfigs durch, wenn ich eine Custom Wakü reinhaue
I
IronAngel12
36 Kommentare 14 Likes
Sehr Interessanter Test.
Gerade das mit dem 3D Drucker finde ich gut. Jetzt wo dieses Jahr neue Grafikkarten kommen, könnte man ja so eine Lufttunnel vielleicht drucken.:)
RX480
1,568 Kommentare 718 Likes
Evtl. doch gleich ein konventionelles O11 Air nehmen, falls man sich mit Radis austoben möchte?
--> Da gänge sehr gut Seite+Boden IN und Front out, falls man doch wg. der HDD die Sorgen hat.
--> Hinten 2x 80 IN und Oben OUT (kann sehr langsam laufen)
Casi030
Also anders als im Test.
Du gehst jetzt von unten und neben dem Mainboard rein mit 6 Lüftern und ziehst die Luft über den Radi mit 3 Lüftern raus.
Durch die 6 Lüfter hast ja je nach Einstellung ein Überdruck,so das dieser hinten raus kann und in die Zweite Kammer kommt durch die Öffnungen wo du dann mit den HDD Lüftern wieder raus ziehst?!
So kann man die HDDs natürlich auch Kühlen,aktiv von Vorne und natürlich durch die Rillen in der Seite.
Wie sind dann wenn du den Test noch mal laufen lässt die Ram Temperaturen?
Ja das kann ich gut Verstehen,besonders wenn es kein Testsystem ist was mal 1-2 Wochen in der Ecke stehen kann.
ro///M3o
321 Kommentare 225 Likes
Super Artikel. Vielen Dank. Teils auch schon für den Mini umgesetzt 😁
S
Straffix
3 Kommentare 0 Likes
Hallo,
also ich hab mich extra für meine frage angemeldet bzw. Registriert
Ich bin kurz vorm explodieren 😂😂
Auf dem bild mit dem rechner Lian Li o11 sehe ich deutchlich dass das seitenfenster definitiv weiter raus steht und nicht bündig abschliesst.
Wo finde ich solche adapter/aufsätze etc???
Ich will das ich am seitenfenster das die scheibe ca 1cm weiter raus steht und mein Gehäuse von dort auch atmen kann! Bei der frage dann auch für das vordere glas ebenfalls.
Tim Kutzner
Willkommen!
Ich habe mit meinem 3D-Drucker kleine Abstandshalter gedruckt, weil es sonst mit meiner GPU etwas eng wird.
Findest du hier: https://www.thingiverse.com/thing:5100977
Funktioniert ganz okay, die Teile für den unteren Teil der Scheibe sind aber zu brüchig.
Bedenk bei diesem Mod aber, dass so Staub ins Gehäuse kommen kann. Das O11 ist eigentlich auch so offen, dass man abseits von der Thematik mit zu breiten GPUs das nicht machen muss.
S
Straffix
Ahh super, ich habe aktuell das problem das ich mit der 3070ti so hohe Temperaturen habe dass ich die fenster offen lassen muss, weil durch die hitze das System abstürzt bei spielen. Ohne fenster alles ok.
RedF
3,857 Kommentare 1,933 Likes
Wie hast du denn die lüfter eingebaut? Vieleicht lässt dir ja auch ohne Mod helfen.
S
Straffix
Ich habe unten rein, seite raus und oben 360er radiator raus..
Gestern habe ich das hintere und obere teil entfernt und konnte somit tatsächlich rund 10-15grad kühleren innbereich erreichen. Mir gehts hauptsächlich um die grafikkarten Temperatur 3070ti fe.
Ich denke das die abdeckungen zu schmale schlitze haben um die warme luft gescheit raus zu bekommen. Jetzt bin ich am überlegen ob ich die größer machen soll die schlitze.
Was eigentlich zu schade ist für das gehäuse.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
