Aircooling Cooling Reviews
NZXT T120 CPU Air Cooler Review – Off to new shores or just another tower?
Disclaimer: The following article is mostly machine translated from the original German, and the translation has not been edited or checked for errors in-depth. Thank you for understanding!
I think most people are familiar with NZXT’s AiO water coolers, the Kraken series being a popular choice among RGB enthusiasts. After expanding the product range in terms of peripherals, we’re going back to the roots today. At least in the category, because NZXT has not yet had an air cooler like the T120. In the following article, we will test whether it also cools well in addition to looking good.
NZXT Kraken Z73 All-in-One CPU-Kompaktwasserkühlung im Test – Leistungsstarke Meme-Maschine
The cooler comes in a mostly untreated brown cardboard box. The only splash of color is – of course – the company name.
Inside, the delicate slats are protected by two blocks of rigid foam during transport.
The accessories do not contain any surprises, just the usual small parts for mounting the cooler.
A nice feature, however, are the two strips of double-sided tape that hold the backplate in place. Another set of retaining clips for a second fan are also included, and the small tube of thermal paste is not labeled further.
Assembly and installation
As is so often the case, the existing bracket of the AM4 socket has to give way, but the backplate may remain. Since the pre-assembled brackets are for the current Intel socket, they first have to be exchanged for the matching parts for AMD. Then fix the cooler in place with four spacers and four screws.
The installation of the cooler is, due to the many individual parts, a bit fiddly. If you can put the computer on its side or if the mainboard has not been installed yet, the whole thing is definitely easier to handle.
Specifications
The following is an overview of the technical details, more information is then available on the Product page at the manufacturer.
Derfnam
7,517 Kommentare 2,035 Likes
Wieso sind die beiden Lüfter auf den letzten 2 Bildern unterschiedlich? Der weiße Quirl hat aussen breitere Rotorblätter als der schwarze.
E
Eribaeri
155 Kommentare 61 Likes
Der 2. Lüfter bring deswegen so viel mehr, weil die NZXT Aer-Lüfter absoluter Müll sind.
Ich hatte ein Jahr Probleme, meine 260€ teure Z63 in einem 180€ teuren H710 zu betreiben und gleichzeitig eine 3080 kühl zu halten. Ist ne Menge Asche für schlechte Thermals.
Lüfter gewechselt auf 7€ Arctics vorm Radiator (da sehe ich kein RGB) und SIEHE da... Grafikkarte läuft jetzt auf 71-72 Grad, statt auf 80-81 Grad.
Es kommt endlich Luft ins Gehäuse, mein PC ist jetzt keine Vakuumkammer mehr.
v
vonXanten
831 Kommentare 363 Likes
evtl ein anderes Designe weil der mit einer Beleuchtung daherkommt...
@Tim Kutzner macht das einen Unterschied bei der Leistung der Lüfter ob mit oder ohne RGB?
mblaster4711
58 Kommentare 29 Likes
Mit RGB ist alles besser :ROFLMAO:
NZXT = gefälliges Design, recht gute Verarbeitung, hoher Preis, aber keinen (mess)technischen Vorteil gegenüber günstigen Produkten die teilweise lediglich die Hälfte kosten.
t
tobu2000
9 Kommentare 3 Likes
Böser Schreibfehler: "Die Monate des Kühlers ist, bedingt durch die vielen Einzelteile..."
Tim Kutzner
936 Kommentare 772 Likes
der RGB-Lüfter tatsächlich eine geringere Drehzahl
Tim Kutzner
hrcn
21 Kommentare 21 Likes
Ich habe zu NZXT als Marke echt ein gespaltenes Verhältnis. Auf der einen Seite gefällt mir die minimalistische Ästhetik vieler Produkte von denen sehr, auf der anderen Seite schwankt die Qualität je nach Produkt zwischen bestenfalls mittelmäßig und relativ gut, aber auf jeden Fall ist fast alles von denen viel viel zu teuer. Kann man echt nicht guten Gewissens kaufen...
Danke aber auf jeden Fall für den Test. Es würde mich freuen, wenn ihr in Zukunft noch ein paar weitere optisch schlichte Towerkühler testen könntet, konkret denke ich gerade an den Deepcool AK500 (von dem kommt nächstes Jahr noch eine schwarze Variante raus) und den Alpenföhn Dolomit Premium - der sieht für mich auch ziemlich vielversprechend aus als Mittelklassekühler, es gibt aber einfach keine vernünftigen Tests von dem Ding, zumindest nicht von Quellen den ich ausreichend vertraue :(
Tronado
4,555 Kommentare 2,492 Likes
Die Kühler im Vergleich schneiden bei 60% Drehzahl alle ungefähr gleich ab. Ich muss also, als unbedarfter Interessent, erstmal Tests auf anderen Seiten lesen, um festzustellen, dass die Kühler bei, sagen wir, 100W oder 120W Leistung meiner stärkeren CPU, überhaupt nicht gleich abschneiden.
J
Jolly91
56 Kommentare 5 Likes
Den gibts sogar mit RGB, das steigert die Effizienz nochmal drastisch.
Sowas sollte verboten werden.
Asghan
31 Kommentare 16 Likes
Könnt Ihr da nicht mal vom Ryzen 5 3600 weggehen und CPUs mit etwas mehr Verbauch testen?
Asghan
Tim Kutzner
Wechsel auf 3950X (bis bisher 200 Watt) kommt, Referenzwerte habe ich schon gemacht
Erneut alles zu testen ist aber einfach nicht kurzfristig machbar, wird auf neue Werte von den relevantesten Kühlern hinauslaufen und ab da dann nur noch mit dem R9 weiter
Antwort 4 Likes
Tronado
Ich sende dir gerne Kühler von Deepcool zu, damit du auch mal richtig
gute Kühler testen kannst, nicht immer die Mittelklasse. :)
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
