We already tested this processor a while ago, and today we have another comparable system from a different manufacturer. So let’s take a look to see if not only the availability and price could be improved compared to the EQ12.
If you want to catch up on the article, you can do so here:
This mini PC is also delivered in a box that corresponds to Geekom’s typical design. This means large lettering on the front with the product name, a small teaser image with the connections on the side and a rough description of the key data on the back.
For better protection during transportation, the system comes in a custom-fit foam case.
The accessories include a 45 watt XinSPower A481-1902360Epower supply unit and a 1.5 meter HDMI cable.
The combined VESA and wall bracket with screws is also included.
Specifications
Before we look at the Mini-PC in detail, here are the technical details and a link to the manufacturer’s product page.
[the_ad_group id=”7834″]
10 Antworten
