Aktivlautsprecher Audio Audio/Peripherals Bluetooth Reviews
Edifier QD35 Review – Bluetooth monoculture in styled up and spacy
And no, that’s not some oversized underwater camera; it’s genuinely a real Bluetooth speaker. This beauty is called the Edifier QD35, and its street price is now 120 Euros (RRP 170 Euros). You really have to come up with such a design, and this piece was so distinctively different that I just couldn’t resist, price notwithstanding. Especially since I grabbed it from the distributor this time. You probably know the moment when you wonder what a designer must have been thinking to come up with such unique ideas?
And I’m a bit late to the party, as the usual sites have already covered it. I’m not an influencer, so naturally, the launch missed me. And since today is Monday, let’s not take things too seriously. But, be that as it may, the thing suddenly appeared here (intentionally on my part) and wanted to be taken out of its box and then put back in. An oversized Bluetooth mono-speaker as an LED-illuminated boom-box in galactic design? Why not? In this interpretation, it’s almost like a wildly flashing unicorn. So let’s dive in!
The box alone is cleverly designed. If you sneak past it on the shelf, the first thing you see is something with 35 watts. That’s even true, but completely different than you think at first. Yes, that’s how honest marketing works, just thought around three corners. But I’ll come back to that in a moment. First, of course, I want to know what is really hidden in this miracle box. So I quickly wash and degrease my hands once again, because you never know what you’re going to get…
Scope of delivery
And what do I find in the box? Of course, the speaker in ecologically pressed eggshell style carton, a quick start sheet, the manual, and a microfiber cloth to polish my grease residues on the body. In addition, there are power cables, a USB cable for the Hi-Res connection to the PC and a 3.5 mm jack cable for feeding from analog oldschool sources. These are also still available. The Hi-Res audio label could have been left out. After all, bats are not included.
Above all, the cloth (or should I better write THE cloth?) is the most important friend in the life of such a Q35. But more about that in a moment, because it makes less prints for the better impression.
Unboxing
Well, just unbox and be amazed. Only, what do you write about such a speaker now? Quite simple: with the Edifier QD35, we simply can’t avoid chatting about its “clearly unique” design. A matter of taste, sure, but this mix of “look-through” industrial look, fingerprint-eating glossy look, and disco lighting might make some think more of a UFO. Is it a bird? Is it an airplane? No, it’s … a loudspeaker! And that even in mono! The urge for acoustic monosyllabicity is more than made up for by the alien design. At least, it does if you stand on it.
Speaking of standing on it, the speaker weighs 2.64 kilos (without fingerprints) and looks just like a take-away roar cube with its approximately 28 x 17 x 14 cm, but it stands bombproof on nice soft rubber feet. And it unfortunately doesn’t have an integrated battery and thus always needs a power outlet. At the bottom left is a display, the speaker’s smartwatch, so to speak! It shows the time, but only when you say it with the app. And without juice? It lasts up to 7 days, after that it gets time-starved and needs a reminder (see mains connection).
The Edifier’s see-through face, with no makeup at all (i.e. grille or cover), could be the main attraction for all the little finger artists out there, especially with the colorful light show behind it. The top screams “Here I am!” with prominent Edifier branding that’s probably there to make sure you don’t forget what you’re looking at. The dark look is practically impractical, as you can really see every tap of your finger – unless you’re eating while listening to music with gloves on. But that’s what THE wipe is for. Wipe and away.
On the right, we then have a control trinity: a power button that acts as an input source changer in its spare time; a volume control that also plays along with play and pause, and acts as a sound DJ on the side. But the star of the show? The RGB controller! That’s where the party really gets started. It not only changes the brightness, but also the lighting effects. Who needs a disco ball? We’ve got the Edi… And the app? It helps out, too. The quality? Top. The buttons? Firm and accurate. Nothing wobbles!
Oh, the app and connectivity will be covered in the next chapter, so don’t get confused. I’ll also write something about the charging in a moment, so have a quick look at the data sheet and let’s continue!
big-maec
546 Kommentare 300 Likes
Jetzt müsste man nur wissen, ob 2 Stück in Stereo trällern können.
9,196 Kommentare 16,059 Likes
Nein, können sie nicht. Das hätte ich nämlich erwähnt ;) Es wäre bei Netzkabelgenundenen auch reichlich sinnlos. Für 200 bis 300 Euro bekommst Du klanglich bessere Stereo-Lautsprecher.
ssj3rd
183 Kommentare 113 Likes
0815 Bluetooth Lautsprecher Test? 💤 😴
Warum nicht? Das Teil is schön spacig und ich denke mal nicht, dass der Text 0815 ist. Ich habe mir extra Mühe gegeben. Mal gelingt es besser und mal nicht. :D Liest es sich so dröge?
Schreib Du mal jeden Tag Laboranalysen für die lesende Masse und gehe gleichzeitig arbeiten... Nicht vergessen, ihr lest hier kostenlos :)
Antwort 10 Likes
echolot
433 Kommentare 265 Likes
Ich glaube mehr kann man beim besten Willen in einem Artikel nicht rausholen und auch nicht verlangen. Dafür mein respekt... :D
Ich kann ja auch mal das Telefonbuch testen. Jede Seite einzeln und mit Screenshot :D
Starfox555
209 Kommentare 73 Likes
🙈 kommt diese Idee aufgrund von zu viel geschnüffeltem Blei und Arsen?
Edifier QD35 ein nettes Gimmick für Kindergeburtstage in Netzsteckerreichweite 🦄
echolot
947 Kommentare 420 Likes
Mit dem ganzen LED Firlefanz sowieso nicht ganz mein Ding ; was aber schade ist, daß es keine Webradio Funktion hat. Die sind zwar etwas aus der Mode gekommen, aber dafür wäre so ein Teil mit brauchbarem Mono Lautsprecher tatsächlich geeignet.
Also Edifier, wenn ihr Euch die RGB Mäusedisko spart , und die gespeicherten Kosten dafür für WiFi und Webradio verwenden würdet, hättet ihr zumindest einen Kunden dafür - mich. Und, transparent muss es dann auch nicht sein.
Starfox555
Als Hörbuch gn8 Geschichte
C
ChaosKopp
351 Kommentare 329 Likes
Irgendwie weder Fisch noch Fleisch.
Klanglich eher naja, optisch sehr eigenständig, aber für unterwegs taugt es auch nicht.
Keine Ahnung, wozu das Produkt gut ist, aber es ist zumindest anders.
LEIV
1,488 Kommentare 553 Likes
Hab sowas ähnliches (von Teufel) um die Küche zu beschallen während ich koche, ist schon ein kleiner Gamechanger mit Musik 😂
Saschman73
326 Kommentare 170 Likes
Mich begleitet seit Jahren die Megaboom 3 in den Garten oder auf die Terrasse.
Bei einer Runde Disc Golf findet die Box auch immer einen Platz im Getränkehalter vom Rucksack oder Trolly!
Und wenns mal etwas lauter sein muss, dann nehmen 1-2 Freunde ihre Boom mit und die Dinger laufen im PARTYUP Modus. 🤫
Es gibt YouTube Kanäle, für die das eine Bereicherung wäre 😁
F
Furda
625 Kommentare 356 Likes
Frischer und amüsanter Artikel, danke! Allein das Lesen war es schon wert, für mich war der Text alles andere als 0815.
Ist doch ein cooles Ding, mal was anderes und hat alles Nötige drin und dran.
Dass es keinen Akku hat, dürfte es etwas länger vor dem Weg in den Müll bewahren, und ist so letztlich auch positiv.
Edit : RGB kann man (hoffentlich) aus machen, wenns nicht gewünscht ist... (?)
Helligkeit geht auch :)
C
ChaosKopp
Nö, das halte ich für ausgeschlossen.
Die Berliner machen das dezent in schwarz und meine Erfahrungen mit der Marke sagen mir, dass es für 120 Schleifen eng wird. Und der Klang zu mehr Feinheiten tendiert.
Das ist eher Teufel auf LSD.
Die Berliner sind leider keine Berliner mehr. Das, was man früher mal als eigenen Maßstab an sich selbst hatte, ist mittlerweile im fernöstlichen Massenprodukt grandios versickert. Kann man leider nicht mehr kaufen. Zu teuer fürs Gebotene, leider. Und mit dem Service hatte ich nur Stress. Ich bin wirklich geheilt.
Follow Igor:
