Audio/Peripherals Keyboard Reviews
AKKO Gear 5075B 75% Wireless Keyboard Review – Boring GMMK Pro clone or cheap custom keyboard with ISO-DE layout?
When the manufacturer AKKO Gear approached me and offered me the latest movement in ISO-DE layout, I was skeptical at first. A Chinese Glorious GMMK Pro, right? After taking a closer look at the specs, I agreed to the test after all. What the 5075B can do, you can read in the test!
In the past, we didn’t always have good experiences when a Chinese manufacturer offered us their latest creations. Yes, there were always highlights like Soundpeats, which we had never heard of, but which offer decent products for little money. Of course, there are also black sheep and blenders, which we here at Igor’s LAB also like to let run up in public. But if you’re already prepared for an official review, I’m afraid I have to disappoint you.
After initial skepticism, the keyboard actually turned out to be a very decent input device and even offers some custom features that are often missed by our readers on many keyboards (including much more expensive mainstream models). Terms like gasket mounted and PBT keycaps are absolutely familiar to the custom scene, but most “normals” have usually lost interest in such topics long ago. I myself am still new to the wondrous world of custom keyboards and I am already dreading the moment when the spark will finally fly.
Because custom keyboards are one thing in any case: expensive. Here times 30€ for a cable, there times 80€ for a set of keycaps and look, there are also carrier plates from other material and differently colored frames – a vicious circle and not seldom that such a finished keyboard devours also times 500€ and more in the end. Fortunately, such custom boards are usually in a smaller form factor (TKL or smaller), which is why they have not yet been able to arouse my interest. Thanks to arrow keys and a real DE layout with a decent Enter key, the 5075B can almost be used in productive use without any problems, but I don’t want to get too far ahead of myself and free the device from its packaging first.
Unboxing
The black and white packaging is quite plain, but somehow it is also an eye-catcher.
The back is mostly in Chinese, but at least you can guess the DE layout and see which switches are installed.
A black cardboard box with a reflective logo is hidden under the slider.
Meanwhile, everyone goes the same way with the type of packaging: The keyboard is wrapped in a cushioning foil and provided with a dust cover. I don’t recall ever putting this transparent cover on my keyboard when not in use, and think you might as well not bother with this plastic waste.
Here’s the thing! Quite plain in white, no frills – an input device for adults?!
Nothing but white ABS plastic on the back, too. Soft rubber feet with a very good grip are attached to all four corners, and we’ll get to the folding feet and other elements right away.
For the toggle switch, 2-way would probably have been enough, since it is actually only possible to switch between the shortcuts for MAC OS and Windows. How the center position differs from the “Win” position is beyond me.
The 2.4 GHz USB receiver is also directly on board.
The rear feet fold out in two stages. Sorry for the dirt, the pictures were corrupted on the SD card and had to be reshot after a few hours of use.
There are discreet light strips on the sides, and of course the complete lighting can also be completely deactivated.
At the rear we still find the USB-C port for lag-free connection and for charging the permanently installed 3000mAh battery. The cable’s fit is okay, but not bombproof either.
The PBT double-shot keycaps are a bit flatter than the regular Cherry MX keycaps, but the quality is very good.
Keycaps removed:
The rotary knob on the upper right has an aluminum casing and is used to regulate the volume as standard. However, pressing the switch does not mute the system – as I had expected – but changes the functionality of the switch, which then allows the brightness of the lighting to be changed instead of the volume.
As standard, the provided model is equipped with the linear Akko Creamy Yellow Switches.
The board is hot-swappable, so the switches can be changed even during operation. All 3- and 5-pin switches fit inside.
The carrier plate is made of plastic and “gasket-mounted”, but I’ll talk about that later. The LEDs are “south-facing”, which I guess makes them compatible with more switches. For the illumination of translucent keycaps maybe not quite ideal, since most keycaps I’ve come across so far are geared to “north-facing” LEDs and the illumination of the letters on the Akko is then not particularly bright. Also, depending on the switches used, the LEDs don’t glow a strong blue, but rather a cold white. But I’ll get to that later, too.
On the other hand, the “stabilizers” for the large keys are very well done. No matter where you press the large space bar, it always moves smoothly and evenly.
However, the stabilizers are allegedly not lubricated ex-works.
Accessories are also included. Keycap and switch pullers, replacement keys (!), a USB-C cable, some silicone mounts for the gasket mounting system, and (a small dig at the competition) a whole bunch of alternative keys that are also PBT double-shot and not cheap printed keys.
For comparison, Akko also packed a complete set of the alternatively available tactile Creamy Blue Switches, which we will of course install and test later.
2,409 Kommentare 1,577 Likes
Zunächst einmal Danke für den Test! @Akko Gear: Wenn's jetzt auch noch eine Version im Vollformat (100% ) gäben würde, wäre ich noch mehr daran interessiert.
Und, eine Vermutung was die Mittelposition des Schalters zwischen Win und Mac soll: Vielleicht ist die auch für zB Linux Benutzer gedacht? Die soll's ja auch noch geben 😀, und die brauchen auch ein Keyboard ⌨️.
Megaone
1,920 Kommentare 1,836 Likes
Erstmal Danke für den ausführlichen Test.
Unabhängig davon bin ich vielleicht zu dämlich für diese Welt. Aber ein paar Sachen muss man mir mal erklären. Wieso kaufe ich eine vermeintlich Kabellose Tastatatur die ich spätestens nach 7 Stunden mit einem Kabel am PC verbinden muss, um Sie aufzuladen? Wieso wird ein fest verbauter Akku installiert, den mindestens 90% der Bevölkerung eh nicht wechseln können wird?
Was bedeutet, das das Ding irgendwann kaputt und nicht mehr benutzbar wird. Was wiederum bedeutet das ich nach einiger Zeit, früher oder später ( Bei 7 Stunden Akkulaufzeit reden wir meist über tägliches laden, das heist eher früher) für sehr viel Geld eine kabellose Tastataur erworben habe, die sich nur noch mit Kabel nutzen läst?
Wieviel Ladezyklen hat der AKKU eigentlich. Besonders wertig scheint er ja nicht zu sein.
Über all das könnte man ja dann noch hinweg sehen, wenn das Risiko des auslaufendes Akkus nicht wäre.
Ich bin wahrlich kein Grüner, noch ein Ökö oder sonst irgendwas. Ich lass mich nur nicht gern zum Narren machen. Für mich ist das ein sehr teures Produkt mit geplanter obsolenz.
Nur weil andere auch so was produzieren und noch teurer vermarkten, relativiert sich das nicht. Und wieso solche Produkte regelmäßig einen Award, bekommen versteh ich auch nicht. Auf einem Planeten mit Überbevölkerung, der in Plastikmüll erstickt mit sehr beschränktem Resourcen sowas auch noch Werbewirksam auszuzeichen ist für mich nicht nachvollziehbar.
Und "günstig" wär mal ganz was anderes. Vielleicht im direkten Vergleich zu diversen Apothekenanbietern, aber ich möchte nicht wissen, zu welchem einstelligen Dollarbetrag sowas von einem chinesichen Band fällt.
Awards müsste es genau genommen meiner Meinung nach nur für langlebige, einfach zu wartenden sowie preiswert zu reparierende Produkte geben. Wenn schon Akku, dann zwingend wechselbar.
Und die ganzen Hersteller des festverbauten Akkus gehören Imho vom Hof gejagt. Das passiert definitiv ohne jede Not und ausschließlich aus Raffgier. Die Erklärungen der Hersteller diesbezüglich sind Comedy pur.
Was nützt mir denn weniger Verpackungsmüll wenn ich das Produkt häufiger ersetzen muss?
Aber das ist nur meine Meinung.
Dennoch kann man es ja auch mal so sehen.
Ansonsten allen Beteiligten und Interessierten eine guten Start in die Woche.
S
SpotNic
1,342 Kommentare 606 Likes
Warum wirds so produziert und verkauft? weils gekauft wird... Wirtschaftlichkeit richtet sich nicht nur nach Ressourcenverbrauch, daher verstehe ich so eine Argumentation nicht.
Kann man sicherlich negativ bewerten und für sich dann so handhaben, ändert an den Tatsachen leider recht wenig.
Was die Bewertung für die Awards angeht gehe ich ein Stück weit mit, dann dürfte aber ziemlich viel keinen Award bekommen :D
Megaone
Sehe ich anders. Du wirsd defakto zum Kauf gezwungen, weil alle aus Gewinnsucht nur noch so einen Müll produzieren. Ich kann so gut wie nichts, was Akkubetrieben ist, bis auf diverse Taschenlampen, noch mit Wechselakku erwerben.
Wirtschaftlichkeit sollte sich zwingend am Ressourcenverbrauch orientieren. Alles andere ist im Bezug auf die, die nach uns kommen nicht nur asozial sondern auch im höchsten höchsten Maße verwerflich.
Nur weil man es mit einer kontinuierrlich zunehmend verblödenden und offenkundig, dank Marketingabteilungen und Verkaufspsyschologen, leicht manipulierbaren Weltbevölkerung zu hat, muss man solche Dinge nicht produzieren.
Aber da nahezu jeder zu glauben scheint in der Hölle stünde ein EC - Automat für den diabolischen Ablasshandel, raffen alle, was zu raffen ist, koste es was es wolle.
Das wird sich zwar als Irrtum herausstellen, auf sowas kommen eh nur die Stellverteter Gottes auf Erden. Aber sei es drum.
Die verstehen unter Wirtschaftlichkeit auch nur Gewinnmaximierung.
Das wiederum ist die Frage. Würde man den Verbraucher entsprechen sensibilisieren, die Politik mobilisieren und die Produzenten kritisieren, wäre ja deren "Wirtschaftlichkeit" in Gefahr.
Aber du hast sicher Recht. Da Bedarf es deutlich mehr als einer Stimme. ;)
Umso dringlicher genau das Spielchen nicht mehr mit zu spielen. Vielleicht würden dann ja mal zur Abwechslung Dinge produziert, die im Sinne der Nachhaltigkeit einen Award auch verdienen würden.
ipat66
1,615 Kommentare 1,747 Likes
Danke Alex für den ausführlichen Überblick dieser Tastatur.
Bezüglich des Awards,finde ich auch,dass es 3,5 Punkte getan hätten.
Wo,wenn nicht bei Igor,sollten strengere Bewertungen stattfinden?
Fest verbaute Akkus sind eigentlich durchaus ein Grund, bis zu einem Punkt Abzug zuerhalten.
Es kommt dann vielleicht darauf an,ob der fest verbaute Akku relativ leicht auszuwechseln ist ( - 0,5 ) oder sehr schwer auszutauschen ist ( - 1 ) .
Wenn von den Reviews zu wenig Druck auf die Hersteller ausgeübt wird, kann auch kein Umdenken bezüglich solcher Details stattfinden.
Es muss doch möglich sein in diesen Peripherie-Geräten ein Fach mit austauschbaren Akkus einzurichten,ohne die Kosten zu erhöhen.
Auch wenn sich viele Verbraucher diese Problematik nicht erschließt, sollte doch der Druck auf die Hersteller erhöht werden.
Die Natur wird es uns danken... :)
Ghoster52
1,646 Kommentare 1,330 Likes
Danke für den Test! (y)
Akku-Laufzeit wurde bereits moniert, aber bei fest verbaut würde ich noch eine Grenze ziehen zwischen
fest verlötet und mit Steckverbindung, diese kleinen 3000mA (Polymer) Akkus gibt es auch oft mit (T oder Iso) Stecker. ;)
Beste Beispiel sind hier meine schon fast Retro MP3 Spieler iRiver H320 Akku fest verbaut aber mit Stecker,
Sie sind jederzeit tauschbar und der xDuoo X3 II (4-6 Schrauben & der Akku ist zugänglich)
Wer sich für ein Custom-Tastatur entscheidet, der kann auch (meistens) mit einem Schraubendreher umgehen... :cool:
Megaone
Joo, wenn das so einfach geht und auch in der Bedienungsanleitung ausführlich erläutert wird, ist das sicher OK.
Leider hab ich in fast 61 Jahren sowas noch nie gesehen? Weil, dann könnte man ja auch gleich einen Wechselakku einbauen.
In der Regel ist sowas eine Art Intellektueller Hürdenlauf aus Internetrecherche, Werkzeug organisieren und Ersatzsteckakku kaufen. Ein Sportart, an der nicht jeder Teilnehmen kann oder will.
Sowas ging auch deutlich einfacher.
Ich meine ernsthaft. Selbst die Autoindustrie, die nicht umhin kommt, in Ihren Fernbedienungen wechselbare Batterien einzubauen, entwickelt sich zunehmend zum Märchenonkel.
Mein Mazdahändler hat mir erzählt, das Akkus mit der FB nicht funktionieren würden und der Wechsel der 70 Cent Batterie 25 Euro kostet, weil ja der Schlüssel wieder angelernt werden muss.
Merkwürdig nur, das mir beides nie aufgefallen ist.
Fakt ist, das man überall versucht den Kunden so schnell über den Tisch zu ziehen, das man die dabei entstehende Reibungshitze für Nestwärme hält.
Ghoster52
Wechsel-Systeme sind wünschenswert keine Frage... Das unterschreibe ich auch sofort, aber
im Patent- und Lizenzdschungel kaum machbar. Beste Beispiel hierfür ist eine Einigung auf USB-C beim Smartphone.
Wie viel Jahre hat das gedauert, kein Hersteller wollte es... :poop:
Klein und flache Akkus designen sich am Reißbrett eben leichter.
Megaone
Das mag sein, aber Standardakkus können ohne jeder Patenrechtsverletzung eingebaut werden. Das halte ich für eine der vielen industriellen Nebelkerzen. Es gab mal Zeiten, lange ist es her, da gab es Kopfhörer (ja wirklich) Rasierer, Zahnbürsten, Handys, MP 3 Player, Haarschneider etc. die alle mit wechselbaren Akkus ausgestattet waren.
Die aktuellen Produkte wären nahezu unverkäuflich gewesen. Dann war es den Kunden plötzlich egal, weil man sowieso alle 2 Jahre ein neues Handy wollte und für die schlauen Längernutzer gab es ja Internet mit Tauschanleitungen. Dann ist Branche um Branche nachgezogen und man hat langsam aber stetig den Akkuwechsel erschwert. Mittlerweile gibt es Produkte, die man zwingend zerstört, beim Versuch als Laie den Akku zu wechseln.
Ich bin mir sicher, das, wenn heute die festinstallierten Akkus verboten würde, die Produktion morgen umgestellt wäre.
Man müsste es halt nur wollen.
Das (Akku verlötet oder mit Steckverbindung) ist in der Tat eine wichtige Frage. @Alexander Brose : hattest Du eine Chance, Dir das anzuschauen? Wenn ja, bitte den Artikel ergänzen.
Wie von @Ghoster52 geschrieben: wenn ich den Akku mit einem Schraubendreher selbst austauschen kann - kein großes Problem. Verlötet und mit Epoxy im Gehäuse verklebt - richtig unschön. Dann würde ich @ipat66 zustimmen , und dafür auch einen halben oder ganzen Punkt abziehen.
Abschließend: Ich weiß daß NiMH Batterien in Standardgrößen (AA oder AAA) sehr aus der Mode gekommen sind, aber gerade für ein derartiges Keyboard wäre der Betrieb mit 3 oder 4 AA oder AAA NiMH Batterien ideal. Ein Keyboard muss ja nicht super leicht und kompakt sein. Und solche Batterien kann ich auch problemlos ersetzen, wenn sie die Ladung nicht mehr halten.
Auch bei Smartphones geht mir das "fest verbaute Akkus" sehr gegen den Strich! Leider wird man schon regelrecht abgestraft (hoher Preis und weniger gute SoC, Kamera usw), wenn man trotzdem eins kaufen will.
Das Argument mit "damits wasserdicht ist" das gerne gebracht wird ist schlicht und ergreifend eine Lüge. Zum Beispiel gibt's von Samsung (einer der ansonsten großen Sünder in dem Bereich) auch ein Smartphone mit okay SoC (Kamera ist nicht so toll) das sowohl Wechselakku als auch IP 68 hat, nämlich das XCover6 Pro. Kann auch 5G. Geht also, aber man (Hersteller ) will halt nicht so richtig.
Megaone
Nee, so kann man halt noch gut funktionierende Produkte aus dem Markt nehmen und neue verkaufen. Ich selber habe noch ein altes Huawei P10 lite, welches ich als Musikplayer missbrauche. Da ich es extrem selten nutze und den Akku Pflege, funktioniert es noch. Wäre für viele noch ein akzeptables Produkt. Zum telefonieren und ein wenig surfen absolut Top.
Den Schmarrn mit der Wasserdichtigkeit haben mir die Herren von Braun und Phillips im bezug auf Ihre Rasierer und Zahnbürsten auch erzählt.
Reine Schutzbehauptungen, damit die Kundschaft nicht auf die Barrikaden geht. Im Moment geht es uns einfach zu gut, so das wir uns diese Wegwerfmantalität noch leisten können. Aber keine Sorge, das wird sich in absehbarer Zeit für Viele ändern.
Mal schauen, wer sich das denn noch alles Leisten will.
Aber wir schweifen ab. Bleiben wir bei Tastaturen. Die wenigen, die Kabellos sind und bei mir rumfliegen, haben Wechselakkus und fertig.
Nagah
131 Kommentare 101 Likes
Ich kenne dieses Modell von Akko nicht.
Aber Akko ist zumindest kein neuer Player im Tastatur-Game und bei anderen Akko Modellen, die ich offen hatte (was kein Hexenwerk ist) war der Akku ein leicht zu organisierender "Standard-Flachakku" mit einem Stecker.
Ergo, tauschbar mit der einzigen Hürde sich anhand der Beschriftung des alten Stromspeichers, einen korrekten Neuen zu organisieren.
Geht sicher schöner, ist aber kein Grund für den Verriss, der sich hier ergießt.
@Alexander Brose :
Wenn das mit dem Akku auch hier so ist, kannst Du das noch einfügen? Macht durchaus einen Unterschied für die Einschätzung. Danke!
ipat66
Ich denke nicht,dass es uns hier um Bashing geht...
Es ist einfach der Stein des Anstoßes um etwas zum Besseren zu verändern.
Fest verbaute sind für den Großteil der User geplante Obsoleszenz.
Ein eigentlich noch funktionstüchtiges Gerät, landet auf dem Müll !
Das geht einfach besser, und das sollte man doch auch ansprechen dürfen.
Edit: Diese Diskussion hätte auch schon beim letzten Test der Corsair Maus losgehen können...
Wo wenn nicht hier auf Igor's Seiten, sollten solche Aspekte besprochen werden ?
Ich sehe da auch weniger Kritik an Alex und Kollegen, an dieser spezifischen Tastatur, sondern allgemein an die Qualität und den Ansprüchen zukünftiger Hardware.
S
SpotNic
Man zwingt dich zum kauf? Mich zwingt keiner, was mir nicht gefällt kauf ich nicht - fertig.
Sollte, muss usw. über was diskutieren wir hier? Gemacht wird das was Geld bringt und nicht einen goldenen Platz im Himmel - irgendwann.
öhm doch, wenn man etwas verdienen will macht man genau das ;) Kauf es halt nicht, wenn es nicht in dein Weltbild passt. Mit Moral kommst du in wirtschaftlichen Bereichen nicht weit.
Im Gegenzug bringt dir ein Ablasshandel wie er derzeit in vielen Bereichen vollzogen wird eben auch nichts.
Nur um das klarzustellen, meine persönliche Sicht auf solche Produkte tut hier garnix zu Sache, nur die Debatte hat kein Ziel, die müsstest du mit solchen Herstellern führen und die werden dich auslachen. So läufts halt nicht.
Sehe ich als Kampf gegen Windmühlen, davon abgesehen, dass wir da Global eh keine Rolle spielen. Dafür ist das Leben zu kurz und am Ende landest du beim Bildungssystem. Wird schwer politisch. Aber ja, da bin ich bei dir. der Verbraucher muss das verstehen.
Was Tauschbare Akkus angeht bin ich da sehr zwiegespalten. Technisch ist alles möglich, aber es kostet, in der Herstellung, im Vertrieb und im Support und das zahlt der Kunde. Anhand meiner eigenen Erfahrungen bin ich nicht bereit diese mehrkosten zu tragen nur weil ein kleiner Bruchteil die Geräte solange nutzt um überhaupt einen Akkutausch zu brauchen. Das ist aber nur meine persönliche Sicht aber ich denke ich stehe da nicht alleine mit da.
Ich kann aber auch meine Griffel bedienen und tausch halt auch fest verbaute wenn es denn nötig ist (sehr selten). Von daher halte ich die Debatte mehr für eine Nebelkerze als die "Ausreden" der Hersteller. Das Umweltschutzargument erscheint mir sehr oft einfach nur vorgeschoben und Heuchlerisch, man könnte noch eine Stufe früher ansetzen und sich selbst hinterfragen, ob man dieses und Jenes Spielzeug unbedingt braucht, ganz besonders in solchen Tech-Foren wie hier ;) das setzt aber eine Debatte mit sich selbst voraus... wollen auch die wenigsten führen.
ipat66
Ein leeres Akkufach für zwei AA-Akkus ist sicherlich preiswerter, als ein fest verbauter Akku.
Nagah
Klar, darf man das. Und das muss auch angesprochen werden.
Aber oben klingt das eben so, als hätte die Akko eben einen solchen fest verbauten Akku, was aber bis jetzt gar niemand weiß.
Megaone
Ich bin prinzipiell bei all deinen Argumenten sogar bei dir. Im Umkehrschluss hieße das aber die Klappe halten, alles zu fressen was man dir hinhält und nichts und niemand zu kritisieren. (Übrigens auch so ein "Nebenprodukt" der political Korrektness")
Aber sieh dich um, wohin uns genau das gebracht hat.
Wenn es das ist was wir wollen.
So what.
Follow Igor:
