Equipment and Lab Modding Practice Reviews
TwoTrees 450 CNC milling machine in test – Fresh wind for the DIY community?
In today’s test I present my first steps in the CNC machine world. By the way, the TwoTrees 450 that I would like to present today before I use it for my projects comes from Geekbuying, because I have not found it in any German store so far and in the end my curiosity was much bigger than my mistrust. The TwoTrees 450 from today’s project is available from Geekbuying starting at 421.64 Euros in the standard version with an 80W spindle. With a 500W spindle it is also on sale, but not yet available from the aforementioned store. But even that wouldn’t be a hindrance, so you’ll just have to keep looking. The work surface is 460mm by 460mm, which is perfectly adequate for my purposes and also big enough, because I wanted something bigger after all, but which would still fit in the workshop without having to pull in my belly and relocate Grandma’s preserving jars.
Just why are we showing a niche CNC router on Igor’sLab right now? The answer is simple: because there have been requests, and I’ve done a lot of custom builds in the past where I’ve occasionally used 3D-printed parts and had to have CNC work done by third parties. However, the world of CNC works essentially the same way, as we use G-codes or coordinates here as well.
My plan is to mill my own cases or distro plates in the future. So I think my first attempt with CNC milling machines fits perfectly on this page. CNC technology for the DYI sector is not that expensive anymore, so maybe one or the other reader is just looking for an impulse to get creative and productive himself.
Scope of delivery and quality
TwoTrees, or rather Geekbuying, ships the TwoTrees 450 in a plain brown cardboard box, on which it is initially not apparent from the outside what is inside. If you are expecting glossy high-gloss pictures from me today, you will unfortunately be disappointed, because today there is pure and unadorned workshop romance, spiced with some dust and little spiders as curious observers. You’ll have to go through that now, as I had to.
After opening, we see the well-protected parts, which are safely bedded in foam and protected from shocks.
All parts are also additionally labeled and carefully sorted to make them easy to find during later assembly.
Tools are also included, such as an Allen wrench, a brush, a file, a USB cable, a USB stick with Micro SD, an engraving graver, a grooving cutter, and a 3mm two-flute cutter. It’s especially commendable that TwoTrees even includes safety glasses. It’s important to note that this is a milling machine where there is a risk of injury, not a toy.
TwoTrees uses only aluminum for their TwoTrees 450, which in my estimation provides a very good fit. Nevertheless, I recommend using additional tools such as an angle to check when assembling. Because if you work precisely during assembly, you will also achieve a precise result in the end.
For a quick overview, here are the technical data, and then we’ll start assembling:
Andy197
198 Kommentare 99 Likes
Ich sehe den Einsatz der 80W Spindel eher beim gravieren. Wirklich fräsen Stelle ich mir schwer vor. Da wird wohl doch die 500w erforderlich sein.
Aber das ist immer eine Sache des käufers, was er braucht.
echolot
1,309 Kommentare 1,057 Likes
Schön zusammengestellt. Hab mal geschaut was es kostet. Nicht schlecht für den Hobbyfräser. Freu mich auf erste verwertbare Ergebnisse.
big-maec
1,030 Kommentare 611 Likes
Hi @Pascal TM-Custom/Igorslab
die hast mir mit deinem Beitrag mehr geholfen als dir bewusst ist. War mal neugierig und habe Estlcam ausprobiert, da ich noch ein Programm für die Isel CPM-4030 CNC Fräse gesucht habe, mit der ich zurzeit herumspielen darf. Mit Estlcam habe ich ein Programm gefunden was endlich das Isel ncp unterstützt, hierfür ein dickes Danke.👍
Pascal TM-Custom
1,100 Kommentare 1,313 Likes
für Acryl oder Holz reicht die Spindel.
Man muss dann eben etwas mit Vorschub spielen und dem ganzen.
Aber ich werde Upgrade machen auf eine 2,2kw Spindel mit er16 Spannzange und Frequenzumrichter
Pascal TM-Custom
Kleine Info heute Morgen hat mir Geekbuying geschrieben und euch einen Coupon Code geschenkt für die Community.
mit dem Code NNNDETTC bekommt ihr die TTC450 anstatt für 421€ jetzt für 349€
ES IST KEIN Affiliate Code nur nochmal für die Transparenz.
Ihnen hat nur das Review gut gefallen und deshalb denn Code eingerichtet.
Gelder fließen also keine :)
Antwort 7 Likes
Inxession
76 Kommentare 77 Likes
Danke für den Test
Danke für die Info
Hab mal zugeschlagen.
Bis vor einem Jahr habe ich noch mit einem 6-Achs Industrie Roboter gefräst.
Eigentlich nur als Machbarkeitsstudie ...
Kawasaki Roboter
Oberfräse dran
GCODE aus verschiedenen Applikationen erstellt
Eigenes kleines Tool in C# geschrieben welches die Gcodes in Robotersprache umwandeln konnte ...
und Fertig.
Roboter hab ich aber verkauft.
Letztendlich schade... aber finanziell die richtige Entscheidung.
Andy197
2,2kW hört sich super an. Denke mehr macht auch nicht unbedingt Sinn. Schlieslich muss der komplette Rahmen die entstehenden Passivkräfte auch abfangen können, ohne sich zu verbiegen :D
Pascal TM-Custom
bissel Upgrade wird es geben die TTC450 lässt sich ganz gut umrüsten z.b auf Liniarschinen usw.
Ich darf euch aber bald noch eine andere Fräse zeigen von Sorotec die Hobbyline 10560 das ist nochmal eine ganz andere Hausnummer :) Wird 2 Berichte geben denn ich bin zu Sorotec eingeladen worden daher machen wir mal einen Hinter die Kulissen Report.
Pascal TM-Custom
na das freut mich aber :) Estelcam ist echt gut ich fuchse mich da auch gerade ein. Die ganzen Optionen gefallen mir sehr gut in dem Programm.
big-maec
Meine allerersten Versuche mit Estlcam und Isel auf festem Schaumstoff. Man sieht eh nicht viel, aber ein bisschen. Das Werkszeug ist im Video auch noch nicht richtig eingestellt.
Youtube Isel CPM-4030 CNC Fräse Versuch 1
Pascal TM-Custom
Wichtig ist ja nur das du dich mit Estelcam anfreunden kannst und damit arbeiten.
big-maec
Ja mal schauen wie es später aussieht, bis jetzt komme ich damit zurecht.
F
Furda
653 Kommentare 371 Likes
Danke für den Artikel, solche DIY Tools lassen mein Herz stets höher schlagen! Es war immer mein Traum (und dabei ist es geblieben), eine gut ausgestattete Werkstatt für DIY zu haben, mit allem was dazu gehört; nebst Handwerkzeug, Fräse, Drehbank, Drechsel, Cup, Schweissgerätschaft etc. und viel Platz. Heutzutage dann wohl auch mit 3D Druck. Esse und Amboss wäre das Sahnehäubchen.
Letztes Mal CNC ist Jahrzehnte her, u.a. Teil der Ausbildung im elektrotechnischen Bereich, Profigeräte, aber noch ohne Bildschirme oder gar PC damals, alles von Hand.
Wozu taugen diese 80W noch bestens, bei welchen Materialien und Werkzeuggrössen?
Pascal TM-Custom
Also Holz Acryl Carbon auch Aluminium geht oder Leiterplatten kann man damit bearbeiten dafür reicht die 80W Spindel.
Man muss eben Vorschub etwas anpassen Fräser gibt es mit der ER11 Spannzange bis 7mm da kann man schon ordentlich Material abnehmen.
Mit der 500W Spindel die man sich noch dazu kaufen kann direkt bei TwoTrees geht dann deutlich mehr auch in Punkto Zustellung da kann man auch gleich mal 5mm auf einmal abnehmen.
Ich bin gerade mit der Firma HC-Maschinentechnik dran ein Igorslab Fräser Sortiment zu erstellen das für Acryl und Aluminium geeignet ist besonders Hinsichtlich Distros.
Eine Fräse ist nur so gut wie die verwendeten Fräser.
Und eines kann ich sagen die Fräser sind Brutal und hinsichtlich P/L echt Klasse.
D
Deridex
2,230 Kommentare 867 Likes
Interessante Maschine. Ich würde die 80W Spindel tatsächlich nicht nehmen sondern gleich zum 500W Model greifen.
Was mir nicht besonders gefällt ist das Fräsbett. Aber ich denke ein besseres würde wiederum den Preis zu weit nach oben treiben.
Was Fräser angeht: Eventuell finden sich bei Hoffman gute Angebote.
Pascal TM-Custom
Was meinst wegen Fräsbett? Das die aus MDF besteht? Ich finde das gar nicht Mal so schlecht falls mal was schief geht und Parameter nicht passen Donnert man nur in MDF.
Wäre die aus Alu wie teurere Modelle wäre der Schaden dann erheblicher.
Wenn man sich aber weilchen mit so einer Maschine auseinander setzt und man gewisse Routine hat würde ich Tatsächlich zu einer Gefrästen Alu Platte wechseln mit Gewinden um die Spannpratzen anzubringen.
Hoffmann schau ich mir aber mal an.
Eigentlich Sitz ich direkt an der Quelle da die Firma Gühring keine 3km neben mir ist
Saschman73
603 Kommentare 376 Likes
..... und ein wenig Fachkentnisse sollte der Anwender auch haben, bzw. wissen in welchen Listen und Tabellen er nachschauen muss!
Der beste Fräser der Welt wird nicht lange halten (Standzeit) wenn er falsch eingesetzt wird.
Pascal TM-Custom
Das stimmt natürlich man sollte da schon drauf achten.
Ich hab gestern etwas cooles gefunden von Sorotec die haben ein Programm in dem man Durchmesser, Schneidenanzahl und Material angibt und man dann die richtigen Werte bekommt mit Vorschub, Spindel RPM, usw.
Die Software wird wohl mein neuer Freund werden besonders für Fusion 360.
Dort lege ich mir eine Datenbank gerade an mit meinen ganzen Fräsern.
Macht Workflow dann doch einfacher
Pascal TM-Custom
Find ich auch Interessant da hast du ja dann 5Achsen Fräsen können das ist natürlich mega.
War sicher kein einfacher Umbau
igor'lLAB Community
