GPUs Graphics Reviews
AMD Radeon RX 570: the little blonde with the black soul
But what can the new edition offer (more)? After all, the GPU itself is not a real new development, but only the continuation of what AMD started with "Ellesmere" and Polaris 10 last year. Since our launch article "AM... Power supply and layout The board is a simple multi-layer design by Asus and differs significantly from the old layout of the Asus RX 470 Strix OC. We now take a closer look at the board and see that the voltage supply... Introduction Yesterday we had already published detailed game benchmarks with the necessary comments at the Radeon RX 580 and summarize the results in FullHD again. For higher resolutions we would ... Doom (volcano) Doom and Vulkan is again a welcome soul comforter for the Radeon community - and rightly so, as the current benchmarks show: Grand Theft Auto V (DX11) This DirectX11 title is reminiscent of earlier launch times, al... Power consumption at different load conditions Now let's look at the power consumption of the map and take a look at the partial load ranges. As with the Radeon RX 580, AMD is now focusing on further cycle steps, so that the performance... Achievable clock rates over the course of the temperature Cold cards are always the best, but unfortunately this is never so realistic. That's why we have stressed the Asus RX 570 Strix OC and are both open and closed. Summary In the end, as with the Radeon RX 580, it's a rather old (but well matured and slightly lighter) wine in new, technologically improved hoses - but also no new chip. The slightly slimmed-down little sister de...
But what can the new edition offer (more)? After all, the GPU itself is not a real new development, but only the continuation of what AMD started with "Ellesmere" and Polaris 10 last year. Since our launch article "AMD Radeon RX 470 4GB: Fleet Entry into Mainstream Gaming" already contains all the important theoretical basics and deeper information about the architecture and the somewhat slimmed-down variant, we give ourselves the long-breathed repetition this place is easy.
Because AMD did not develop its own reference design for the Polaris reissue and had already introduced the Radeon RX 470 only with the help of the board partners, it is not surprising that the path was also chosen in the new edition, so that we with the Asus RX 570 Strix OC the direct successor model of the Asus RX 470 Strix OC, which was already tested at the time. Of course, this also makes direct comparison from new to old much easier.
In time, however, the launch date together with the Radeon RX 580 could not have been less favourable so shortly after Easter, so that the people directly involved, also on behalf of their children and the rest of the family, would be able to attend this Easter egg, which was delivered just before the holidays, and would like to thank you very much for the busy holidays. Whether and how at least the buyers can and will see this new edition as a real gift, this will have to be clarified by today's test.
With 1300 MHz boost and 1750 MHz memory clock speed compared to the previous model, the card has only very moderately increased clock speeds, because the Asus RX 470 Strix OC already clocked at 1270 MHz (boost clock) and 1650 MHz for the memory and thus only slightly lower.
However, the board partner card at the time could not really keep the GPU clock constant due to the rather moderate cooling and the inappropriate board layout. We shall see how much better the successor model will be in this respect. Of course, we will take the map completely apart and judge it later.
Purely externally, the map is visual and haptic average and not a particularly successful treat from the top-of-the-material kitchen. But the plastic cover made of matt-black plastic does what it is supposed to do and you have to accept, also because of the price positioning, to be fair.
The card, which is very light with a whole 658 grams, with 24.2 mm real installation length (outer edge slot aperture until the end of the cover), a height of 12.2 cm (upper edge motherboard slot to top edge heatpipes) and a mounting depth of 3.5cm is a rather small dual slot card, which is mounted on the back side because of the upper stabilization frame again approx. 0.2 cm of space is required. This should be taken into account with large tower coolers and mini-ITX boards.
On the top we see the GPU heatsink, the illuminated ROG logo, as well as the single 8-pin power supply connector.
The bottom allows you to view the two medium-strength 6 mm heatpipes made of nickel-plated composite material, as well as the heat sink for cooling the GPU.
Since the slats are horizontally aligned, the end of the map has been kept open as an air outlet, although not optimally. The same applies to the openings on the slot panel, which are, however, obstructed by even two, meanwhile rather overflowing DVI-D connections. For up-and-comers, a single DVI-D jack would surely have done the same. Instead, it would have been better to bet on significantly more air outlet. The variety of connections is completed by an HDMI 2.0 jack and the DisplayPort-1.4.
How this map works in detail, we will of course question in detail later, here first again a tabular comparison:
  Nvidia
Geforce
GTX 960
Nvidia
Geforce
GTX 1060 3GB
Amd
Radeon
RX 470
Asus
RX 470
Strix OC
Asus
RX 570
Strix OC
Amd
Radeon
R9 390X
Shader
Units
1024 1152    2048 2048 2048 2816
Rops 32 48 32 32
32
64
Gpu GM206 GP106 Ellesmere Ellesmere Ellesmere Hawaii
Transistors 2.54 billion 4.4 billion 5.7 billion 5.7 billion 5.7 billion 6.2 billion
Memory 2 GB 3 GB 4/8 GB 4 GB 4 GB 8 GB
Interface 192 bit 192 bit 256 bit 256 bit 256 bit 512 bit
GPU clock
Mhz
1080 MHz+ 1502 Mz+ 1206 1270
1300
1050
Memory clock
Mhz
1502 2002 MHz 1650 1650
1750
1500
Test system and measurement methods
The new test system and the methotics have already been described in great detail in the basic article "How We Test Graphics Cards" (English: "How We Test Graphics Cards") and therefore, for the sake of simplicity, we now only refer to this detailed Description. So if you want to read everything again, you are welcome to do so.
If you are interested, the summary in table form quickly provides a brief overview:
Test systems and measuring rooms
Hardware:
Us:
Core i7-7700K
MSI Z270 Gaming Pro Carbon
G.Skill F4-3200C14Q-32GTZ x 2400 MT/s
Germany:
Core i7-7700K
1x 1 TByte Toshiba OCZ RD400 (M.2, System SSD)
2x 960 GByte Toshiba OCZ TR150 (Storage, Images)
Be Quiet Dark Power Pro 11, 850-watt power supply
Windows 10 Pro (all updates)
Cooling:
Alphacool Ice Pump VPP755
Alphacool NexXxoS UT60 Full Copper 360mm
Alphacool Cape Corp Coolplex Pro 10 LT
5x Be Quiet! Silent Wings 3 PWM
Thermal Grizzly Kryonaut (for cooler change)
Housing:
Lian Li PC-T70 with expansion kit and modifications
Modes: Open Benchtable, Closed Case
Power consumption:
non-contact DC measurement on the PCIe slot (Riser-Card)
non-contact DC measurement on the external PCIe power supply
Direct voltage measurement on the respective feeders and on the power supply
2x Rohde & Schwarz HMO 3054, 500 MHz multi-channel oscillograph with memory function
4x Rohde & Schwarz HZO50, current togor adapter (1 mA to 30 A, 100 KHz, DC)
4x Rohde & Schwarz HZ355, touch divider (10:1, 500 MHz)
1x Rohde & Schwarz HMC 8012, digital multimeter with storage function
Thermography:
Optris PI640, infrared camera
PI Connect evaluation software with profiles
Acoustics:
Creative X7, Smaart v.7
own low-reflection measuring room, 3.5 x 1.8 x 2.2 m (LxTxH)
Axial measurements, perpendicular to the center of the sound source(s), measuring distance 50 cm
Noise in dBA (Slow) as RTA measurement
Frequency spectrum as a graph
Follow Igor:
