DDR-RAM Practice Reviews System
Not just a visual eye-catcher – Corsair Vengeance RGB RT 2x 16 GB 3600 CL18 Kit Review with Overclocking and Teardown
With the first DDR5 platforms on the doorstep at the end of this year – if the leaks are to be believed – it’s the dash to the line for DDR4 and for memory manufacturers this means it’s time to refine the design one last time. Corsair launches the Vengeance RGB RT DDR4 series today, specifically tailored for Ryzen systems and with a freshly redesigned exterior. The gray 2x 16 GB 3600 Mbps CL18 variant is what we take a closer look at in today’s review.
Let me first give you a short overview of what makes the new DDR4 modules special, according to Corsair. The lighting of the new modules is provided by ten RGB LEDs with a “panoramic light guide” that can be individually controlled with Corsair iCUE. The heatsink is made entirely of aluminium for the best possible cooling performance – except for the light guide, of course – and in addition to the “Gunmetal” colour there is also a version with the brushed element in light grey / white.
For the memory configurations, kit sizes from 2x 8 GB to 8x 32 GB and XMP profiles DDR4-3200 C16, DDR4-3600 C18, DDR4-3600 CL16 and DDR4-4000 CL18 are available, which are thus optimally suited for AMD Ryzen systems in 1:1 mode. Corsair also advertises a specially designed PCB and carefully selected memory chips for maximum overclocking potential and backs this up with a “Limited Lifetime Warranty”.
Of course, if you want to know details and pricing on the various individual SKUs, you can just click through to Corsair’s website. The link with filter on the Vengeance RGB RT series is linked for you in the picture above. ☝
Tim Kutzner
888 Kommentare 726 Likes
Danke für den Test!
Aber für was steht RT? :P
big-maec
976 Kommentare 586 Likes
RT = Optimized for Ryzen.
BUILT FOR RYZEN™​
Optimized for maximum bandwidth and tight response times on the latest AMD DDR4 motherboards to complement your cutting-edge Ryzen™ system.
Tim Kutzner
Ryzen Toptimized? Für was genau das Kürzel stehen soll wüsste ich gerne :D
big-maec
oder Ryzen Technologie?
RedF
5,108 Kommentare 2,926 Likes
Da kann ich mit meinen 32GB Dual Rank CJR, die ich letztes jahr für 180€ gekauft habe, echt glücklich sein.
Ab und zu juckt es mal wieder, aber wenn ich wirklich noch mehr rausholen will muss ich gut das doppelte für Samsung B hinlegen.
skullbringer
320 Kommentare 339 Likes
Das T in RT müsste für Ten, also die zehn LEDs stehen, denn es gibt auch eine RS Serie mit 6 LEDs.
Das R könnte Ryzen sein, wobei es seit heute auch eine 4600 c18 SKU auf der Corsair Website gibt. Mit einer APU könnte man vielleicht an die 2300 FCLK rankommen, aber das R könnte auch einfach für Refresh stehen. 🤔
Auch Geizhals wirft gerade die SKUs durcheinander, weshalb eben die RS unter dem Artikel verlinkt waren :D
garfield36
1,293 Kommentare 337 Likes
Na da gibt es bessere Kits, zu ähnlichem Preis: "Crucial Ballistix RGB weiß DIMM Kit 32GB, DDR4-3600, CL16-18-18-38"
OdinsHeaven
27 Kommentare 11 Likes
Toller Artikel der mich angespornt hat, zumal mein aktuelles System ähnlich ist. Meine 5950x perform recht gut mit wenig Strom aber meine RAMs kosten mich jetzt schon 2 Wochen "Kampf" :ROFLMAO:
Jetzt hoffe ich doch, diese Community kann mir weiter helfen, denn wahrscheinlich bin ich vor lauter Testen betriebsblind geworden.
Hier ist mein Problem : Die RAM wollen aus irgendeinem Grund keine niedrigen Timings -B-Die wohlgemerkt.
Sys-Specs:
Asus Rog Strix B550-A Gaming
AMD Ryzen 9 5950x @4.65 Ghz/ 1.3250 VCore ( 1,331) - ca. 250 Watt
Kühlung AIO LinaLi 360mm
Corsair DDR 3600 CL18-22-22-42 - mit schrecklichen Subtimings in Auto Mode - diese habe ich mühsam korrigiert und eine deutlich bessere Performance erlangen
Mein Problem: Die Timings gehen nicht weiter runter - sollten es jedoch nach allem was ich gelesen und gesehen habe locker weiter runter gehen.
Bislang bin ich von DDR 3600 auf 3800 MT/s mit den selben Timings (18-22-22-42) und optimierten Subtimings nach dem Youtuber und Overclocker"Actually Hardcore Overclocking" FCLK 1900 und UCLK 1900 also alles synchron
Meine Fragen:
Warum kann ich keine niedrigeren Timings einstellen ( System bootet dann nicht mehr)
IOD CDD VDDP und SOC Spannungen seht ihr in der Tabelle Zen Timings.
Was muss ich tun dass ich die FCLK und UCLK weiter rauf bekomme ? (ja es gibt keine Garantie dass weiß ich und auch dass es nicht jede CPU kann) - aber vielleicht habe ich auch was übersehen ?
Bei den RAM bin ich bis auf 1.55 Volt rauf, es interssiert die Sticks nicht, auch unter 1,45 getestet, selbes Ergebnis.
Derzeit Geekbench3 bei : Browser Ergebnis
Singel 6458 , Multi 87574 - also gar nicht weit weg von Igor´s fabulosem Ergebnis.
Ich hoffe jemand kann mir wertvolle Tipps oder Wege geben?
Danke vorab, GLG
Adi
LEIV
1,579 Kommentare 664 Likes
Die einfachste Antwort ist wahrscheinlich, weils 4 Riegel sind, kannst ja mal mit 2 Riegel in A2 und B2 ausprobieren
Ansonsten müsste da noch deutlich mehr gehen, ist ja Samsung B-Die, aber bei 4 Riegeln ist halt ram Controller sehr entscheidend
Abgesehen davon hast du ganz schön hohe Spannungen auf vddg iod und vddg ccd
EDIT: kannst mal csodtdrvstr auf 30 setzen, das hilft bei "kalten" Starts
OdinsHeaven
Hm, ja daran dachte ich auch, das wäre aber eher bei DR (Dual Ranks) ein Problem , bei SR ist das weniger tragend. Die Spannungen sind niedriger als bei Igor´s 4,75 Ghz ;) aber noch lange nicht "zu Hoch" da ist noch Luft zu den Spezifikations- Grenzen. Es ist auch ein bisschen "Puffer"drin, da ich noch nicht fertig bin mit OC .
Alle anderen dich ich mit diesen KITT arbeiten habe sehen, haben diese merkwürdigen Probleme nicht. Zumindest sollten die Timings locker weiter runter gegen. Ich bin mir sicher ich übersehe etwas :))
M
Maddes
6 Kommentare 2 Likes
Hammer wie viel Arbeit da drin steckt. Und mal so aufs PCB geschaut sieht der „betagte“ DDR4 echt hochmodern aus. Also nix hier mit „altem Kram“, der ja „schlecht“ ist.
Ich selber habe 2x 16gb corsair vengeance lpx 3600 cl16-18-18 auf meinem 5800x3d. Bei normalen CPUs ohne 3dvcache geht ja wirklich noch mehr, aber ich denke ich kann schon zufrieden sein mit dem was ich hab 😅😄
Xaver Amberger (skullbringer)
