Gainward (i.e. The gaming brand of Palit) relies on a complete self-design for the board and a 2.5-slot radiator structure with three 8.5 cm fans (opening 9 cm, 15 rotor blades) in the Phantom GLH ("Goes Like Hell") that build up a correspondingly static pressure. The longitudinal, chrome-plated pipes are visually an eye-catcher, but do not influence the air flow measurement or audible. But more on that later. The card is also one of the few cards on the market with a true dual BIOS.
The 1382 g card is on average 29.3 cm long, measures 12 cm from top edge slot panel to top edge graphic card case and is 5 cm thick. In addition, there is another 0.5 cm for the blackened backplate. This means that it can already encounter space problems if housings are too small. The cover is made of plastic in the base with attached, black light metal applications in Buish optics and two silver longitudinal temples.
In addition, there are also optical accents such as the illuminated strips with RGB lighting embedded at the top, which can be controlled by driver and can also be switched off. The GeForce logo on the top is only embossed.
Gainward delivers the card with two external 8-pin ATX power supply connectors. The BIOS 1 delivers slightly more boost clock (1875 MHz to 1800 MHz), but leaves the fans in the idle at approx. 800 rpm lightly sour, while BIOS 2 allows a little less boost, but offers a fan stop. Why it was decided. But even more on that later. The screenshot of GPU-Z gives us a first impression:
Technical data and comparison maps
At the end of this introduction, the maps of the new generation and those of the old generation in direct tabular comparison:
Nvidia GeForce RTX 2080 Ti Fe |
Nvidia GeForce RTX 1080 Ti Fe |
Gainward GeForce RTX 2080 Phantom GLH |
Nvidia GeForce RTX 2080 Fe |
Nvidia GeForce RTX 1080 Fe |
Architecture (GPU) |
Turing (TU102) | Pascal (GP102) | Turing (TU104) | Turing (TU104) | Pascal (GP104) |
CUDA Cores |
4352 | 3584 | 2944 | 2944 | 2560 |
Peak FP32 Compute |
14.2 TFLOPS | 11.3 TFLOPS | 11 TFLOPS | 10.6 TFLOPS | 8.9 TFLOPS |
Tensor-Cores |
544 | No | 368 | 368 | No |
RT-Cores |
68 | No | 48 | 48 | No |
Texture Units |
272 | 224 | 184 | 184 | 160 |
Basic clock |
1350 MHz | 1480 MHz | 1515 MHz | 1515 MHz | 1607 MHz |
Boost clock |
1635 MHz | 1582 MHz | 1875 MHz | 1800 MHz | 1733 MHz |
Memory |
11GB GDDR6 | 11GB GDDR5X | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDRX5 |
Storage bus |
352-bit | 352-bit | 256-bit | 256-bit | 256-bit |
Memory bandwidth |
616 GB/s | 484 GB/s | 448 GB/s | 448 GB/s | 320 GB/s |
Rops |
88 | 88 | 64 | 64 | 64 |
L2 Cache |
5.5MB | 2.75MB | 4MB | 4MB | 2MB |
Tdp |
260W | 250w | 250w | 225W | 180w |
Transistors |
18.6 billion | 12 billion | 13.6 MRD | 13.6 billion | 7.2 billion |
Chip size |
754 mm2 | 471 mm2 | 545mm2 | 545 mm2 | 314 mm2 |
SLI Support |
Yes (x8 NVLink, x2) | Yes (MIO) | Yes (x8 NVLink) | Yes (x8 NVLink) | Yes (MIO) |
Test system and measurement methods
We have already described the new test system and the methodology in detail in the basic article "How We Test Graphics Cards, as of February 2017" and therefore refer to this detailed basis for simplicity. Description. So if you want to read everything again, you are welcome to do so. However, we have again improved CPU and cooling to largely exclude possible CPU bottlenecks for this fast card.
If you are interested, the summary in table form quickly provides a brief overview:
Test systems and measuring rooms | |
Hardware: |
Intel Core i7-6900K -4.5GHz MSI X99S XPower Gaming Titanium G.Skill TridentZ DDR4 3600 1x 1 TByte Toshiba OCZ RD400 (M.2, System SSD) 2x 960 GByte Toshiba OCZ TR150 (Storage, Images) Be Quiet Dark Power Pro 11, 850-watt power supply |
Cooling: |
Alphacool Ice Block XPX 5x Be Quiet! Silent Wings 3 PWM (Closed Case Simulation) Thermal Grizzly Kryonaut (for cooler change) |
Housing: |
Lian Li PC-T70 with expansion kit and modifications Modes: Open Benchtable, Closed Case |
Monitor: | Eizo EV3237-BK |
Power consumption: |
non-contact DC measurement on the PCIe slot (Riser-Card) non-contact DC measurement on the external PCIe power supply Direct voltage measurement on the respective feeders and on the power supply 2x Rohde & Schwarz HMO 3054, 500 MHz multi-channel oscillograph with memory function 4x Rohde & Schwarz HZO50, current togor adapter (1 mA to 30 A, 100 KHz, DC) 4x Rohde & Schwarz HZ355, touch divider (10:1, 500 MHz) 1x Rohde & Schwarz HMC 8012, digital multimeter with storage function |
Thermography: |
Optris PI640, infrared camera PI Connect evaluation software with profiles |
Acoustics: |
NTI Audio M2211 (with calibration file) Steinberg UR12 (with phantom power for the microphones) Creative X7, Smaart v.7 own low-reflection measuring room, 3.5 x 1.8 x 2.2 m (LxTxH) Axial measurements, perpendicular to the center of the sound source(s), measuring distance 50 cm Noise in dBA (Slow) as RTA measurement Frequency spectrum as a graph |
Operating system | Windows 10 Pro (1803, all updates) |
