Cooling Reviews Watercooling
Deepcool LS720 Review – discreet AiO with a special installation wish
Last time, we had a small air cooler from Deepcool for testing, but today it’s practically exactly the opposite. With the new LS series, the manufacturer certifies itself “elite performance”, whether you can keep this promise you will learn in the following article.
If you prefer compact air coolers after all, here is the article on the AK400 with quite a positive overall result:
Deepcool AK400 CPU-Tower-Kühler im Test – Guter Allrounder für die Mittelklasse
The compact water cooler comes in a printed cardboard box, which is partly covered by a white sash. Besides the obligatory product picture, there is also a list of the most important features and properties on the back.
Inside the box, the contents are protected by the classic shell made of hard cardboard. The pump, radiator and fans are individually packed in plastic bags, which could be avoided for the sake of the environment.
The accessories consist of various brackets and screws as well as cables for connecting to the motherboard and lighting. Unfortunately, a tube of thermal paste is once again not available.
By the way, on the right in the picture is not an empty bag, but an extra cover for the pump block, which you can use yourself eg. can design with a sticker. Nice gimmick for some personality in your own system.
Assembly and installation
For the AM4 socket, the existing backplate of the motherboard is once again used to mount its own screws including integrated spacers. The matching bracket must then itself be attached to the underside of the pump block with four screws.
Afterwards, the pump block only has to be placed on the processor and tightened crosswise thanks to the factory-applied thermal paste. The pump and fan are connected to each other via a daisy chain system, and only the last fan is connected to the mainboard. Since the aforementioned screws with rubber spacers keep the backplate in place, the installation also works quite well without a third hand.
My PR contact and also the press guide explicitly pointed out that this AiO should be installed with the hoses down.
However, this information is not found on the product page and even the render images and instructions show the “normal” installation with side hoses. More about this later in the article.
Specifications
Here is a quick overview of the technical details before we get down to the nitty-gritty. More information can be found on the manufacturer’s product page, as usual.
RX480
1,883 Kommentare 873 Likes
Bei 30% PWM sieht der dB-Wert der Lüfter sogar besser aus als bei den Aurora.
(könnte zusammen mit Pumpe@6V erträglich sein)
Nachteile sind fehlende Erweiterbarkeit und evtl. "Fluxx nach ein paar Jahren".
btw.
Interessant wäre es, die CPU-teststation auf den 5800x3d umzustellen, weil die CPU sehr auf gute Temps reagiert,
bzw. andersrum bei schlechten Temps nach ner 1/2h gerne etwas runtertaktet in CB23.
RedF hatte mal bei sich gemessen:
Ghoster52
1,425 Kommentare 1,089 Likes
Wegen der Vergleichbarkeit würde ich auch gern eine CPU der 5000er Serie unter dem Kühler testen. ;)
F
Furda
663 Kommentare 371 Likes
Wofür steht nun die "720" im Namen? Vorder- und Rückseite einmal rund herum gemessen? *fail*
Eine weitere 0815 AIO Einheitsbrei.
w
waintdeir
3 Kommentare 0 Likes
Ich kann es auch nicht ganz nachvollziehen, aber wahrscheinlich weil es drei 120x120mm Lüfter sind... macht in Marketing-Mathematik also 6x120 = 720 :ROFLMAO:
F
Furda
Hey schaut her, der neue Ford Mustang V8 mit Vier-Zylinder-Motor 🤦🏻‍♂️
Dann noch nichts neues bieten, macht das ganze sehr unsympathisch!
A
Aasimar
37 Kommentare 12 Likes
Mal eine Frage zu dem Gehäuse...
Ich habe ein Thermaltake P5, und betreibe es atm mit einer normalen Wasserkühlung.
Da aber wegen einer defekten CPU ein kompletter Neubau bei mir vor der Tür steht,
denke ich darüber nach, mir auch eine AiO Wasserkühlung zu kaufen...
Da das P5 größer ist, als das hier verwendete P3, stellt sich mir aber die Frage,
ob die Leitungen der AiO überhaupt lang genug sind??
Hier mal ein Bild meines jetzigen, nicht so ganz funktionierenden PCs
Der Radiator wäre dann ja schon ein ganzes Stück weiter weg von der CPU
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
