DDR-RAM Motherboard Reviews System
Challenge accepted? – ASRock Z590 OC Formula overclocking review with teardown
Dare to Challenge – rarely has a slogan been more fitting than that of the Z590 OC Formula, ASRock’s new high-end overclocking motherboard! Intel’s latest mainstream CPUs of the Rocket Lake family don’t bring any big advantages for gamers, but for friends of memory overclocking the 11th generation opens completely new possibilities with its new memory controller. Unsurprisingly, all the motherboard manufacturers are throwing their hats in the ring once again on this occasion to fight for the crown of the OC battleroyal.
But this is not without risk, because in the end usually only one can prevail, in the performance and thus also in the choice by the XOC community, which always wants to use only the best hardware for the highest benchmark scores. If you are only a 100 MHz behind, you will be sorted out and, in case of doubt, as a manufacturer you will be left with the development costs. It is all the more remarkable that ASRock also dares to take this step to the spearhead of OC motherboards at the end of the DDR4 era.
The reference for today’s test is a Maximus XIII Apex. Asus has been able to get itself firmly locked into the hearts of the XOC community over the last few generations with the Apex series, making it the benchmark for what a board in this class needs to be able to do in order to compete. Other manufacturers like Gigabyte with the Tachyon, MSI with the Unify-X or EVGA with the Dark should also be mentioned, but have only made it to the market in homoeopathic quantities if at all so far and therefore can’t really have a say in today’s review.
Overview and features
So first, let’s take a look at the features ASRock has added to their overclocking flagship, largely due to world-renowned overclocker Nick Shih, whose experience and secret ingredients are meant to propel the OC Formula series to new heights. As it says on the front of the product page, “Unlike most so called overclocking motherboards that are designed by engineers who don’t have adequate experience in extreme overclocking or have never participated in an OC event, Z590 OC Formula is the only motherboard in the market that are designed by a genuine overclocker, Nick Shih, who is hands down one of the most talented overclockers alive.” So there is no lack of self-confidence.
Probably the most exotic feature are the SMD DIMM slots, which are otherwise almost only installed on small ITX boards due to space contraints. In addition to the space-saving installation, (SMD) Surface Mount Devices DIMM slots offer another decisive advantage: better signal quality. With conventional DIMM slots, the contact feet of each DIMM slot pin protrude through the entire board to be soldered in place. Due to the actually unnecessarily long and protruding connections, signal reflections and thus problems occur, especially at higher frequencies.
SMD DIMM slots, as the name implies, are mounted only to the surface of the board, which means more complex assembly, but also no excess traces and paths where signals can get lost and reflected. Furthermore – as usual for OC boards of this class – only 2 DIMM slots are installed to keep the load on the memory controller of the CPU as low as possible and to be able to move the slots of both memory channels even closer to the CPU.
To improve the signal quality even more, ASRock also uses a 12-layer PCB with backdrill process, which some of you may have heard in connection with current Ampere Nvidia cards. The principle here is also simple but effective: The signal-carrying traces in different layers of the board are isolated from each other as well as possible and at vias, i.e. connection points between layers, excess conductive material is drilled out from the back to further reduce reflections.
As a consequence, ASRock advertises clock speeds of DDR4-5600 and more. Whether the board can keep what is promised, also for daily, stable use of such breathtaking speeds, will have to be seen in today’s test. But at least on the paper of the data sheet, the conditions are right for this.
On the other hand, the 16-phase voltage supply for the CPU core voltage, consisting of 90 A Smart Power Stages, and the 2-phase voltage supply for the main memory sound almost unspectacular. However, ASRock has definitely not skimped on comfort features for overclockers. So the board has an OLED display to monitor system parameters like voltages, temperatures, BCLK etc., on-board buttons for power, reset, but also BCLK plus and minus and 3 definable profiles.
Furthermore there is a “BFG” button, comparable to the Safe Boot of Asus boards, a retry button, dual BIOS with a dedicated switch, LN2 mode, slow mode, dip switches for the PCI-E slots and of course a postcode display. Does the hobbyist or extreme overclocker of the world miss anything here? I don’t think so. If you want to know more, you can find all information and links directly at ASRock’s website. As a starting point, I have linked the specsheet of the Z590 OC Forumla here.
thebagger
104 Kommentare 77 Likes
Danke für den Test,
ich habe ja nun wirklich keine große Ahnung von OC-Brettern, aber der Bios-Switch ist endlich mal an einer für mich vernünftigen Stelle!
B
Bambina
66 Kommentare 35 Likes
Wo kann man die MemTweaktIt software downloaden?
skullbringer
312 Kommentare 333 Likes
Die exakte Version, die mit Z590 M13A und OCF funktioniert, ist hier verlinkt: https://community.hwbot.org/topic/205829-rog-maximus-xiii-apex/
Da es eine portable Version ist, gibt es keine Infos zur Versionsnummer, aber immerhin muss man auch nichts installieren.
Leider werden die Links auf den offiziellen Hersteller Support-Seiten viel zu selten aktualisiert. Die Suche nach einer funktionierenden Version für Board/CPU Kombinationen ähnelt Detektivarbeit :D
Tim Kutzner
867 Kommentare 710 Likes
Interessanter Artikel und nettes Board, aber die Farbwahl .. naja :D
Guest
Schöner und interessanter Test @skullbringer
Das es extra Boards fürs OC gibt, war mir jetzt doch neu. Die verbauten Komponenten sind top, die hätte ich auch gerne auf einem normalen Board ;)
Aber so richtig hat mich das eigentlich nie gereizt und habe mich generell mit OC nie groß beschäftigt.
Aber ob sich ein knapp 600,- Dollar teures Board vor dem kommenden Alder Lake wirklich noch lohnt? Da soll es ja dann zwingend auch einen neuen Sockel geben. Naja, man weiß da zwar noch keine genauen Zeitpunkte, wann es soweit sein soll, aber könnte mir vorstellen, dass sich das vielleicht nicht wirklich lohnt, soviel auszugeben. Auch wenn man über die vorgestellte Qualität des Boards sicher nicht meckern kann.
l
lochi
7 Kommentare 0 Likes
Nettes OC-Brett für Freaks, wäre auch für mich interessant, wenn nur Intel nicht immer seine MB Chips durch neue Sockel so schnell altern lassen würde.
Aber mal was anderes, wie schauts mit der Minimal-Stromaufnahme im Desktop Betrieb aus, interessiert das denn keinen mehr? Die CPU´s werden immer toller und schneller, aber Chipsätze dafür immer durstiger!
Enttäuschend war mein letzter i9-9900T(35 Watt) in 2019 gekauft, die CPU hat zwar Idl nur 3 Watt, aber der Chipsatz(Z390) saugt dafür 42 Watt aus meiner Steckdose
Martin Gut
7,982 Kommentare 3,725 Likes
Zwei neue Sockel, einen für CPU und einen für DDR5-RAM. Mit Aufrüsten ist auf jeden fall nichts mehr.
Lohnen tut es sich nur, wenn man OC als intensives Hobby betreibt. Da geht es nur noch um die letzten 2 oder 3 % Leistung die man heraus kitzeln will, weil man Spass daran hat. Wenn man nicht vor hat eine Woche lang mit dem OC zu experimentieren, kann man auch ein Board für 150.- bis 200.- nehmen, Prozessor rein und laufen lassen. Man wird keinen Unterschied spüren. Da kann man das Geld an anderen Orten sinnvoller verbrauchen.
Riegelstriegel
110 Kommentare 62 Likes
Servus,
die roten Knubbel in der Ecke dürften extra-audiophile Kunststofffolien-Kondensatoren sein und keine Spulen wie auf Seite zwei geschrieben. ;-)
B
Besterino
6,932 Kommentare 3,507 Likes
Ich mag ASRock(Rack) für ihren Mut zu Nischenprodukten. Sind für mich ein wenig wie ABit damals(tm)...
Diese konkrete Nische des Formula spricht mich zwar eher wenig an, aber in der Vergangenheit bin ich inzwischen bei denen irgendwie echt verdammt oft schwach geworden und so hab ich im aktuellen Fuhrpark von denen allein 4 Bretter hier:
Z270M-ITX/ac
X399D8A-2t
TRX40 Taichi
TRX40D8-2n2t
Alle absolut unauffällig & zuverlässig. Die VRM-Kühllösung für dieses Brett haben sie anscheinend vom TRX40 Taichi übernommen - da funktioniert die Kühlung nach meiner Erfahrung durchaus und ist erstaunlich leise.
P
Phoenix
4 Kommentare 0 Likes
Guter Test und wirklich tolles Board, schlussendlich fahren die irgendwie aber doch alle Gear1 scheint mit CL13 oder 14
wohl flotter in den FPS zu sein.
Hätten se das mal für den CKL rausgebracht, 2x16GB B-Die läuft wohl auf fast allen Z590 Board´s eher Mau, das läuft aufn Z490 wesentlich entspannter im Daily.
Das Unify X wäre auch noch interessant, das einzige Board wo mit RKL 2x16GB@4933MhzCL17-18 mit B-Die gezeigt wurde.
l
lablaka
41 Kommentare 28 Likes
Das Problem ist, dass sich die selbstzahlenden Enthusiasten, die nicht gesponsort werden, bereits ein Z590 Apex gekauft haben.
War in der EU deutlich günstiger, ist seit Ewigkeiten immer eines der besten Extreme OC Boards und war vor Rocket Lake Launch verfügbar, nicht erst Monate später.
Der Großteil dieses kleinen Nischenmarktes dürfte daher längst bedient sein.
Xaver Amberger (skullbringer)
