Komplett-PCs Mini-PC Reviews System
Beelink SER4 Mini-PC Review – Massive upgrade to the predecessor
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
It was only a few months ago that I put the SER3 from this manufacturer through its paces, and the successor is already being introduced. And while the exterior has remained virtually identical, the number of cores inside has simply been doubled. The following article will tell you whether you can cool so much power in a small space.
You can find the article about the SER3 Mini-PC here:
Beelink SER3 Mini-PC Review – fat bumblebee with decent performance
In any case, the space-saving black box has already been preserved for us, only a new “4. Generation” sticker was added. There is still no product picture or other information, only the sticker on the back suggests the details of the contents.
We have also already seen the inside of the small box in this form. A thin layer of sponge-like padding protects the system from above and below, but apart from that, the packaging itself has to absorb the rest of the possible shocks.
The accessories include the power supply, a short manual, the wall mount and two HDMI 1.4 cables with 20cm and 100cm length.
According to the type designation, the same power supply as the SER3 is included, a TDX-1903000E. This supplies a maximum of 57 watts at 19 volts / 3.0 amps.
Specifications
The following is an overview of the system details; further information can be found on the manufacturer’s product page.
RX480
1,924 Kommentare 905 Likes
interessante Metrik mit dem 90%-Wert bei den Fps
(sollte man vllt. als Fps-Limit öfter mal nutzen)
btw.
Wems zu laut ist, kann ja easy mit LM nachbessern:
(sollte eigentlich auch bei neueren APU´s genauso gut funzen)
Tim Kutzner
936 Kommentare 772 Likes
Ist ja zum Glück echt leise, braucht gar kein Tuning :)
Case39
2,606 Kommentare 998 Likes
Dann kann man sich ja auf nen Nachfolger, mit der dann aktuellen APU freuen.
2,136 Kommentare 1,370 Likes
Das war auch genau mein Gedanke! Zumal sich Intel in Sachen NUC mit AL (Mobile i7 Version mit Xe iGPU in Vollausbau) sehr zurückhaltend zeigt (außer beim Preis).
Tim Kutzner
Dauert immer ein wenig, bis die in solchen Systemen landen.
ArcusX
950 Kommentare 563 Likes
Nichtsdestotrotz sollen doch die neuen APU Lösungen deutlich besser sein oder täusche ich mich?
Pascal TM-Custom
1,100 Kommentare 1,313 Likes
Ist schon sehr cool son kleines Teil für denn Täglichen gebrauch eine echte Alternative dazu noch Emulatoren drauf und man hat für Zwischendurch noch eine Retro Konsole.
Case39
Ich kann warten. Mein bisheriger "NUC" von Gigabyte (2016) verrichtet noch zuverlässig seinen Dienst.
Casi030
11,923 Kommentare 2,340 Likes
Die Größe ist natürlich das eine,aber ein 5600G mit itx so klein wie es geht dürft dennoch günstiger sein , leider.
Natürlich erst nach meinem Test dein Video gesehen.Hatte irgend wo was mit 15Watt gelesen........
So schaut der 5700G dann mit 15Watt aus.
Pascal TM-Custom
Das glaube ich weniger das man mit einem ITX billiger davon kommt.
PSU, Case, Lüfter,Speicher,Ram,CPU und bei denn heutigen Preisen wirst du da sicherlich auch wenn es das billigste vom Billigen ist nicht unter 600€ wegkommen.
Casi030
Alles bei MF "Gekauft",Ram bekommt man aktuell nur 16GB Kits......Zusammen 512EU + 15EU für Windows 10/11
Der 5700G kostet rund 80EU mehr,bringt bei 25Watt aber nicht wirklich viel mehr weil die iGPU da noch gedrosselt wird.
Pascal TM-Custom
interessant hätte ich so jetzt nicht erwartet.
Casi030
Das ist aber auch wirklich solala , besonders wenn man so klein wie möglich bleiben will um mit dem Beelink SER4 noch halbwegs mit halten zu können.
Ich wüsste ja gern mal wie der als reiner 4Kern abschneidet.Schon mal überlegt ob du da Optimieren kannst?
B
Besterino
7,168 Kommentare 3,737 Likes
Für Office & Co. nehm ich ne VM aufm Server im Keller - als Client reicht dann jeder Toaster, auf dem muss dann nur ein RDP-Client o.ä. laufen.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
