GPUs Graphics Practice Reviews
AMD Radeon HD 5850 and HD 6950 revived – cleaning, assembly and the hunt for old records | Time travel
After a good year of dealing with current and competitive hardware and hanging out in the overclocker community, my current focus is on older graphics cards of the Radeon HD series for DirectX 11 applications. For this, I always give myself a budget of up to about 20 Euros, look what I can get used on the net for it and try to set new records with old graphics cards – which is of course a bit presumptuous. Well, at least that’s the claim and usually something quite nice can be elicited from the cards after all.
Since retro “10 years ago” articles appear here from time to time, this one should fit into the series. I would like to show in more detail how such old cards can be overhauled with simple means and how you can get more performance out of them – most of the time! And it might be worth taking a look in your own basement, especially because of the current street prices of current graphics cards – if current cards are available at all. I’ll now take a closer look at two used cards for this article, a reference ATI Radeon HD 5850 and a PowerColor HD 6950.
Since most of you probably don’t remember at all or only partially what these cards were about back then and what technical specifications they had, I have a GPU-Z screen shot for you as a refresher. Let’s start with the older of the old cards (that is, the even older one) in the form of the AMD Radeon HD5850:
Cypress was followed by Cayman in the next generation – that was the name of the chips at the time. By the way, both had the memory size of 1 GB in common, which already seems extremely poor today. The GPU clock rates were also still below 1 GHz and the breakthrough through this sound barrier only came later with AMD’s GHz edition of another card from the HD7000 series
So far, so good. So that’s where they are. And now? As they are, you can’t use them yet, nor should you. Hardened thermal paste, junk and bad pads need to be replaced or removed first. And it is exactly this journey that I cannot and will not spare you.
RX480
2,126 Kommentare 1,029 Likes
btw.
etwas OT, aber weil ich gerade Dein Bild sehe, wo auch die aktuelle 6800xt mit dem AiO-Loop noch drin ist
@ApolloX
Du könntest mal den hinteren Lüfter als Intake nutzen/drehen.
3x Outtake oben reicht ja dicke
und
evtl. wäre ein zusätzlicher kleiner Lüfter auf dem Ram und 1x 120er auf der GPU-Backplate noch ne Verbesserung
falls
Du noch nen Vgl. mit dem CustomLoop von Fritz Hunter in Betracht ziehst.
P
Picinc
4 Kommentare 2 Likes
Thema 6950 verleitet mich jetzt auch zu meinem ersten Kommentar hier. Hab auch noch eine ASUS HD6950 DCII mit 2GB (gekauft April '11 für 216,50 Euro) mit Dual-BIOS. Das ist die "Dicke" 3-Slot Karte. Vor ca. 4 Jahren hatte ich dann Grafikfehler (rote Balken) auf dem Monitor. Letztes Jahr hab ich die Karte dann mal aus dem Karton genommen und komplett gereinigt, incl. neue Paste. Siehe da, sie geht wieder. Was ich aber auch noch nie geschafft habe, ist der flash auf eine 6970. Ich hab das in den Jahren mehrfach versucht.
ApolloX
1,769 Kommentare 1,011 Likes
@RX480 Hey, du hast das zweite P wegbekommen :)
Ja stimmt, wenn der Rechner auf dem Balkon steht, dann dürfte der hintere Lüfter umgedreht eventuell sogar mehr Sinn machen, wobei durch die niedrigen Temperaturen ists auch fast egal. Und indoor, hm. Ich hab die Lüfter am oberen Radi meist aus, die ALC (sinds die Aurora Rise?) sind Monster, die werf ich nur an, wenn mir der Hotspot nen Schwellwert für ein paar Sekunden überschritten wird, waren das ca. 70°C sowas. Da die andren ALC Lüfter vorne am großen Radi kein 0 RPM können, laufen die eh permanent mit so 600 RPM, so dass es im heruntergetalteten Normalbetrieb reicht, wenn ein Radi leicht durchlüftet wird.
Den kleinen Lüfter auf den RAM hab ich öfters schon überlegt, letztens hat mir irgendwo wieder einer gesagt, dass den Ballistix so um die 50°C garnichts ausmachen. Und die Halterung für nen kleinen Lüfter (neben dem Geräusch) ist auch etwas kompliziert. Vielleicht ein Projekt für den Hochsommer.
Ja, ich warte schon sehnsüchtig auf Teil 2 vom Fritz, dann vergleich ich mal mit ihm. Mittlerweile kenn ich ja n paar Player, die relativ ähnliche Konfigurationen haben.
@Picinc
Ja, mit der 2 GB sollte es gehen, tuts auch nicht? Hattest du da aufs 1er Bios geschalten, denn merhere Quellen sagen, dass im 2er ein schreibgeschütztes Bios aktiv ist. Und das merkt man scheinbar nicht, der ATIflash schreibt einfch, meldet success, will neu starten, aber effektiv ist nichts passiert.
Ich hab mir ja noch extra die PowerColor gekauft, weil laut Netz genau diese eben das 6970er bereits im zweiten Speicher drauf haben soll. Aber dass es da ne 1GB Variante gibt, das hat mir sogar TPU verschwiegen.
Mit den alten Karten, da wirst halt echt zum Techno-Historiker und Forscher.
Antwort 4 Likes
P
Picinc
@ApolloX
Ich hab es auf beiden Schalterstellungen schon probiert. Und die BIOS-Versionen waren bestimmt auch von unterschiedlichen Quellen. Aber irgendwann probier ich es nochmal.
RX480
sorry, wenn ich das bis jetzt in der Eile immer übersehen hatte
Es gibt evtl. noch ne passende ältere Lösung, einfach zum draufclippen.(falls man kein Freund von Bindedraht ist)
Weiss jetzt net, ob DDR4 länger ist und dann net zu dem DDR3-Kühler passt.
(dann müsste mal Jemand mit 3d-Drucker ran, um die 2 Klammern zu modifizieren)
v
vonXanten
835 Kommentare 364 Likes
Hmm alte Grafikkarten, hab hier auch noch ein paar Exemplare. Davon einmal einen Satz 4870X2 als Crossfire Verbund, gute Heizung für den Winter ;)
Aus der 5er bzw 6er Serie habe ich auch noch Karten hier. Vllt. bastel ich auch noch in der nächsten Zeit.
amd64
1,177 Kommentare 773 Likes
Ich hatte auch eine Powercolor 6950 1GB die ich zur 6970 flashen konnte. Wenn ich mich recht erinnere müsste das Produktionsdatum entscheidend sein, nicht die Speichermenge. Nach aufkommen der BiosMods wurde die Freischaltung imho physisch von AMD unterbunden.
IloveTattoo
222 Kommentare 129 Likes
Hach mein Teammate wird gross. Super Artikel
P
Picinc
Der berühmte Lasercut. Kann man an der Karte erkennen, welches BJ die hat? Hab mal eben geschaut, aber nix gefunden, was auf ein Datum hindeudet. Außer daß das PCB Rev. 1.0 ist. Aber es kommt ja auf den GPU Chip an.
RAZORLIGHT
385 Kommentare 295 Likes
Hab auch noch ne Sapphire HD5850 Toxic, war damals ne feine Karte, läuft immernoch.
Ben87
149 Kommentare 34 Likes
@ApolloX find ich gut, dass du dich hier einbringst! Weiter so 👍🏻
S
Soupar
42 Kommentare 9 Likes
Da es keine Angaben zum Strom gibt: Ich tippe die Ausgaben für Wäremeleitpaste etc sind schnell irrelevant, wenn man die alten Graka länger betreibt, und man ist schnell im Bereich in dem sich eine neue APU amortisiert?
ApolloX
Hm, guter Punkt. Also ich nutze die nicht wirklich, kaufen, aufbereiten, benchmarken, zurück ins Netz.
Aber die meisten der alten haben ein oder zwei 6 Pol Anschlüsse, da geht in Summe nicht soviel durch. Was Effizienz angeht, sind die APU/iGPU sicher die bessere Alternative.
igor'lLAB Community
