GPUs Graphics Latest news
Turing reloaded as a stopgap? Several board partners ready to produce GeForce RTX 2060 again
After I already reported about the shortages of graphics cards, a rumor made the rounds that NVIDIA probably wants to revive the older Turing entry-level chips. These were running (and apparently are running again) in TSMC’s old 12nm node, which is supposed to have enough spare capacity to be cheap and responsive. Own surveys among the board partners have shown that NVIDIA will probably supply all companies with this GPUs and not only a few selected ones. The quantities should be interesting enough for mass production, but not too high.
From that perspective, a revived GeForce RTX 2060 still makes perfect sense, as it won’t cannibalize a still upcoming GeForce RTX 3050 Ti or 3060, nor will it overly burden the existing and also scarce memory budget with the rather small memory expansion of 6 GB. However, reports that GeForce RTX 2060 Super will also be delivered are definitely false, according to the respondents. Only the original, unsupercharged RTX 2060 is supposed to be available for a limited time, nothing more.
The fact that this chip will later be relabeled and sorted into the new nomenclature below the current portfolio should, however, remain only a rumor according to the board partners. The delivery of the chips, on the other hand, should be considered as confirmed.
Source: own
M
MoGas
23 Kommentare 13 Likes
Verzweifelte Maßnahmen...
Karma
117 Kommentare 69 Likes
Tolle Sache, wenn die Preise dann auch zur Leistung (und dem UVP) der aktuellen Generation angepasst werden. Dann sollten solche 2060-Karten unter 250 Euro kosten für unter 250 Euro im Handel erwerbbar sein.
Ich muss selbst gerade lachen. Tatsächlich werden die wahrscheinlich deutlich über dem alten UVP von $349 liegen, wenn sie denn überhaupt in den Einzelhandel gelangen. Vermutlich ist die Produktion primär für Computerhersteller gedacht, damit die bezahlbare Systeme produzieren können.
c
cunhell
642 Kommentare 621 Likes
@Karma
Sieh Dir die Preise für die RX5600XT an. Selbst wenn der UVP unter 300€ liegen sollte, was ich nicht glaube, wird der Straßenpreis deutlich höher liegen. Selbst die 5500XT kostet jetzt deutlich über 200€ wenn man 8GB und eine vernünftige Kühlung haben will.
Ich hoffe immer noch, dass meine alte R9-280 durchhält bis die Preise irgendwie wieder normaler werden. Beim Zocken läuft die quasi immer auf Vollast mit entsprechenden Temps.
Cunhell
ipat66
1,587 Kommentare 1,711 Likes
Für wann sind denn die neuen RTX4000er angesetzt? :)
Antwort 4 Likes
m
maxw3ll
2 Kommentare 1 Likes
mal sehen ob der preis überzeugen wird. (facepalm)
c
cunhell
Kommt darauf an, von welcher Warte aus gesehen. Kunde oder Hersteller/Verkäufer ;-)
Cunhell
I
Irolas
17 Kommentare 8 Likes
Na ja, nachdem sich Intel ja entschieden hat, die GPUs auch in ihren neuen Enthusiast-NUCs zu verbauen, besteht wohl durchaus bedarf. Wobei da gerade für das Spielen eine 3060Ti besser gewesen wäre. Aber auch die Kernanzahl in dem Ding ist mit nur vier auch etwas gering.
v
vonXanten
831 Kommentare 364 Likes
Hab auch noch ein paar alte Grafikkarten rumliegen ;)
Die Hütte muss ganz schön brennen um so etwas zu machen oder alternativ die Dollarzeichen in den Augen... 🤑
konkretor
357 Kommentare 377 Likes
Wenn TSMC auf dem 12 Node aktuell genug Kapazitäten hat wieso nicht.
Die Nachfrage wird extrem hoch sein, aktuell sind keine Karten Lieferbar unter 300 € und viele Leute spielen noch in FHD da tuts die Karte allemal.
Die Ware wird schon verkauft sei, wenn bei TSMC noch die Belichtung läuft. Nvidia könnte auch noch andere 20xx Karten im 12 nm bei TSMC fertigen lassen. Wollen sie wohl nicht. Die anderen Turing Karten basieren ja auch auf dem 12 nm bei TSMC
Ich habe die Woche mal meine alten Grakas getestet ob die noch funktionieren. Nicht das die Vega 56 abraucht, dann siehste alt aus.
Fury und 7970 funktionieren noch :)
11,847 Kommentare 23,225 Likes
Bei meiner FuryX ist die Dreckspumpe hin, die fiept mittlerweile wie eine geprügelte Ratte auf Extasy. Die Karte selbst geht noch, nur der RAM ist bissl mau.
Antwort 4 Likes
M
McFly_76
412 Kommentare 146 Likes
Aber das ist ein Widerspruch in sich 🧐
Zuerst jammern die Hersteller dass die Produktion wegen Materialmangel schwierig ist und die Preise gehen nach oben.
Am 20.01.2021 lesen wir https://www.igorslab.de/weitere-det...en-so-schwer-zu-kaufen-und-herzustellen-sind/
Jetzt, wo eine GTX 1660 so viel kostet wie die RTX 2060 6G im Oktober 2020 ( ab 279 € ) kommt die Meldung dass es doch genug Kapazität gibt und die Boardpartner die Turing Grafikkarte als Lückenfüller produzieren können ? 🤣
Definition "RTX 2060 als Lückenfüller": Preise zwischen 400 - 650 €
D
Denniss
1,718 Kommentare 652 Likes
Dann könnte AMD ja Polaris auch nochmal auflegen lassen, dann aber in 12nm wie bei der RX590. Das hatte sowieso immer gefehlt, RX570XT+RX580XT mit geringerem Stromverbrauch dank 12nm.
DAs wäre dann was für diejenigen die eine Grafikkarte unbedingt brauchen aber nicht die Mondpreise für aktuelle Karten zahlen können
M
MyRunner
318 Kommentare 100 Likes
@McFly_76 Kenn mich da nicht aus. Kann es sein, dass fuer die alten Karten noch genug Komponenten auf Lager liegen, die bisher nicht verbaut wurden und jetzt halt noch versilbert werden. Ich hab keine Ahnung, wieviele "Gleichteile" zwischen der 2xxx und 3xxx Version vorhanden sind.
M
Macces
29 Kommentare 24 Likes
Ich habe ein wenig das Gefühl hier wird versucht, über die nicht vorhandene aktuelle Generation, für die alte Generation noch möglichst viel Geld abzugrasen.
Ich hoffe auch das meine auf RX580 umgeflashte RX480 noch eine Weile durchhält und ich dann für einen humanen Preis im Sommer etwas neues bekomme.
Oder ich gewinne die XFX aus dem Gewinnspiel 😃.
D
Deridex
2,230 Kommentare 867 Likes
Danke für das Bild in meinem Kopf:ROFLMAO:
McDexter
69 Kommentare 27 Likes
Bis es die Grafikkarten zu denn angeblichen UVP Preisen gibt, steht schon die neue GPU Generation vor der Tür.
Habe heute eine RTX 3070 für 1179 Euro gesehen. Das ist nur noch zum Kopfschütteln.
v
vonXanten
Ich weiß zwar wie eine Ratte fiept, aber das als Kopfkino....
Umbau auf einen anderen Kühler wäre auch eine Option, schade um die Fury...
Und die Preise sind schon nicht mehr auf dem Mond, die sind schon ein Stückchen weiter ;)
Suche im Moment nicht nach Karten, will ich mir nicht leisten! Aber so denken die wenigsten, sieht man ja anhand der kurzen Verfügbarkeit in den Shops.
c
cunhell
@Igor
Das mit der Fury ist wirklich schade.
@vonXanten
Ich glaube, viele wollen die Preise nicht zahlen so lange sie nicht dazu gezwungen sind, weil z.B. die aktuelle Karte abgeraucht ist.
Ich kämpfe zur Zeit mit fps unter 30 rum. Meine alte Karte bringt nicht mehr, aber es geht halt irgendwie. Ich hoffe nur, dass sie nicht das Zeitliche segnet. So denken sicher viele.
Das Problem ist aus meiner Sicht eher, dass die Paar, die nicht auf die Kohle achten wollen/müssen, schon reichen, um alles wegzukaufen, weil nix da ist, was man kaufen könnte.
Cunhell
C
Candyman2211
16 Kommentare 2 Likes
Ich beschließe hiermit, dass die 1060 Strix noch solange reicht, bis mir was neues zufliegt oder die Blauen den Grünen / Roten Paroli bieten^^
Follow Igor:
