With the GeForce RTX 2080 Gaming X Trio, MSI introduces its own new graphics card design. From the very beginning, MSI relies on a true custom design and its own cooler with three fans and the obligatory RGB effects. It is equipped with the TU104, has 8 GB of GDDR6 graphics memory and offers everything else we already know from the reference design.
The 1,525 kg card is a proud 32.5 cm long, measures from top edge slot panel to top edge graphics card case almost 13.5 cm and is 5.3 cm thick. Then there is another 0.5 cm for the silver backplate. I unpacked them and photographed them from all sides. Disassembling, board images and further analyses, as well as the necessary benchmarks, can be found in the upcoming single map review. For now, these high-resolution images must be enough:
We will read again at a later date in the usual depth. Promised!
MSI GeForce RTX 2080 Gaming X Trio, 8GB GDDR6, HDMI, 3x DP, USB-C (V372-031R)
