GPUs Graphics Reviews
KFA2 GeForce RTX 2070 Super Work The Frames in review – KFA2 annoys premium vendors with new board, usable fans, lots of RGB and a starry sky
Normally, KFA2 positions itself with the cards of the respective performance classes rather in the most favorable range and thus shows some Pixel pharmacists the cold shoulder and where it can go long in the customer search, because many of these models have been among the absolute price/performance winners for years. But Asia is now ticking quite multi-layered and one cannot and does not want to close one's eye to the call of the RGB-believing community forever.
Of course, such a somewhat elaborately designed offshoot has its (slightly higher) price, but KFA2 still managed to reach the actual target group such as Aorus (i.e. Gigabytes Gaming Brand of the slightly better equipped cards) once again cheeky to annoy and undercut significantly in terms of price. The name "Work The Frames" has been chosen almost sarcastically and even somehow program, because in the end many competitors probably only a (badly) moody WTF gets stuck in the throat. Improved board, other fans on a slightly more powerful radiator – KFA2 has actually shoveled a decent everywhere, not only visually, but also. Especially at the back.
It is also interesting that this even puts you in direct competition with the products of the parent company (Palit/Gainward), whose products, however, are significantly less luminous, are priced on one level and yet are hardly significantly better in the end. With the WTF offshoot of the GeForce RTX 2070 Super, KFA2 is settling in this area in this country that others have identified for some time as an illuminated comfort zone and it will be exciting to see how KFA2 can hold its own here in the end – if. But you even have two independent RGB controllers on board, more on board later.
The TU104-410 of the GeForce RTX 2070 Super
The TU104-410 of the GeForce RTX 2070 Super is reduced to 2560 CUDA cores, 320 tensor cores, 40 RT cores, 160 TMUs and 64 ROPs compared to the full version TU104-400 on the RTX 2080. The number of GPC (Graphics Processing Clusters) varies between 5 and 6 depending on the chip and type of recovery. The card will have clock frequencies in the range of 1605 MHz (base clock) and 1770 MHz (boost) and can thus simultaneously deliver up to 9 TFLOPS computing power. The 40 RT cores can deliver about 7 giga-rays per second in ray tracing performance.
Like the RTX 2080, the RTX 2070 has super 4 MB L2 cache. Otherwise, everything I have already written in the launch articles for the GeForce RTX 2070 FE and the GeForce RTX 2060 FE applies. And if you want to find out more about all the RTX features in detail, please refer to my long basic article "Nvidia GeForce RTX 2080 Ti and RTX 2080 – what is really hidden behind Turing" on the subject of RT. This, too, is read-proof and certainly worthwhile.
The TU104-410 also receives the same 256-bit memory bus as the TU104-400, which has eight 1 GB GDDR6 memory modules with 14 Gb/s data rate, resulting in bandwidth of up to 448 GB/s. As with the GeForce RTX 2080, NVLink support is at least active with one link, which makes the card a little more attractive, because the RTX 2070 was not allowed to use this feature. The 545 mm2 chip chip contains 13.6 billion transistors. Compared to the GeForce GTX 1080 Ti with its 12 billion Transistors on 471 mm2 may seem like a lot, but we must also remember that the chip is cropped and large parts lie fallow.
Die KFA2 RTX 2070 Super Work The Frames
The map tested today, despite or because of the whole beacon, also made it to Europe. And i will go into these details in more detail in a while. Let us first of all stick to the facts and data that are visible even without electricity. Because they are also interesting. The radiator cover is made of black ABS with piano lacquer surfaces and a light metal application in the upper middle. All three fans are illuminated (aRGB), the label with the "Work The Frames" logo on the top of it is of course also. Here, a separate RGB controller (GM006, ARM Cortex) modified for KFA2/Galax offers 4 independently controllable channels.
The 1173 grams are not really a small amount now, but there are also much thicker ships. The card measures 31.7 cm from the outer edge of the slot panel to the outer edge of the radiator cover. With the 12.5 cm from the top of the motherboard slot to the top edge of the cover, it is significantly higher than the slot bezel and the installation depth ("thickness") of 5.2 cm makes it a 2.5 slot card. The backplate made of ABS is purely optical in nature and is not actively involved in the cooling concept, as well as. Plastic unfortunately does not give this, but it shines like a starry sky.
With the GM001, which is also installed, the manufacturer uses another custom controller, which only masters simple RGB. But this is quite sufficient for the starry sky of the backplate.
The slot bezel does not allow any warm exhaust air directly, as the cooling fins are vertically aligned due to the three fans. So everything disappears as usual only in the depths of the housing. With one HDMI 2.0 port and three DisplayPort 1.4 connectors, there are plenty of variants to connect to the monitor.
Installation length (gross) 31.7 cm
Installation height (gross) 12.5 cm
Installation depth front (gross) 5.2 cm
Installation depth rear (gross) 0.6 cm (backplate)
Weight: 1173 g
Connections: 1x HDMI 2.0
3x DisplayPort 1.4
8-pin + 6-pin PCIe power supply
Cooler cover: ABS injection moulding, black with light metal applications
Fan: 3x 8.5 cm rotors with 11 rotor blades each
The latest version of GPU-Z gives us an initial overview of the electrical data, where Gigabyte has raised the base clock to 1685 MHz, but the "boost" corresponds to that of the competitors. However, this does not affect the overall performance, as the final bar is again, as with all other cards, on average in the boost specification:
Let's quickly compare some of the relevant maps in table form. The overview of the relevant comparison maps then looks like this:
  KFA2 RTX 2070 Super
Work The Frames
GeForce RTX 2070 FE GeForce RTX 2070 Super GeForce RTX 2080 FE
Architecture (GPU) Turing (TU104-410) Turing (TU106-400) Turing (TU104-410) Turing (TU104-400)
CUDA Cores 2560 2304 2560 2944
Tensor Cores 320 288 320 368
RT Cores 40th 36 40th 48
Texture Units 160 144 160 184
Base Clock Rate 1605 MHz 1410 MHz 1605 MHz 1515 MHz
GPU Boost Rate 1815 MHz 1710 MHz 1770 MHz 1800 MHz
Storage expansion 8GB GDDR5 8GB GDDR6 8GB GDDR6 8GB GDDR6
Storage bus 256-bit 256-bit 256-bit 256-bit
Bandwidth 448 GB/s 448 GB/s 448 GB/s 448 GB/s
Rops 64 64 64 64
L2 Cache 4 MB 4 MB 4 MB 4 MB
Tdp 215 W 185 W 215 W 225 W
Transistors 10.8 billion 10.8 billion 13.6 billion 13.6 billion
The size 445 mm2 445 mm2 545 mm2 545 mm2
Sli No No NVLink x8 NVLink x8
Test system and evaluation software
As always, I benchmark with my own PresentMon GUI and the interpreter software, which fills the Excel charts and the graphical output (and only the) so extra- or so. interpolates that all graphs are exactly long, creating a uniform and comparable time line. The remaining evaluations up to percentiles and bar graphics are based on the real raw data from the measurement. The benchmark system is new and has been upgraded in some areas. That's one of the reason why I've completely re-benchmarked all the games and cards.
I have also summarized the individual components of the test system in tabular form.
Test System and Equipment
Hardware:
Intel Core i9-9900 K
MSI MEG Z390 Godlike
4x 8GB G.Skill FlareX DDR4 3200
1x 2 TByte Aorus (NVMe System SSD, PCIe Gen. 4)
Seasonic Prime 1200 Watt Titanium PSU
Cooling:
Alphacool Ice Block XPX (1151), XPX Pro (AM4, 2066)
Alphacool Ice Grinder (modified)
Thermal Grizzly Kryonaut
Case:
Lian Li T70, Raijintek Paean
Open Benchtable
Monitor: BenQ PD3220U
Power Consumption:
Non-contact direct current measurement on PCIe slot (riser card)
Non-contact direct current measurement at the external PCIe power supply
Direct voltage measurement at the respective connectors and at the power supply unit
2x Rohde & Schwarz HMO 3054, 500 MHz multichannel oscilloscope with memory function
4x Rohde & Schwarz HZO50, current clamp adapter (1 mA to 30 A, 100 KHz, DC)
4x Rohde & Schwarz HZ355, probe (10:1, 500 MHz)
1x Rohde & Schwarz HMC 8012, digital multimeter with memory function
Thermal Imager:
1x Optris PI640 + 2x Xi400 Thermal Imagers
Pix Connect Software
Type K Class 1 thermal sensors (up to 4 channels)
Acoustics:
Creative X7, Smaart v.7
Own anechoic chamber, 3.5 x 1.8 x 2.2 m (LxTxH)
Axial measurements, perpendicular to the center of the sound source(s), measuring distance 50 cm
Noise emission in dBA (slow) as RTA measurement
Frequency spectrum as graphic
Os: Windows 10 Pro (1909, all Updates)
KFA2 GeForce RTX 2070 SUPER Work The Frames Edition, 8GB GDDR6, HDMI, 3x DP (27ISL6MD24WF)
Follow Igor:
