Case Reviews
Follow-up to the CORSAIR iCUE 5000T review – even more RGB with the LC100 Case Accent Lights!
Now we’re going full speed ahead! The already insane 208 LEDs of the 5000T are now joined by another 162 LEDS with the LC100 Case Accent Lights including expansion set. Thanks to the hinge-like magnetic connectors, the flexible triangles can take on all sorts of interesting shapes and, of course, glow in every color imaginable. Read what you can do with the small panels in our review.
If you are not a fan of excessive RGB lighting, you have to be very strong now. If I had already recommended wearing sunglasses for the Corsair 5000T, almost the same amount of colored LEDs is now added. The small triangles, which strongly remind of the well-known Nanoleafs for the wall, represent another individualization option for the computer.
Foreword
Before a discussion about the sense of such a product arises in the comments, I would like to explicitly point out here that this is a completely optional customization option. Whether you light your living room with a construction site lampholder or a designer lamp, equip your small car with 15″ steel rims or 17″ aluminum rims – such decisions are always a matter of personal taste and nobody is forced to buy or install something like that.
Unboxing
Before we delve deeper into the matter, let’s first free the whole story from its packaging.
The starter kit consists of nine magnetic triangles with nine LEDs each and the corresponding controller. It can be extended by nine additional triangles with the extension kit.
The expansion kit also actually consists of only the master and 8 normal modules.
Each module has contacts on two sides for the previous and subsequent module.
The connection is realized via magnetic contact rollers, which also act as a kind of hinge and bring some flexibility to the matter. The small connectors (left) offer slightly less play, while even 90° kinks can be realized with the larger connectors (right).
Both kits strung together, interesting constructs can be realized.
In principle, the master module can be located at any point of a 9-unit setup, but it is best to place it at the end or in the middle for easier configuration. More on this follows on pages two and three.
ipat66
1,546 Kommentare 1,610 Likes
Wer's braucht soll damit glücklich werden.
Mir wäre es das Geld nicht wert und ich kriege davon Augenkrebs !
Danke Alex für die Vorstellung dieses neuen RGB Fraktion Gadgets .
Was es nicht alles gibt....
ArcusX
960 Kommentare 567 Likes
Es ist und bleibt mir ein Rätsel warum man dafür Geld ausgibt. Irgendwann werden die Rechner leuchten wie Supernovae und dann wird eine Gegenströmung auftreten, bei der es dann darum geht die Rechner möglichst geräuschlos und dunkel zu machen.
Das klingt jetzt recht negativ, ist aber nicht so gemeint, dass man das Produkt nicht kaufen sollte. Ein jeder werde seelig nach seiner Facon.
E
Emmbot
23 Kommentare 7 Likes
Für das Geld kann man auch gerne Radiatoren kaufen dann wird es wenigstens leiser.
Die Lösung ist schon cool, aber ich steh eh nicht auf Computerdisco. Bei nem anderen Preis und mit Batterie wäre es was für die Kids zum spielen.
Megaone
1,920 Kommentare 1,835 Likes
Wo sind wir dann komplett? Bei 600 Euro für Tower sowie Starter und Erheiterungskit?
Der einzige der hier in die vollen geht, ist der Hersteller.
Die Herstellungskosten sollten Imho im unteren einstelligen Dollarbereich liegen. Zumindest hat der Hersteller einen Plan im Bereich Gewinnmaximierung. Der Preis ist sicher deutlich mehr als selbstbewußt.
Ich zitiere mich ungern selbst, aber mein Satz im letzten Thread:"Sind dann 600 Euro für einen Big Tower mit 50 LED`s mehr ein Schnäppchen?". war ja fast schon prophetisch.
Ok, zum Big Tower hat das schon nicht mehr gereicht. :ROFLMAO:
Aber so what, es gibt viele Möglichkeiten sein Geld an Tür und Fenster raus zu werfen. Diese hier leuchtet zumindest.
Wer auf sowas abfährt, hat ja jetzt was zu basteln.
Kolossus
56 Kommentare 16 Likes
Tja, meine Lieblingsfarbe bei einem Computer ist tiefschwarz
W
WeisserWalFisch
66 Kommentare 41 Likes
Sieht ja wunderschön aus aber ich bin zu alt für diese neumodischen Sachen.
RedF
5,270 Kommentare 3,068 Likes
Ich empfehle eine Dose Black 3.0 . Damit kannst du beinahe "Löcher" malen : )
Antwort 5 Likes
ssj3rd
263 Kommentare 184 Likes
Zeit für die Kiste würde mein Opa sagen 😉
v
vonXanten
831 Kommentare 364 Likes
Irgendwie beschleicht mich immer mehr das Gefühl das die Grenze nach oben nur noch der Himmel ist.
Stolzer Preis für ein wenig RGB in Dreiecksform.
@RedF eine echte Option und die gesparten Taler beim Gehäuse und dem Zubehör RGB dann in eine Wakü, dann ist auch Ruhe im "schwarzen Loch" ;) :cool:
RedF
Ich find diese Farbe total genial :D
v
vonXanten
@RedF hast du die schon verwendet? Ist die schwarzer als schwarz?
RedF
Ne, was man so online findet sieht schon gut aus.
Habe sie meiner Mutter zu Weinacht geschenkt, aber auf einem abstrakten Acryl Bild hatte es nicht so den effekt.
Denke gegenstände damit Konturlos zu pinseln macht da mehr her.
Megaone
Formulieren wir es mal ganz allgemein und selbstverständlich völlig unabhängig vom obengenannten Produkt.
Das ist das Problem an der "Political Correktness". Du darfst galoppierende Raffgier nicht mehr galoppierende Raffgier nennen und die Frage stellen, ob man möglicherweise einen Preis im Vollrausch mit einem Würfel zu viel ausgewürfelt hat.
Stattdessen werden solche Margenorgien mit positiven Attributen wie selbstbewußt oder sportlich etc belegt.
Bei einem beispielsweise fiktiven Produkt und einem fiktiven EK von 3 Dollar und und einem VK von über 200 Euro sind wir ja fast schon auf dem Niveau wo man früher mit unwissenden Schwarzafrikanern Glasperlen gegend Gold getauscht hat.
Wie man sowas positiv umschreiben kann, versteh ich nicht.
Natürlich braucht niemand so einen Produkt zu kaufen. Es ist ja am Ende eines langen Tages jeden freigestellt. Auch darf jeder alle legalen Produkte zu einem ihm beliebigen Preis feilbieten.
Nur die allgemeine Kritiklosigkeit zu so einem Treiben, erlaube ich mir mittlerweile als sehr beunruhigend zu empfinden.
Es täte mittlerweile meiner möglicherweise infantilen Einschätzung nach, nicht wenigen Herstellern gut, wenn Ihnen jemand entgegen stehen würde und die Dinge so formuliert wie sie Imho wirklich sind.
Dies wäre in der Tat die Aufgabe der Presse, von Magazinen, influenzern etc.
Aber das Thema ist definitiv durch. Ich habe vor nicht all zu langer erlebt wie diverse Influenzer plötzlich in Ihren Foren von "Fachleuten" angegangen wurden, weil sie im Hififbereich überteuerten Sondermüll als solchen mit gesetzteren Worten gekennzeichnet hatten.
Kurz darauf verschwanden die Artikel. Ich habs nur gemerkt. weil ich in Kommunikation mit Leuten in Kontakt stand.
Und wie lange solche Beiträge wie die meinen noch Geduldet werden, wird die Zeit erweisen.
v
vonXanten
@Megaone finde auch das der Preis hier sehr stoisch hingenommen wird.
Allerdings waren solche RGB-Platten schon immer alles andere als günstig und bei einem neuen Produkt kann der Hersteller ersteinmal ausloten was die Kunden bereit sind zu zahlen.
Ist inzwischen einfach nur noch die von Dollarzeichen in den Augen getragene Gier. Qualität und Haltbarkeit stehen da meist hinten an.
@wuchzael wie stark sind eigentlich die Magnete welche die Plättchen halten? Und wie schaut es mit dem Durchmesser der Verbinder aus, kommen die an das Gehäuse oder ist dort ausreichend Abstand zwischen.
Als letzte Frage, können die ein vernünftiges Weiß oder nur mit Farbstich? Kenne viele RGB Komponenten die das nicht können.
Kolossus
Richtig! Ein Computer muss rechnen, nicht blinken. Wenn ich bunte Beleuchtung haben will, greife ich zu Hue
W
WeisserWalFisch
Alt aber nicht veraltet :)
Alexander Brose
843 Kommentare 609 Likes
Moin!
Ich check das morgen alles mal, war total im Klausur-Stress (y)
Grüße!
Tronado
4,693 Kommentare 2,574 Likes
Naja, an den Dingern sieht man sich schnell satt. Meine Beleuchtung der Lüfter bleibt seit Wochen aus. Gute Hardware wird nie langweilig, Bling-Bling rasend schnell.
Alexander Brose
@vonXanten
So, jetzt endlich nochmal im Detail. Die Durchmesser der Verbinder liegen bei 4,0mm für die "schmalen" Verbinder mit großem Radius (eher als Verbinder gedacht) bzw. 5,5mm für die "dicken" Verbinder, die als Art Scharnier zum Überbrücken von Winkeln gedacht sind. Die Konstruktion ist dabei so ausgelegt, dass ein Kurzschluss eigentlich nur durch komplette Idiotie oder Vorsatz verursacht werden kann. Ich hänge dir mal ein Bild von einem 90° Winkel an (und bitte den Staub zu entschuldigen, das System läuft jetzt schon seit dem Gehäusetest quasi 24/7 ;) .
Bezüglich der Farben: "Weiß", also #FFFFFF ist schon relativ "sauber", geht aber auch hier leicht ins bläuliche. Es ist also ein sehr kalter Weißton, wenn auch nicht so extrem wie bei einigen anderen Herstellern, wo Weiß = Hellblau bedeutet (z.B. Logitech oder KFA2).
Ich hoffe das beantwortet deine Fragen 🙂
Grüße!
Alexander Brose
