It’s been a good year since we tested a small system from this manufacturer, but that changes today. So let’s start right away, if you want to refresh your memory of the last Mini-PC from ECS, you can do so here:
ECS LIVA One H610 Mini-PC Review – Barebone for 12th Gen Intel CPUs in a small space
The compact cardboard box is printed in black and does not reveal much information about the contents. As this system is available in different configurations, you have to make do with the key data on a small sticker.
Has anyone noticed that “Multi-functional” has been misspelled? It would be annoying if incorrectly printed packaging continued to be produced.
But as we all know, it’s the inner values that count, and everything seems to fit, with several small “compartments” separating the accessories and providing additional protection during transportation.
A VESA or wall mount, suitable screws and a 19V 90 Watt power supply from Huntkey are included. The plug for American households was supplied with my unit, fortunately the common C5 socket and a suitable cable can be found quickly on the power supply unit.
Specifications
Below is an overview of the key technical data, further information can be found on the manufacturer’s product page.
8 Antworten
