Cooling Picture stories Reviews Watercooling
CPU Water Block in Macro Shots – When the Mud (Basic Copper Carbonate) Strikes Again
I had recently received a CPU water block from the RMA of a friendly dealer, which I should investigate. Please “take a closer look”. That’s exactly what I did after my first inspection, because although you could see the dirt with the naked eye – how about some really fancy macro shots of the horror? And since there was just the chance to test a Keyence VHX 7000 digital microscope here in the lab, I naturally took it.
The metallic copper surface of such a cooler bottom runs through various phases of metamorphosis from a shiny block to a clogged crystal base, if not handled correctly. In our case, a cheap aluminum radiator and dubious coolant were said to have been in the system. Then it may well happen within a few months that the original copper first oxidises to copper(I) oxide (Cu2O) and then, under further sustained oxidation, is converted to green, basic copper(II) carbonate, which contains further additives such as sulphates or chlorides – depending on the composition of the coolant and the production residues in the radiator.
ro///M3o
384 Kommentare 278 Likes
Goil :geek: könnte man da denn noch irgendwas retten, mit Chemie z.B.?
Blubbie
809 Kommentare 275 Likes
Grusel zum Wochenende....
Bitte nicht nochmal. Hatte sowas 2019 bei meiner ersten großen custom loop. Die drei Radiatoren, zwei Kühlblöck und sonstigenTeile waren aber damals auch alle von AC.
Zum Glück hab es damals Garantie und die Vermutung war, dass ich beim Coolant fertig Gemisch von AC eine verunreinigte/ falsch gemischte...whatever Charge abbekommen hatte.
Ach die "glücklichen" AiO User die davon nichts mitbekommen..... Bis es zu spät ist. 🤯
Blubbie
Ja ideal wäre so ein Kalk/ Kristall.... Was auch immer Löser... Wir eine Geschirrspüler Tablette oder Kookident,🥳. Rein in den AGB... Mit 5 list destilliertem Wasser durchlaufen lassen und fertig.
Ich glaube nur dass zeug hängt echt fest. Selbst mit Zahnbürste schrubben ging das damals bei mir kaum von CPU Block ab. Außerdem setzt sich für Reaktion Fan nicht ewig für wenn die Nickel Schutzschicht erstmal an ist? 🤔
Guest
So sah meine SilentLoop 360 auch von innen aus. Dachte damals, das wären Algen. 🙈
Kaufst du billig, kaufst du zweimal.... ☝️
11,236 Kommentare 21,310 Likes
Mit Essig geht vieles wieder ab. Gegen Basen hilft Säure am ehesten - aber wohl dosiert. So ein Dreck wie Cillit Bang, was auf YT gern propagiert wird, ist absolut tödlich und frisst sich richtig rein. Waschmittel ist auch eine Option, ich hatte auch schon mal Fleckenlöser getestet. Aber das Wichtigste kommt immer zum Schluss: Spülen, bis der Onkel Doktor kommt!
B
BadWulf
2 Kommentare 0 Likes
Bis 2011 war ich auch Waküinfiziert, allerdings hatte ich dahingehend wohl immer Dusel (das richtige zueinander gekauft) gehabt.
Wasserwechsel gab es nur alle 3-4 Jahre, aber der Mora Radi und die Kühlblöcke waren tip top. ^^
Igor, wie verhält es sich mit AIOs. Ich habe den Arctic Cooling Liquid Freezer 2 420 verbaut. Top Leistung und dabei verdammt leise, aber relativ günstig, meinst du, der könnte langfristig Probleme bekommen?
RedF
5,249 Kommentare 3,038 Likes
Ja Essigsäure und Ultraschall putzt das Zeug gut weg.
Antwort 4 Likes
Guest
Hab es noch wieder gefunden...
Meine damalige SilenLoop von Innen... brrrr... die Anschlüsse am Radiator bröselten schon etwas.
N
NilsHG
91 Kommentare 53 Likes
Hallo Igor,
bei mir steht auch bald ein Umbau der Wakü mit Grundreinigung an. Schläuche werden getauscht, der Rest gereinigt.
Spülen der Komponenten... geht das mit Leitungswasser?
Danke und Gruß
Nils
k
krelog
174 Kommentare 53 Likes
@Igor Wallossek was ist denn mit "geschnitten (nicht gefräst) " Kühlkanälen gemeint ?
D
Dennis TeCheXperience
188 Kommentare 10 Likes
"Cillit Bang und dann streiten se sich noch um die Farbe", hab herzhaft gelacht eben beim Video schauen :D
Gruss Dennis
M
MHoppe
27 Kommentare 9 Likes
Ich glaube die einzige AIO mit Kupfer Radiator ist die Eisbaer Extreme, kann das sein?!
RedF
Ich glaube alle von Alphacool sind Kupfer. Hatte eine Eisbär LT und das war alles Kupfer.
big-maec
994 Kommentare 601 Likes
Das Problem hatte ich die letzten Jahre mehrfach auch, aber jetzt scheint es vorbei zu sein.:D Am schlimmsten finde ich das bei den AIO, habe hier noch Teile davon rumliegen.
Îst im Video erklärt
Unterfranke
173 Kommentare 178 Likes
Ein Artikel wie man ihn nur bei dir findet - Danke Igor für die Aufarbeitung mit sachkundigem Tiefgang.
M
Mausmaki
15 Kommentare 4 Likes
Wunderbarer Artikel! Danke dir Igor für diese traumhaften, schmodderigen Einblicke zum Valentönstag morgen :D
Persönlich finde ich es immer wieder erheiternd, wenn Leute sich eine Wasserkühlung zusammenzimmern und ihren Lebtag offenbar in der Schule in Physik und Chemie geistig in den Wolken verpennt haben.
Dieser Artikel ist ein Musterbeispiel!
Elektrochemische Grundlagen der Korrosion -> Mittelstufe wenn ich mich recht entsinne?
(erzähl nochmal einer, dass in der Schule nichts fürs Leben (oder den Geldbeutel) gelehrt wird)
oder die Helden, die irgendwelche Farbstoffe/ Farbperlen in ihr Wasser packen und sich wunndern, dass die Pumpe verschlammt oder der CPU Block sich zusetzt und keine Arbeit mehr tut xD
Emploi
5 Kommentare 1 Likes
Geht alles ;) 5 Jahre nur deionisiertes Wasser, ohne Zusätze... Erstaunlicherweise hat der KyrosXT immer noch den 4770K so gut gekühlt, dass er unter Volllast nicht ins Temp-Limit gelaufen ist. Vor einem Jahr wurde der zuhe Wasserfilter ausgebaut, ca 1 Jahr später hat dann der CPU Kühler die Filteruntg übernommen, siehe Bilder. Aus der Wasserleitung kamen aber auch nur noch ein ganz schwacher Strahl, das Ding war fast zu.
k
krelog
habe es mir angeschaut aber du sagst da auch nur es wird "geschnitten" damit kann ich jetzt rein technisch nichts anfangen.
Wird das Material verdrängt oder verdichten das ein Kanal entsteht?
Oder wird das Material spanend entfernt das die Kanäle entstehen?
Follow Igor:
