Aircooling Cooling Reviews
Cooler Master MasterAir MA824 Stealth Review – A new, brute top performer
The last time we tested a MasterAir air cooler, it was already of considerable dimensions and offered quite a bit of cooling performance. And now, just over 2 years later, there is a successor that is supposed to offer even more? Let’s take a closer look at Cooler Master’s new flagship! If you would like to read the first review in advance, you can find the predecessor here:
Cooler Master MasterAir 624 Stealth CPU air cooler in test- A dark threat in large
A big cooler needs a big box, that’s for sure. The black-purple box is kept in the usual design of this manufacturer and proudly presents the contents on the front.
The back and the sides already show the first details of the content, but they will be shown here later in table form.
Due to the high weight, the MA824 must be well protected during transport in any case, Cooler Master has decided to wrap it in foam here. From above, the cardboard box with the accessories also offers some protection.
This turns out relatively normal, the various mounting materials for the various sockets, fan clamps and a 4-pin PWM splitter are included.
Mounting and installation
Depending on the socket, the appropriate frame is mounted on the socket with spacers. Thanks to the two long screws, which are carried out to the top cover, then only the cooler itself must be screwed tight.
Specifications
Below are the technical details from the press material, more information on the product page by the manufacturer.
Cooler Master MasterAir MA824 Stealth (MAM-D8PN-318PK-R1)
AlternateAuf Lager89,90 €*Stand: 17.06.25 00:42
Caseking.deLagernd89,90 €*Stand: 17.06.25 00:48
e-tec.atVersandlager: ca. 2-3 Werktagen versandbereit, Lieferzeit 3-4 WerktageLinz, Salzburg, Wels: 2-3 WerktageZentrale Timelkam: ca. 2 WerktageDornbirn, Graz Nord, Graz Süd, Innsbruck, Klagenfurt, Villach, Wien 15, Wien 20, Wr. Neustadt: 1 WocheStand: 16.06.25 23:3392,45 €*Stand: 16.06.25 23:37
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
125 Antworten
Tim Kutzner
998 Kommentare 824 Likes
Alternativ auch zum Erschlagen von Einbrechern verwendbar, wie mein Opa immer sagte :D
Derfnam
7,517 Kommentare 2,035 Likes
Besonders, wenn er schon eingebaut ist. Und RGB stealtht ganz doll...
Sooo teuer ist der auch nicht, wenn man die stolthen Preise einiger Noctuas hernimmt.
DrDre
356 Kommentare 195 Likes
@Derfnam
Der hat kein RGB. Verlinkt ist die 30 Jahre Geburtstagsversion
und der 624 auf der letzten Seite.
Tim Kutzner
Richtig, Geizhals führt nämlich die "richtige" Variante noch nicht
Derfnam
Dascha mal blöd. Wie findet Opa den dann???
Case39
2,686 Kommentare 1,053 Likes
Wie schwer ist er denn überhaupt?
DrDre
Ghoster52
1,690 Kommentare 1,355 Likes
Gegen den Meinungsverstärker 2000 sieht der Kühler aber kein Land.... :ROFLMAO:
Antwort 6 Likes
Case39
Diese Leichtigkeit des Seins..
Derfnam
Und der Jammerlappen in den Kommentaren soll sicher das mit der gekochten Banane testen, oder?
Lagavulin
316 Kommentare 265 Likes
Vielen Dank für den Test!
Eine Bitte hätte ich: Wäre es möglich, bei Luftkühler-Tests die RAM-Kompatibilität anzugeben? Klar, man kann auf der Herstellerseite nachschauen: Mit Lüfter 42 mm, ohne Lüfter 67 mm. Wäre trotzdem schön, die Info hier zu finden.
https://www.coolermaster.com/de/de-...olers/masterair-ma824-stealth/#specifications
Tronado
4,999 Kommentare 2,799 Likes
"den ersten Platz unter den Luftkühlern sichern" - aber nur unter den hier bei dir getesteten. Wo bleibt denn der aussagekräftige Vergleich mit einem der bisher besten Kühler? Eben ein Assassin III oder NH-D15, habe ich schon mehrmals geschrieben und werde ich auch immer wieder schreiben.
Lagavulin
@Tim Kutzner
Falls Du Interesse hättest, einen Noctua NH-D15S zu testen, kann ich Dir gerne einen für den Test zur Verfügung stellen. Ich würde auch die Rücksendekosten übernehmen und kann auch gerne ein paar Monate auf die Rücksendung warten, weil der Noctua (übrigens nagelneu in OVP) bei mir sowieso nur im Schrank liegt und auf einen Lüftkühlungs-Build wartet (sicher nicht vor Jahresende). Und mit Kratzern hätte ich auch kein Problem. So ein Kühler ist ein Arbeitstier und nicht für die Vitrine. Melde Dich bei Interesse gerne per PM.
Nachtrag 1: Ich habe nix mit der Firma Noctua zu tun, außer dass ich ein paar Produkte (Lüfter) von denen gekauft habe.
Nachtrag 2: Ich habe auch als zweiten Lüfter den passenden NF-A12x25 dazu.
midwed
45 Kommentare 12 Likes
Vielen Dank für den Test :) Schaut gut aus, sowohl optisch (meine Meinung) als als leistungstechnisch - kommt auf die persönliche Liste der pot. Kandidaten, sollte mal ein neues System zusammengebaut werden ;]
Kolossus
56 Kommentare 16 Likes
Irgendwie erinnert mich das Teil an den BeQuiet DarkRock 4 pro, der allerdings für 250 Watt ausgelegt sein soll....
Tim Kutzner
Assassin III hatte ich sogar schon im Test, aber auf der alten Testbench:
Spare ich mir jetzt aber auch nochmal zu testen, der Assassin IV ist schon auf dem Weg zu mir :)
Tim Kutzner
Mit Noctua habe ich einen guten Kontakt und bekomme bei Bedarf Kühler, hat sich bisher aber einfach noch nicht ergeben :D
Hatte ein wenig auf neues Futter von der Computex gehofft, aber die brauchen noch etwas mit der Next Gen ...
Tim Kutzner
Bei 200 Watt und meinem 3950X ist bei praktisch allen Luftkühlern Obergrenze und man liegt schon bei 90°C+ beim CPU Die, der DRP4 eingeschlossen.
Für 250 Watt Abwärme wurde ich nicht mehr auf Luft setzen
Tronado
Gut, falls weiterhin alternative Lüfter auf den Kühler passen, sonst ist das nichts für mich zum Rumprobieren.
Aber der gut zum vorderen und hinteren Turm abschließende mittlere Lüfter könnte natürlich was bringen.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
