Little space, little bass? If you are struggling with your limited living space or simply don’t want to have visible subwoofer cubes, you can breathe a sigh of relief. The Nubert nuSub XW-800 Slim likes to duck away, sometimes crawls under the sofa or stands upright next to a sideboard, as if the bass reflex tube wanted to sniff the high altitude air. With its unusual shape, which by the way does not detract from the function, the hip flask is the ideal bass-to-go furniture for those for whom smart terrain gains are more important than martial looks. You get the part in the usual sanded varnish finish in black or white, it doesn’t get more colorful.
Of course, an active bass reflex subwoofer in such a flat design only works in its primary position with the downfire principle and a chassis with a lot of excursion. Here, the chassis radiates towards the installation surface and the resonator including the opening is then located 90 ° to the side. However, you can also place the subwoofer upright and operate it “classically”. Of course, there are also a few sentences when it comes to functionality and sound. But it’s nice that it’s finally here. Of course, it’s now easy to satisfy curiosity as to whether such a concept will work out. It is certainly a bit of a niche, but it is also really cleverly positioned, because there are currently no serious alternatives. And that is precisely the point.
Scope of delivery and technical data
But despite the somewhat different shape, you don’t have to do without anything else either, because the X in the name refers to the new connectivity in Nubert’s acoustic activist brigade. But there are also a few sentences about this in the appropriate place in the article, because we have to unpack everything first before we start packing. And well, so the part is packed as always exemplary, so that is actually no problem with the stunning transport service provider. Outside everything was a bit scuffed as usual, but the cardboard is shockproof enough and so is the foam corset inside.
And what do you get now for the 585 euros in the Nubert store (direct sales, no affiliate)? The subwoofer, but that was obvious. There is also a kind of quick start guide, the power cord, an analog 2-to-1 RCA cable with angled plugs (well solved)and a set of screws + dowels for optional wall mounting. Here, however, I would better first make sure which building material the wall in question is made of. The fastening would even work on gypsum cation, but then please with four individual heavy-duty dowels.
That’s about it and we can now quickly look at the technical data before I continue.
By the way, the user manual is not only practical for the end user, because it saves me a huge wall of text with just a few pictures.
Manual EN
42 Antworten
