UL, a leader in benchmarking and testing, today announced news. They have released a new functional test for AMD FidelityFX™ Super Resolution (FSR) upscaling technology. AMD FSR technology is an advanced method for improving image quality in video games. This is a type of upscaling technology that allows low-resolution games to be displayed on higher resolutions without degrading image quality.
The new AMD FSR feature test for 3DMark® is now available in the 3DMark Advanced and Professional editions. With this new functional test, users can test and compare the performance of their systems using AMD FSR technology. This is especially relevant for gamers and computer enthusiasts who are looking for a powerful and smooth experience when playing video games. The release of this functional test shows that AMD continues to strive to improve its products and optimize the experience of its users.
The AMD FSR Functional Test is a tool that helps compare the performance and image quality of AMD FSR 2.2 technology by comparing it to a traditional rendering approach with Temporal Anti-Aliasing (TAA). The technology uses algorithms to deliver games in higher resolution and frame rate without overloading the GPU. The functional test also includes the 3DMark Frame Inspector tool, which allows comparing the image quality with an interactive direct comparison of AMD FSR 2 technology and native resolution rendering.
This displays the image quality of both rendering methods side by side in real time, so you can see exactly which method offers the better image quality. Through the AMD FSR function test, you can also compare the performance of both methods to find out which method offers the higher frame rate and performance. This can help find the optimal setting for the system and achieve the best possible gaming experience.
The AMD FSR function test is a free update for the 3DMark Advanced and Professional Edition. These editions can be purchased either on Steam or directly on the UL Solutions Benchmarks website. The Advanced and Professional editions offer additional features and options compared to the basic version. The test is free and available to all 3DMark Advanced and Professional Edition users. Users can download and run the AMD FSR Functional Test to see how well their hardware handles AMD’s FSR technology. By performing the test, users can ensure that their system is optimally configured to use FSR and that they will enjoy the best possible gaming experience.
If you already own 3DMark and purchased the program before October 12, 2022, you will also need to purchase the Speed Way upgrade to unlock the AMD FSR feature test. This extension allows the user to activate the AMD FSR function test and thus test its performance. To get more information about updates and upgrades for 3DMark, it is recommended to click on the provided link that leads to a corresponding page. On this page, users can learn what options are available to update their 3DMark software or upgrade to a higher version.
To run this test, you need a graphics processor that supports AMD FSR 2 technology. FSR stands for “FidelityFX Super Resolution” and is an open-source technology developed by AMD. It makes it possible to increase the resolution of games without affecting performance. This results in higher image quality at the same frame rate. FSR supports a wide range of graphics processors from all manufacturers. A list of officially supported GPUs from all manufacturers can be found in the 3DMark user manual. This list contains all graphics cards that support FSR and which FSR modes are available for the respective GPU.
Source: ULSolutions, AMD
11 Antworten
