Case Practice Reviews
The Sharkoon M30 RGB PC Case Review – Good and cheap for entry-level and mid-range PCs
If you’re looking for a case to build your PC, you’re literally overwhelmed by offers. You could spend days researching, only to still not really know in the end: does the case fit in the end, or not? At the beginning there is always the question about the form factor: ATX, mATX or maybe mini ITX? The next question is: RGB optics yes or no – i.e. glass windows? Whereby you can also create a nice open look without RGB. Are you guys also concerned with a standard ATX case? The Sharkoon M30 with and without aRGB is quite a worthwhile offer, which we will take a closer look at today.
The packaging is typical for Sharkoon and ensures safe transportation. So that even the tempered glass does not arrive at your home as confetti. Judging by the deformation you can see on the packaging, I wasn’t quite sure if the glass was still intact. If you uncover the case, you will basically see a normal ATX case.
For today’s review, Sharkoon provided me with the RGB variant, although I’m also looking at the whole thing vicariously for the non-illuminated variant. The only difference in the end is that you don’t get a glass pane and aRGB HUB. The non-RGB version also costs a bit less.
Not a total loss! You currently pay 69 Euros for the Sharkoon M30 and the aRGB variant costs about 77 Euros. In both cases, Sharkoon installs one fan in the front and one in the rear. You get USB-C, 2x USB-A 3.0 and audio on the front panel. All other information can be found here: Click!
ds_M30_RGB_de_01
Let’s take a look at the workmanship, build and functionality of the case. Next page…
Megaone
1,919 Kommentare 1,830 Likes
Guter Test und gutes Gehäuse, wem der Platz reicht. Und der passt ja für die meisten. Der Preis erscheint mir unterm Strich auch OK.
Ich würde mich mal über einen Vergleichstest der großen Gehäuse freuen. Wer eine komplette Wakü mit genug Reserven unterbringen will, erlebt sowas wie die Irrfahrten des Odysseus. Ich bin von einen Nanoxia deep silent 5 zu einem Define 7XL zu guter letzt bei einem Coolermaster Haf 700 Evo gelandet. Und jedesmal dachte ich, ich hätte die nächsten 10 Jahre Ruhe.
Derfnam
7,517 Kommentare 2,033 Likes
Ghoster52
1,575 Kommentare 1,268 Likes
Sehr schöner Test... (y)
Teile auch deine Meinung, ich würde ganz klar wegen der Luffis zum TG7M greifen.
p
pedi
273 Kommentare 73 Likes
und wieder ein gehäuse mehr, in das man keinen brenner einbauen kann-nichts für mich.
LEIV
1,604 Kommentare 681 Likes
brenner? du meinst ein CD/DVD/Blu-ray Laufwerk?
Für mich sind seit über 10 Jahren Laufwerkschächte Ausschlusskriterien für Gehäuse - hier stört mich eher das nur 120mm Lüfter rein gehen, bzw nicht genug 140er
Megaone
Nö, das Wort ist Odysseus.
Odysseus (episch altgriechisch Ὀδυσσεύς Odysseús) ist ein Held der griechischen Mythologie.
Das entspricht am Ende auch meiner Selbstwahrnehmung. :cool:
Derfnam
Im Alter lässt's nach, ist bekannt.
Odyssee = sowas wie die Irrfahrten des Odysseus.
onyman
254 Kommentare 137 Likes
Wie unterschiedlich doch die Ansichten sein können.^^
Das Gehäuse umfasst 50 Liter Volumen, das sind 5 Eimer Wasser (Galileo kann das bestimmt noch in Fußballfeldern angeben). ;) Alles andere als kompakt und trotzdem kein Platz für ein 5,25" Laufwerk gelassen.
Ich mag die Sharkoon Produkte, auch die Gehäuse gefallen mir. Hatte schon zwei in den Fingern und war bei beiden mit den Details sehr zufrieden. Aber Wünsche wie o.g. 5,25" LW oder ein oben liegendes NT sollte man besser nicht haben. 🤷‍♂️
Y
Yumiko
782 Kommentare 362 Likes
Naja, mit den BR M-Discs lassen sich private Datensicherungen ganz hervorragend machen. Natürlich geht das auch mt einem externen Laufwerk.
Pascal TM-Custom
1,122 Kommentare 1,362 Likes
Laufwerkschacht oder SD Karten Schlitz braucht man meiner Meinung gar nicht mehr in einem Case. Es gibt Externe Lösungen für Apfel und ein Ei als USB Lösung.
Dazu kommt viel weniger Kabel gewurschtel im Case. Der Großteil der Softwares gibt es als Digitalkauf, selbst Hersteller wie Asus, MSI usw. legen mittlerweile nicht mal mehr eine CD bei bei ihrem Mainboard.
Und sollte man jetzt wirklich mal ein Laufwerk brauchen für 25€ gibt's USB- Laufwerke.
Antwort 4 Likes
Derfnam
Im Englischen gibt es 'Don't patronize me' als Antwort auf sowas.
So: just don't.
Pascal TM-Custom
kann jeder für sich halten wie er will :)
Derfnam
Kann man sogar für sich behalten.
Megaone
Naja, ich bin ja auch ziemlich Oldschool unterwegs, aber von internen Laufwerken hab ich mich komplett verabschiedet. Für die paar Anwendungen die ich noch 2 x im Jahr hab, reicht ein externes völlig.
Was den Platz angeht, bin ich wie gesagt beim Coolermaster Haf 700 Evo angelangt. Hat aber irgendwie was mit Alter zu tun. Je älter ich werde, desto weniger Kompromissbereit bin ich.
Pascal TM-Custom
Ist aber auch ein Monster nächste Stufe wäre eigentlich nur noch das Corsair Obsidian 1000D 🙈
Megaone
Das stimmt, aber ich war es echt satt. Ich will gut und einfach ans Netzteil ran und brauche Platz für das Kabelmanagement sowie die Radiatoren für die WAKÜ.
Das Define 7XL ist schon Ok, aber eignet sich nicht wirklich für mehrere 60er Radis und das Corsair 1600i NT braucht echt Platz. Mit Wasserfilter, Durchfluss- und -Temperatursensoren sowie diverse hubs und Aquasuite etc. wird die Luft schnell dünn.
Pascal TM-Custom
im Obsidian kannst meines Wissens 4x60mm einbauen 2x480 und 2x360 Bei Push Pull wird das witzig mit dem Kabelsalat :D
Das Case betrachtet man nur die reine Radi Fläche bist auf dem Stand eines Moras nur im Case drin.
Wenn du das Case voll machst brauchst jemand der mit dir das Teil Transportiert. 🙈
Ich könnte eines haben für Video aber nää danke danach brauch ich einen Gabelstapler um das zu drehen und wenden für die Aufnahmen.
BTW. Hab gestern das neue Phanteks NV7 bekommen.
Wird auch noch interessanter Artikel.
H
Helldog38
47 Kommentare 19 Likes
Ich hab das Gehäuse auch zum Test bei mir stehen (Testen, Bewerten, Behalten von Alternate)
An sich ein schönes Gehäuse, nur warum RGB, wenn dann nur der hintere Lüfter in RGB Ausführung ist.
Ausserdem war dann auch zu wenig Platz für meinen Macho Luftkühler.
Ich hatte dann ein Sharkoon Netzteil installiert und hab dann unten durch die Öffnungen für die Kabel nix mehr durch bekommen.
Da ist der Platz einfach zu knapp.
Wenn jemand das Gehäuse haben will. Steht günstig zum Verkauf. 😁
F
Furda
663 Kommentare 375 Likes
Sehe ich das richtig? 45 Grad C im Gehäuseinneren? Ist ja erst März, Sommer kommt noch....
Fritz Hunter
