Case Reviews
SHARKOON TK5m RGB Review – Compact budget case for ATX motherboards
As a constant in the budget segment, Sharkoon always knows how to surprise with unexpectedly good quality and excellent value for money. In this test, we want to find out whether the compact TK5m can do the same. Can you expect anything at all at a price of around 65€ despite four pre-installed ARGB fans?
The market for inexpensive cases is gigantic. This has a big advantage for PC hobbyists: Cheap cases can be found on every corner and every manufacturer tries to advertise their own product with a unique selling point. Sharkoon therefore equips the small TK5m with four ARGB fans and even adds a USB Type-C port in the front I/O.
Sharkoon provides a small teaser on their Youtube channel:
Unboxing and Hands-On
Let’s take a look at what Sharkoon has conjured out of the hat this time. The box is adorned with a product image, and I like the design in black and white.
Here I had to smile briefly. Let’s unleash the shark in us!
Stripped of all cardboard and polystyrene, the TK5m already looks very compact.
The glass panel is of decent quality with a thickness of 4mm, there is nothing to complain about.
The interior is clean and evenly painted.
There are also openings everywhere at the rear where air can enter or leave (depending on the fan configuration).
The right side panel is “bulged out” to hide the cables underneath. When it comes to cable management (installation report), you will notice that this is not necessarily the best solution.
Everything on the back of the motherboard is easy to reach, and the cut-outs are sufficiently large.
Nice detail: The power supply is “mounted” on thick foam rubber pads to prevent the transmission of vibrations.
The front is almost completely made of mesh, and the fans can draw in fresh air unhindered.
For cleaning, the cover can be pulled off with a hearty tug.
There is an additional magnetic dust filter in front of the pretty fans. If you’re afraid that the system won’t get any air with this filter, just leave it out.
The front I/O is well equipped for this price range with 2x USB 3.0 and 1x USB Type-C. The reset button is connected to the integrated RGB controller as standard, which I will talk about later.
Accessories include the usual mounting hardware, a 3.5″ slide, an instruction manual and a set of stickers.
d
dman
180 Kommentare 107 Likes
Good Morning☕
Dank dir für den Test,kannst du bestätigen das es sich um diese vorinstallierten ARGB Lüfter handelt?
Mit 34€ nur für die Lüfter ist das komplette Gehäuse ja ein superschnappa,ich mag Sharkoon Gehäuse und hab schon etliche im Bekanntenkreis verbaut.
Gruß
RedF
5,254 Kommentare 3,042 Likes
Sharkoon hat sich über die jahre echt gemacht.
Anfangs war das nur bei Alternate zu bekommender schrott.
F
Furda
663 Kommentare 375 Likes
Scheint ein nettes Case zu sein, das für den Preis Einiges bieten kann.
Der Fractal Aspect 12 RGB sollte mit dem kleinen Stecker auch direkt am Mainboard Header verbunden werden können, zudem sollte Daisy Chaining möglich sein, um zb die drei Front Lüfter gemeinsam zu verbinden und ansteuern. Auch wenn es nur zwei Pin sind, also weder Tacho noch PWM, dürfte eine reine DC Regelung vielleicht möglich sein, Anlaufspannung ist gemäss Specs 7V. Nicht? Wäre dann bezgl Lautstärke sicher besser.
Megaone
1,913 Kommentare 1,823 Likes
Für den Preis geht das Gehäuse komplett in Ordnung. Nicht jeder will 200+ für eine Gehäuse ausgeben. Und solange man keinen wassergekühlten High-End Pc bauen will, bekommt man für 69 Euro so ziemlich alles, was man braucht.
T
TeKila
25 Kommentare 11 Likes
Einfach den inneren PIN im "Lüfter"-Molex Stecker nach außen versetzen, schon laufen die Lüfter mit 7V (y)
RX480
1,914 Kommentare 899 Likes
Ich hatte früher mit Crossfire auch ein Sharkoon.
weil
ggü. der beiden Grakas@radialOUT die 2x Seitenlüfter IN ganz nützlich waren.
ergo
Sharkoon, please back to the roots without glass
und
bitte dafür zusätzlich noch wieder Seitenlüfter
btw.
Ne interessante Diskussion "zu ner offeneren Seitenwand" gibts momentan bei CB im Thread.
Alexander Brose
