GPUs Graphics Reviews
Sapphire Radeon RX 5700 XT Pulse Review – Navi with certain vibrations
Sapphire's first Navi card is with the Pulse actually the entry model, if one follows the previous nomenclature of the manufacturer. This also entails compromises and today we will sound out which and what this means for the customer.
The title sounds funny? I’ll come back to that, I promise. But first, we’ll look at the exterior and data of the dual BIOS card. At least that’s where Sapphire didn’t save money. Compared to the already tested Red Devil by Powercolor and the Evoke by MSI (including the efficiency mod), the Pulse has to make a lot of effort. But always nice one after the other…
In order to make the whole thing a little clearer and to get to the point a little bit more, I have kept the structure of the articles to a large extent, but now I rely more on tables with clear representation of the result values and specifications, which later also guarantee a better comparison of the cards among themselves.
Technical data and picture gallery
The design is based on older Pulse versions and is not really new. Sapphire has probably done without LEDs for reasons of cost. This isn’t really a disadvantage, as there are enough interested people for a darkroom in a closed case. If you don’t have a transparent side panel: here’s a card without a squeaky colorful photon gun.
Matching the promised overview of the most important features:
Length (outer edge of slot bracket to end of card)25,5 cm
Installation height (upper edge of PCIe slot to upper side of card)12,8 cm
Front mounting depth (cooler body to underside of circuit board)4,0 cm
Rear mounting depth (board to outside of backplate)0,5 cm
Weight919 g
ShroudAnthrazit
ABS
Keine LED
Connectors3x DisplayPort 1.4
1x HDMI 2.0
Other FeaturesDual-BIOS with Silent-Mode
An initial overview of the further technical data of both BIOSes is provided by our MorePower Tool. First the similarities, which are the same in both settings:
Now let’s get to the power and the voltages, where there are some slight differences. On the left the OC (Standard) BIOS 1 and on the right the silent version from BIOS 2:
There are hardly any differences with the fan settings, only the target temperature is set somewhat lower with the silent variant:
Die Tabelle gibt noch einmal einen schönen Überblick über die restlichen technischen Daten der aktuellen und der älteren Vergleichsmodelle:
DataAMD Radeon
RX 5700 XT
Sapphire
RX 5700 XT Pulse
AMD Radeon
Vega 64
AMD Radeon
RX 5700
AMD Radeon
Vega 56
Architecture (GPU)Navi 10Navi 10Vega 10Navi 10Vega 10
CUDA Cores / SP25602560409623043584
(40 CU)(40 CU)(64 CU)(36 CU)(56 CU)
Texture Units
160160256144224
Texture Fillrate (Gtexels/s)304.8326.2395,8248,4330
Base Clock Rate (MHz)16051422127414651156
Boost Clock Rate (MHz)1755 (typisch)
1905 (max.)
2044 (max.)15461625 (typisch)
1725 (max.)
1471
Memory8 GB GDDR6
14 Gbps
8 GB GDDR6
14 Gbps
8 GB HBM8 GB GDDR6
14 Gbps
8 GB HBM
Bus (Bit)25625620482562048
Bandwidth (GB/s)448448483,8448410
ROPs6464646464
L2 Cache4 MB4 MB4 MB4 MB4 MB
TGP/TBP225 W250 W295 W185 W210 W
Mrd. Transistors10,310,3 12,510,312,5
Die (mm²)251251495251486
Node7 nm7 nm14 nm7 nm14 nm
MultiGPUDX12/VulkanDX12/VulkanCFDX12/VulkanCF
Test system and measurement methods
The test system and methodology are well known, but since I now test independently here in Germany, the test system has also been upgraded again without having to consider the former US colleagues.
The summary in tabular form offers interested parties a quick overview:
Test System and Equipment
Hardware:
Intel Core i9-9900 KF
MSI MEG Z390 ACE
2x 8GB KFA2 HoF DDR4 4000
1x 1 TByte Patriot Viper (NVMe System SSD)
Seasonic Prime 1200 Watt Titanium PSU
Cooling:
Alphacool Eisblock XPX
5x Be Quiet! Silent Wings 3 PWM (Closed Case Simulation)
Thermal Grizzly Kryonaut (für Kühlerwechsel)
Case:
Lian Li PC-T70 mit Erweiterungskit und Modifikationen
Modi: Open Benchtable, Closed Case
Monitor:Eizo EV3237-BK
Power Consumption:
Non-contact direct current measurement on PCIe slot (riser card)
Non-contact direct current measurement at the external PCIe power supply
Direct voltage measurement at the respective connectors and at the power supply unit
2x Rohde & Schwarz HMO 3054, 500 MHz multichannel oscilloscope with memory function
4x Rohde & Schwarz HZO50, current clamp adapter (1 mA to 30 A, 100 KHz, DC)
4x Rohde & Schwarz HZ355, probe (10:1, 500 MHz)
1x Rohde & Schwarz HMC 8012, digital multimeter with memory function
Thermografie:
1x Optris PI640, 2x Xi400 Thermal Imagers
Pix Connect Software
Akustik:
Creative X7, Smaart v.7
own anechoic chamber, 3.5 x 1.8 x 2.2 m (LxTxH)
Axial measurements, perpendicular to the centre of the sound source(s), measuring distance 50 cm
Noise emission in dBA (slow) as RTA measurement
Frequency spectrum as graphic
BetriebssystemWindows 10 Pro (1903, all Updates)
This website is using cookies to improve the user-friendliness. You agree by using the website further. Privacy policy
