The Shure Aonic 50 is a circumaural wireless headset with active noise cancelling and is said to offer studio quality. At various retailers you can buy this headset for around 300 Euro. The RRP of Shure is 369 Euro, but a look at the website shows that the RRP has been lowered to 319 Euro.
Scope of delivery
The package includes the headphones, a carrying case, the 3.5mm jack cable, and a USB Type-C charging cable – that’s all you’ll find in the box. The most important data are written on the back of the packaging box. This is sufficient and appropriate. but that’s all.
Optics and haptics
As soon as you unpack it and hold it in your hand, you immediately notice that the Aonic 50 is a truly premium product. The design is very modern and the materials used are of high quality. The headband is made of aluminium.Mix, the faux leather is high quality and it surrounds the soft padding on the ears as well as the top of the head. The whole thing is then elegantly rounded off with decorative stitching. The plastic that hides the technology is also very high quality in its appearance. The Aonic 50 is available in 3 colors: white, black and the brown version shown.
The look and feel of the Aonic 50 are very good. The materials used are of high quality. The weight is 334 grams and it is therefore not a lightweight. The weight is compensated by the high wearing comfort, because nothing presses and pinches even after 2 hours. But more about that on the next page.
Technical data and operating instructions
Model/Model: | SBH2350 |
Transducer type: | Dynamic, neodymium magnet |
Driver Size: | 50 mm |
Frequency Response: | 20 to 22,000 Hz |
Sensitivity at 1 kHz: | 97.5 dB/mW |
Impedance at 1 kHz: | 39 Ω |
Maximum input power: | 100 mW |
Weight: | 334 g |
Gain: | +2.05 dBi |
Operating frequency Radio: | 2402 MHz-2480 MHz |
Modulation type: | FHSS RF output power +4 dBm ( EIRP) |
Supported Codec: | ptX, aptX HD, aptX Low Latency, SBC, AAC, LDAC |
SBH2350_guide_de-DE (1)
