NVIDIA has released the first performance numbers for the upcoming game Alan Wake 2. The game will feature full path tracing and support for DLSS 3.5. An NVIDIA GeForce RTX 4090 is expected to reach over 120 FPS at 4K, but only using the full feature set including Frame Generation. Alan Wake 2 is thus now one of two games to fully utilize NVIDIA’s new visual technologies, including DLSS 3.5 and RTX Path Tracing. So effectively the next showcase after Cyberpunk, but from launch also with FSR2 for the rest of the world. If discussions should arise…
DLSS 3.5 Ray Reconstruction will replace two denoisers in Alan Wake 2 with an AI-driven algorithm that accurately calculates ray tracing and delivers better visual fidelity and even better performance. If DLSS Ray Reconstruction is disabled or unavailable, there are at least fallbacks. NVIDIA has also revealed the exact details of each ray tracing preset and how each setting affects it. When RT is set to low, no path tracing is used, as at least a “Medium” setting is required to enable partial path tracing.
As for performance numbers, NVIDIA has released some benchmarks within Alan Wake 2 running on different GeForce RTX 40 series cards. These numbers are for DLSS 3 Super Sampling and enabled frame generation, hence the higher, up to 4x increases. At 1080p, the RTX 40-series delivers up to 190 FPS at maximum settings. For 1440P, you get 80 FPS on RTX 4070 and higher with the same settings, while NVIDIA recommends using a 4070 Ti or higher for Ultra HD. The NVIDIA GeForce RTX 4090 achieves over 120 FPS at 4K resolution, while the RTX 4080 and RTX 4070 Ti see a 4.7x boost using frame generation and deliver 80 FPS and above.
- At Ultra-HD, with all settings at maximum and real-time ray tracking fully enabled, enabling frame generation, ray reconstruction, and super resolution results in an astronomical increase in frame rates. On the GeForce RTX 4090, performance multiplies by 4.1X, allowing owners to play Alan Wake 2 at over 120 FPS in Ultra HD with the best quality. The GeForce RTX 4080 sees its performance multiplied by 4.7x, and the GeForce RTX 4070 Ti multiplies performance by 4.7x for gameplay at max settings in Ultra-HD at nearly 80 FPS.
- At 1440p, GeForce RTX 40 series frame rates multiply by 3x on average with full real-time ray tracing and all other settings at max, enabling gameplay at 80+ FPS on the GeForce RTX 4070 and higher.
- At 1080p, the most popular gaming resolution, performance multiplies by 2.7x on average, allowing owners of faster cards to enjoy gameplay at up to 190 FPS.
Based on the numbers, you can clearly see that GeForce RTX 40 GPUs will have to use Frame-Gen to get the best performance in Alan Wake 2 when Path Tracing is enabled. The graphical feature is expected to be very demanding, but with DLSS 3.5 Ray Reconstruction you can look forward to a 14% performance boost, at least NVIDIA says.
NVIDIA has already announced Alan Wake 2 as part of its latest RTX bundle, and the latest game-ready drivers are expected to be available on October 26, which is today and a day before Alan Wake 2 launches.
Source: YouTube
56 Antworten
