DDU is an indispensable software for all GPU enthusiasts. Reviewers and gamers know this very well, and this is where Display Driver Uninstaller (DDU) comes in. The software can completely remove all the data left by the graphics drivers, including registry data, folders and files, and driver memory.
The software was developed by Wagnard and works under Windows 7, Windows 8, Windows 10 and 11. It supports AMD, Intel and NVIDIA GPUs, but can also remove audio drivers. Using the software is relatively simple, but comprehensive instructions are also available in case there are any questions.
DDU works best in Windows Safe Mode and without Internet access. This ensures that no files are in use and the system does not automatically overwrite the missing drivers with updates. The software update brings minor, but still very important changes. A new installer has been added and the license has been updated. Also, the developer has worked on making the dialog messages appear in the right order.
Display Driver Uninstaller V18.0.6.0 Changelog:
- New DDU installer.
- Intel : Registry Power Settings CleanUP.
- The moment that some DDU messages box appear make more sense now. Thanks to a user feedback.
- There is a new button on the safe mode dialog window that allow to set Windows update search for drivers to default. Thanks to a user feedback.
- Updated LICENSE
- Translation : Swedish.xml
Source: Wagnardsoft via videocardz
48 Antworten
