Monitors Practice Reviews
The Cooler Master Tempest GP27U in the “long-term development test” – a real alternative to OLED?
With Cooler Master, we have another player in the monitor market. And with the GP27U, Cooler Master is damn serious and goes “all in”. The UHD panel with 3840 x 2160p resolution comes with a refresh rate of 160 Hz. The panel itself comes from AU-Optronics – Fast IPS and Quantum Dot enhanced with 576 dimming zones and a mini-LED full array backlight awaits us. The monitor is manufactured by KTC in China. We already had a look at a KTC with LG OLED last year. Is that good or rather bad?
I’ll put it this way, KTC offers the “same” monitor as the M27P20P and it can’t even begin to keep up with the GP27U. Thus, I can give the all-clear in advance. Cooler Master stands behind its products and pays attention to quality. Before I go into details, I would like to say a few words about the GP27U and the GP27Q. I have had both monitors in my home since October 2022 and have experienced a few things with both monitors.
Maybe some of you have noticed that the GP27U/GP27Q had some initial problems. For example, HDR did not work in conjunction with Adaptive Sync. The 160 Hz also did not work with VRR, which only worked with 144 Hz. The other things – like color accuracy and color space coverage – really convinced me. Delta E less than 2 was not a marketing joke. Interestingly, the first firmware updates came in November and the “madness” took its course.
(Source: Cooler Master)
HDR with Adaptive Sync suddenly worked, but all color spaces (P3, sRGB, Adobe) were suddenly gone. Color accuracy gone! Then came the next update and then the color spaces were fixed correctly again. But then the gamma tracking and the white point didn’t fit anymore. Long story short. Cooler Master probably wanted to take advantage of the 2022 Christmas business and launched the GP27U and GP27Q monitors too early.
From my point of view – the firmware updates were thrown onto the market untested. Which only made the problems worse. I didn’t publish all this, because I’m not the type who wants to tear down an actually very good product, just to swim along on the wave of clickbait. I am so fair and let the manufacturer the possibility of rectification. Besides, the monitor was basically in very limited supply at the time.
A purchase warning or negative press about an actually very cool product – is hard to get out of the heads again. See the topic of G-Sync causing latency. That still lingers in people’s minds today, even though it’s the biggest nonsense. We humans can do 100 things well and no one cares, but we do one thing badly and people will still be talking about it in a hundred years. That’s how it is – unfortunately! I can keep my mouth shut even without an NDA.
What I really have to praise Cooler Master for is that they took my feedback on the GP27U and GP27Q very seriously. Unfortunately, there was no direct communication initially, which led to more firmware updates being released untested. Contrary to my warning and the offer on my part to send such updates first to me and if necessary to other testers (like Tim from HW UB). In the meantime, there is a direct line to Cooler Master and they have also carried my suggestion of pre-testing to the decision-making levels. I am curious.
Cooler Master sent me a second monitor for today’s test. My first sample is meanwhile covered by firmware updates and own test settings. Thus, the first monitor no longer allows any conclusion about the product a customer buys from the retailer. My second sample is new, but was also flashed to the new firmware afterwards. So here we go with the usual…
Technical Data
As always, here is a PDF and the link to Cooler Master’s homepage: click here!
Product Sheet - Tempest GP27U
Will Cooler Master be able to keep all this in the end? You know the prequel a little bit now. I am curious to see what the second GP27U monitor in my test – with the current firmware – can do now.
Case39
2,432 Kommentare 875 Likes
Guten Morgen und Danke für den Test. Die 1440p Variante hatte ich mal ins Auge gefasst aber zu Gunsten eines OLED Monitors verworfen.
Mit dem Test konntest du immerhin meine Bedenken wegen der fehlenden Gsync Compatible Zertifizierung schon mal ausräumen.
Dazu noch Danke das du Igors Seite mit Monitor Reviews bereicherst👍 Dir noch einen erholsamen Urlaub.
p.s, Meinen OLED Kauf kann ich jetzt noch weiter nach hinten verschieben, da mein jetziger Monitor bewchlossen hat, seinen DP Eingang, doch wieder funktionieren zu lassen🙄😂
FritzHunter01
889 Kommentare 918 Likes
Der GP27Q ist für den Preis aktuelle alternativlos, wenn es um HDR und Color Critical Work geht.
ipat66
1,058 Kommentare 950 Likes
Danke Dir für das aufschlussreiche Review.
Ansonsten wünsche ich Dir einen schönen entspannten Urlaub :)
Gregor Kacknoob
432 Kommentare 332 Likes
Hm, man lege 100€ drauf: OLED, 120Hz, Kontrast Drölfzig:1, perfektes Schwarz, auch UHD, geiles HDR (zzgl. Dolby Vision etc.), geile Farben, geile Latenzen, ggf. sogar noch TV-Funktion mit Zwischenbildberechnung (kann geil sein), ...
Wobei es das auch schon für 800€ als 55" gibt 😅
S
SpotNic
380 Kommentare 152 Likes
Die Schwarzwerte mit Localdimming sind schon sehr gut, auch wenns nur Edgedimming ist wenn ich das richtig verstanden habe. Die Farbgenauigkeit der OLED dürfte wohl auch nicht in den Bereich des hier genannten heranreichen, die Textlesbarkeit ist auch besser.
Haben sicherlich beide ihre Vorteile aber "Besser" kommt nunmal auf den Usecase an. Und der C2 ist immernochn TV und kein Bildschirm, auch wenn sich viele mit dem Schminkspiegel abfinden (ich geh mal davon aus, den meinst du wegen der 120 Hz).
Gregor Kacknoob
Nein, ich habe einen Panasonic. Offengestanden kenne ich mich bzgl. der farblichen Darstellungqualität meines OLEDs oder generell bei OLEDs nicht sonderlich gut aus - bekomme aber 'ne Krise, wenn die Farben (egal wo) offensichtlich nicht gut angezeigt würden (früher bei IPS und auch unabhängig vom Display (Netflix ohne HDR ist ein graus)). Aber der Usecase ist ja Gaming und mir sind jetzt spontan nur zwei Spiele bekannt, bei denen man ein Farbraum für HDR wählen kann. Einmal Cyberpunk und Hellblade. Fraglich ist doch, ob Spiele überhaupt dazu im Stande sind, solch ein gute Farbdarstellung auszureitzen. Will sagen, mag ein Argument sein, aber nicht so richtig mit durchschlagener Wirkung, finde ich.
In Sachen Textlesbarkeit kann ich dir sagen, dass mein OLED hierbei keine Probleme bereitet. Und ich kenne das Problem. Das hatte ich bei Oculus Rift (ganz schlimm), dem Valve Index (erträglich) und bei einem Bildschirm mit MVA-Display deutlich sichtbar, aber via Windows Konfig war es beim MVA gut in den Griff zu bekommen. Bei meinem OLED muss ich nichts einstellen. Das passt so (ohne diese Fehlfarben und ohne Unschärfe an den Rändern). Mit dem Handy lässt sich das aber nicht einfangen, sonst würde ich dazu ein Bild anhängen. Gerade beim Scrollen/Bewegung ist die Lesbarkeit aber unübertroffen. Das betrifft halt auch Schriften in Games.
Was die Spiegelung angeht, naja, es hinderte mich nichts daran, mich darauf einzulassen. Irgendwann sieht man das einfach nicht mehr (ja, wirklich), oder in wenigen Ausnahmesituationen, erwische ich mich dabei, wie ich dann eben aus einem passenden Winkel auf den Bildschirm gucke. Auch sind 46" echt groß, mein OLED ca. 50cm vor meiner Nase und dadurch schiebe ich mir das YT-Video oder so eben dahin, wo nichts spiegelt. Platz ist genug vorhanden. Nebenbei erwähnt habe ich bei meinem Laptop, ohne Glare, auch das Problem. Nur ist es da eben so eine graue Wolke, wo das Licht draufscheint. Da siehste halt auch nicht so viel und muss mich entweder woanders hinsetzen oder den Winkel vom Laptop ändern. Nicht schlimm. Aber diese matte Oberfläche hat auch ihre Nachteile (es ist nicht so "brilliant"/klar wie bei einem Glare).
Mir persönlich ist der angedachte bzw. aufgedruckte Einsatzzweck schnurtz (TV, Gaming, Grafik, bla). Es muss zu meinem Usecase passen. Das tut es - ebenfalls bei den Farben. So ein TV ist auch flexibler. Man muss für YT, Netflix, Filme & Co. nicht den PC anschalten.
Ich möchte noch betonen, dass mir auch der vorgestellte Bildschirm in realife durchaus gefallen könnte. Die Review gefällt mir. Von meinem Bauchgefühl ist (m)ein OLED in Preis-/Leistung besser. Wer mich nach einem Monitor für 1000€ fragt, dem würde ich dann eher zu einem OLED raten - aber fragen würde ich dennoch nach den Schwerpunkten und dann könnte ich es auch demonstrieren. Zugegebenermaßen läuft es bei mir bzgl. IPS eiskalt den Rücken runter - egal ob Office, Gaming oder Videos/Serien/Filme.
Edit: oder passender ausgedrückt, ist mir das Gebotene schlicht zu teuer. Für 400€ ok. Aber Monitore sind ebenfalls wie Grakas im Preis explodiert und abseits von OLED tut sich in dem Markt schon seit Jahren nicht mehr viel.
L
Legalev
34 Kommentare 27 Likes
Reden wir von Monitor oder Fernseher?
Gregor Kacknoob
@Legalev
Gnarf, ein Fernseher ^^ Viele fahren mit dem SUV zur Arbeit. Ich arbeite an einem Display, das als TV vermarktet wird. In der Firma stehen zwei Gamingmonitore auf meinem Schreibtisch 😘
Case39
Wenn der TV es hergibt und der User es gut findet, warum nicht?!
P
Phelan
176 Kommentare 161 Likes
Quasi das ausreitzen der am Ende angekommenen IPS-Technologie :)
Da die OLED Fraktion es irgendwie auch nach 20 Jahren immernoch nicht schaft bezahlbare PC Monitore im Bereich 27-35zoll zu bauen, muss man ebend sowas nehmen.
Mein aktueller Monitor hat 26300 Betriebsstunden weg und funzt zwar noch Problemlos aber irgendwie darf mal was neues auf den Tisch.
Preis finde ich sogar noch ok. Gute Allrounder kosten immer bissel mehr.
Stören tun mich die nur 27". Für 4k hätte ich lieber schon 30-35zoll besser gefunden.
Außerdem war bisher jeder neue Monitor größer ;-)
Die Firmware kann man später im Monitor nachpatchen ?
Monitor mit Softwareupdates ... oh man , ich werd alt oder so.
S
SpotNic
Generell wäre es schon mal ne Mitte zwischen 32 und 42" zu haben, 36 - 38 wären perfekt und dann mal eben kein breitbild (21/9)
Annatasta(tur)
312 Kommentare 99 Likes
Ich finde interessant, dass man hier 4K in 27" auch hochkant hinstellen kann, für DTP (also früher irgendwann mal die Druckvorstufe ;)) sehr angenehm. Fürs Gaming ist OLED in 42" oder 48" auf alle Fäller besser, auch vom PL her.
Case39
Scheint Standard zu sein, das die Firmware patchbar ist. Jetzt warte nochb2-3 Monate und die OLEDs werden richtig bezahlbar.
FritzHunter01
Das können mittlerweile sehr viele Monitore. Firmware Updates brauchen auch immer mehr Monitore....
Z.B: der Alienware AW3423DW (QD-OLED) kann nicht gepatched werden. Wer sich einen gleich am Anfang geholt, der muss seinen Monitor zu Dell schicken, um die neueste Software zu bekommen. Das ist OLD-School
Gregor Kacknoob
Sei froh! Ich hatte mal einen Philips Momentum 42" (Monitor :P), wo beim Aktivieren der HDR-Funktion plötzlich die Anzeigeschärfe auf 50% fiel, obwohl weiterhin 100% in den Einstellungen sichtbar waren. Nach dem Deaktivieren von HDR bliebt es auch weiterhin bei 50%, obwohl noch immer auf 100% stehend. Beheben ließ es sich nur, wenn der Wert kurz auf 90% und wieder zurück auf 100% gestellt wurde. Jedes fu**ing mal.
Der Support konnte nicht helfen und ein Austausch hatte auch nicht gefolgen (gab keine neue Firmware über Umwege). Zu der Zeit hatte ich mir so eine Updatefunktion gewünscht ^^
Aber ja, diese Firmwareupdate sind wie 'ne Seuche. Meine Philips Momentum 2 (Kopfhörer) liefen problemlos ohne Firmwareupdates. Das Nachfolgermodell (optisch billiger, klobiger und der Sound war exakt Identisch, wenn nicht sogar etwas schlechter durch die billigere Hülle) brauchten erstmal Updates. Meine jetzigen Sony XM5 brauchen auch Updates.
Aber immerhin brauchen die Geräte noch kein Day1-Patch 🤯 ... außer manche AMD Mainboards 💩
Gregor Kacknoob
Was ich ja gut finden würde, wäre so ein Konstruktionskonzept für Monitore, wie wir es von PCs kennen. Entweder ein Fertig-Monitor oder man stellt sich ein selber zusammen. Dann kann man sich die Auflösung, die Größe und auch so Sachen wie die Elektronik selber zusammenstellen. Denn was die maximalen Hz angeht, so denke ich als Leie, dass das mehr mit der Elektronik (Ansteuerung) als mit dem Display (Umsetzung) zutun hat.
Dann wären keine Wünsche mehr offen. Das darf auch mehr kosten finde ich. Ähnliches wünsche ich mir auch für Mainboards. Denn wenn eines nervt, dann das versucht wird jede noch so kleine Nische bzw. Trend zu bedienen und ganz erlich: ich brauche keine zwei Lan Ports, Wlan, Audio etc. und möchte nicht notgedrungen 500€ für 10% des von mir genutzten Funktionsumfangs bezahlen müssen. Ich mein, dafür haben wir doch die PCI-Slots, von der in 99% (heutzutage) nur einer für die Graka genutzt wird. Man man man ^^
Aber wer weiß. Das gibts ja mittlerweile auch für Handys und Laptops. Begrüßen würde ich es auf jeden Fall ... auch aus Umweltgründen :)
FritzHunter01
Interessante Idee... Schreib mal LG, Samsung etc. an, bin gepannt, was die dazu sagen :ROFLMAO:
Ghoster52
1,125 Kommentare 748 Likes
Dafür gibt es dann die vielen Modelle mit unterschiedlicher Zeichenfolge, wo sich keine Sau mehr auskennt. 🤪
Die Firmware zu patchen ist gar nicht mal schlecht, wenn der Monitor / TV nicht ganz rund läuft,
kann man in wenigstens eckig patchen. :LOL:
Gregor Kacknoob
Ich dachte schon an Linus Tech Tips, weil die ja auch Framework (Laptops) mitfinanziert haben. Ist ja keine neue Idee. Als Pragmatiker wäre das halt voll mein Ding :)
Fritz Hunter
