Allgemein Case Latest news System
Corsair 5000D, 5000D Airflow and iCUE 5000X RGB cases announced
Corsair is announcing the new 5000 Series cases at CES 2021. Continuing the naming scheme and design language introduced with the 4000 Series in late September, the 5000 Series is available as the 5000D, 5000D Airflow and iCUE 5000X RGB. In addition to the black variants, there will also be white variants of the model. The 5000 Series is therefore the big brother of the 4000 Series and offers an increased internal volume and thus many new possibilities for system builds.
CORSAIR 5000D / 5000D AIRFLOW – MSRP: 154.90 Euro
  • Clean and Cool: The 5000D makes a stunning, showpiece-worthy PC easy to build, and even easier to keep cool with the space and flexibility to mount multiple 360mm radiators.
  • High-Airflow Front Panel: An optimized steel front panel delivers massive airflow to your system for maximum cooling (5000D AIRFLOW) / Solid Steel Front Panel: Offers superb durability and sharp looks, with wide ventilation channels for ample airflow. (5000D)
  • CORSAIR RapidRoute Cable Management System: Makes it simple and fast to route your major cables through a single hidden channel, with an easy-access hinged door and a roomy 25mm of space behind the motherboard for all of your cables.
  • Two Included 120mm Fans: CORSAIR AirGuide fans utilize anti-vortex vanes to concentrate airflow and enhance cooling.
  • Motherboard Tray with Customizable Fan Mounts: Side-mount up to 3x 120mm fans or up to a 360mm radiator, enabling new flexible cooling options.
  • Maximum Cooling Potential: A spacious interior fits up to 10x 120mm or 4x 140mm cooling fans, along with multiple radiators including up to a 360mm in front or side and a 360mm push/pull in the roof.
  • Modern Front Panel I/O: Puts your connections within easy reach, including a USB 3.1 Type-C Port, 2x USB 3.0 port, and a combination audio/microphone jack.
  • All the Storage You Need: Fits up to 3x 2.5in SSDs and 2x 3.5in HDDs.
  • Tool-Free Tempered Glass Side Panel: Show off your high-profile components and RGB lighting.
CORSAIR iCUE 5000X RGB – MSRP: 189.90 Euro
  • Clear, Clean, and Cool: The 5000X RGB makes a stunning, showpiece-worthy PC easy to build and easier to keep cool with the space and flexibility to mount multiple 360mm radiators, all surrounded by beautiful tempered glass on four sides.
  • Four Tempered Glass Panels: House your system behind tool-free tempered glass, highlighting your components and RGB lighting.
  • CORSAIR RapidRoute Cable Management System: Makes it simple and fast to route your major cables through a single hidden channel, with a roomy 25mm of space behind the motherboard for all of your cables.
  • Three Included 120mm RGB Fans: CORSAIR SP RGB ELITE fans utilize AirGuide anti-vortex vanes to concentrate airflow and enhance cooling. Each fan is equipped with eight individually addressable RGB LEDs for brilliant lighting.
  • Smart RGB Lighting Out-of-the-Box: Fully control and synchronize the RGB lighting for up to six fans with the included iCUE Lighting Node CORE and CORSAIR iCUE software.
  • Maximum Cooling Potential: A spacious interior fits up to 10x 120mm or 4x 140mm cooling fans, along with multiple radiators including up to a 360mm in front and a 360mm push/pull in the roof.
Below you can find the specs of the three cases in an overview for direct comparison:
Before the full review I want to give you a little visual insight behind the scenes and on the following pages a few impressions of the new iCUE 5000X RGB case.
