Monitors Practice Reviews
Bargain check: ASUS VA24ECE LCD monitor in test – What can you get new for under 100 euros?
Before I focus on the new flagship models with OLED panels in 2024, let’s take a look at one of the cheapest entry-level gaming or home office/second monitors that you can currently buy. The ASUS VA24ECE comes with a 24-inch 1920 x 1080p Full HD IPS panel and a maximum refresh rate of 75 Hz. I can’t tell you which manufacturer the panel comes from. Doesn’t really matter in the end.
There’s not much to say about the packaging either. ASUS takes a rather thin and economical approach here. The monitor made it to my home undamaged – that’s a good thing! It remains to be seen whether the monitor will survive the onward shipment to Tim Kutzner. The ASUS VA24ECE was not provided by ASUS, but was bought as normal. Tim wanted something cheap and I thought we’d test the economy model right away.
The IPS panel comes with a color depth of 8 bit (6 bit FRC), AMD FreeSync (48 Hz to 75 Hz VRR) – without LFC. I assume RGB for the sub-pixel layout, as I couldn’t detect any text rendering problems. ASUS specifies a pixel response time of 5 ms, which I think is realistic. You can find the rest of the technical data here: Click!
You can also scroll through the PDF. The data comes from the ASUS homepage.
The specifications
ASUS VA24ECE
Let’s see what the small ASUS VA24ECE has to offer…
T
TheSmart
536 Kommentare 292 Likes
Danke für den Test vorab.
Für den Preis ist das gebotene voll in Ordnung.
Okay die fehlende Ergonomie könnte manche echt etwas stören, aber dafür kann man das Teil auch mittels VESA an einen Monitorarm dran hängen.
Nur ein Officemonitor ohne VGA?
Das braucht man normalerweise immer noch recht häufig.
Also meiner Erfahrung nach.. ich kenne viele Sparbrötchenunternehmen, die bei den PC´s ordentlich sparen^^
2,279 Kommentare 1,468 Likes
Stimme weitgehend zu, nur das mit dem abwesenden VGA Anschluss würde mich eigentlich nicht stören. Bei einem Beamer für ein Konferenzzimmer vielleicht noch ein bisschen, aber selbst dafür - es gibt ja kaum noch PCs, die VGA Anschluss bieten. Selbst mein schon recht alter Laptop vom Arbeitgeber (fast 4 Jahre alt, wird bald ausgetauscht) hatte schon kein VGA Out mehr. Mein Haupt "Problem" mit dem Monitor ist, daß er mir als Hauptmonitor zu klein wäre, aber als Zweit- oder Drittmonitor für Office Geschichten - warum nicht? Frage @FritzHunter01: Kann man den auch hochkant (Portrait) aufstellen; wenn nicht direkt, dann mit entsprechendem VESA Mount?
Unabhängig davon finde ich es sehr gut, daß Du und Deine Kollegen hier auch mal die unteren Preisgefilde mit abdeckt. Gute Sachen teuer einkaufen ist einfach(er), etwas gutes für wenig Geld finden eher schwierig! Und manchmal tun es solche Geräte ja durchaus, und passen gut rein!
S
SpotNic
1,330 Kommentare 600 Likes
Also wer heute noch mit VGA rumfuchtelt läuft wirklich am Leben vorbei, Privat wie auch gewerblich. Das ist kein Sparunternehmen mehr sondern Huddel und Brassel.
T
TheSmart
Selbst mein Mainboard, das ich 2019 gekauft habe und ein sogenanntes Officeboard ist mit B-Chipsatz, hat noch einen VGA-Anschluss bzw es hat selbst noch einen PS/2 Port :D. Das fand ich schon fast lustig. Denn wenn VGA alt ist.. dann ist der Port quasi antik^^
Und mein auch damals gekaufter Monitor hat auch noch einen VGA-Ausgang.
Ich habs mir zwar nicht deswegen gekauft..
Eher weil ich die ganzen teuren Features von den Gaming-Boards überhaupt nicht brauche.. aber daran merkt man.. es war zumindestens zur damaligen Zeit noch immer sehr verbreitet.
s
scotch
179 Kommentare 150 Likes
Ich habe als Zweitmonitore den HP P24q G4 für 119€. Der kleine hat eine WQHD Auflösung (2560x1440) und zaubert ein super Bild für das Geld.
FritzHunter01
1,346 Kommentare 1,839 Likes
VESA Montage ist möglich. Ohne kein Hochformat!
Megaone
1,920 Kommentare 1,835 Likes
Top Test. Ich freue mich immer, wenn preiswerte Produkte unter die Lupe genommen. Aktuell droht ja PC-Gaming zu einer elitären Veranstaltung, ähnlich wie Hifi zu werden.
Und nicht jeder kann oder will ein kleines Vermögen oder den Preis eines Jahresurlaubs oder mehr dafür ausgeben.
Antwort 8 Likes
grimm
3,481 Kommentare 2,483 Likes
Kann mich @Megaone nur anschließen. Habe aber eine Frage: Der Messaufbau weist 4090 FE und 7900XT als GPUs aus, bei den Wattzahlen zum Stromverbrauch ist nur ein Wert gelistet - gilt der für beide Karten? Ich hatte im Hinterkopf, dass die AMDs beim Idlen mehr Watt ziehen...
FritzHunter01
Das ist der Stromverbrauch des Monitors, nicht der der GPUs!
Rizoma
254 Kommentare 271 Likes
Uf 24 zoll 1080p mit 75hz :oops:
"Das Jahr 2000 hat angerufen und will sein Monitor zurück" Gibt es wirklich noch jemand der sich so etwas neu kauft? Ich würde es nicht mehr kaufen.
FritzHunter01
Ja, sowas wird tatsächlich noch gekauft. Warum auch nicht?
Bitte nicht die eigene Einstellung auf die Allgemeinheit übertragen.
Antwort 6 Likes
Guest
Danke für den Test!
" (..die neuen Flaggschiffe mit OLED-Panels fokussieren werde..)"
Also die nun 4te Iteration von TITANIC DAMPFER mit minderwertigen EISEN NIETEN die das bekannte Ergebnis liefern.
Der EISBERG ist der BREITE RÜCKEN des KONSUMENTEN, der nix dafür kann DAS ER, SIE, das EXPERIMENTIERFELD
der Branche ist, die sich in den Highlands beim Schampus über selbige totlachen. BEZZOS.. was kommt nach BILLIONÄR? lol
Also. Du bist seht gut und Dir steht die STÄHLERNE HÄRTE EINES IGOR TEST LABOR MANNES.
Mehr sei nicht gesagt.
Ich gehe davon aus das 20 bis 35 % mit gebotener Leseschwäche oder angeborenem LATEX ums Hirn geil
auf die DOMINA GELDVERNICHTUNG sind und im Wettlauf des Kollektivs kaufen und so den Markt anheizen
und die Verzögerung ( da drüben 20 Hutirebellen.. geht sich grad noch aus für die 27 mm Mauser.. alle zerfetzt)
die nach dem Corrona nun das neue Normal bringt. Das soll nicht nix heißen. Is so wie 2013 sieht man ehemalige
du weißt schon wer Fachleute ( ex spetnatz) die Libyen desavouieren.. 2024 eifern Bauern um und sollten eig vor den
Toren ihrer PREIS KNECHTER oder der Lebensmittel-Camora LIDL ALDI und CO stehen, die ebenfalls ins perfide
Konzept des Petersburger Schachspieler passen, dessen Langzeitplan aufgeht.
Und wenn es nun noch regenet, den ganzen Sommer.. au backe.. nix da.. HUNGER... ( wie geht sich das aus?)
in a nutshell : DIESE MONITORE KOMMEN AUS TAIWAN.. da war doch noch was?
Anmerkung: haut eure gebrauchten noch net weg. Kann sein, das die echt sau teuer werden.
" Guck da fährtn Volchswogen, datt Teil soll nun 99.000 Eoro koste. Weit hatsch de Gölf gebroch net wohr?"
( wir reden von einer 11.900 Euro-karre)( marktperversium24)
KARNEVALL von VENEDIG 247 365 oder?
ps. ich bezeichne mich als sozialist der grad in einen 6liter V12 Lamborghini hockt. start... geil :)
DEIN PEIN HARTER TEST IST GARANT! GRAD WEGEN INFLUENZA ( eitrig fiebriger Ausfluss) MARKETING und dem Gelächter.. peace :)
Rizoma
Wqhd in 27" gibt's ab ca. 160€ und UHD ab ca. 200€ warum sollte man dann noch 1080p kaufen?
LEIV
1,620 Kommentare 685 Likes
es gibt auch noch GPU für full HD...
Und so bekommt man ein gutes Allrounder Paket (PC, Monitor, Maus und Tastatur) für ~1000 Euro hin
Antwort 5 Likes
Megaone
Und dann hab ich auch ein relativ stromsparendes System, was ja leider auch immer mehr zum Thema wird!
Rizoma
Und selbst dann würde ich diesen Monitor nicht kaufen. Einfach deswegen weil der Monitor das Teil ist was meistens vom ganzen System am längsten genutzt wird alles andere erhält viel früher ein Upgrade. Gerade da würde es sich lohnen in etwas besseres zu investieren und wenn es nur die 20-30€ für 144Hz sind
Ghoster52
1,618 Kommentare 1,301 Likes
Dein ernst ??? Bitte bedenke, es gibt auch Mitmenschen, die auch gern mal ihren Retro PC aus dem Schrank holen
und Spiele aus vergangenen Tagen zocken möchten. So einfach aus Spaß, oder um den Kindern alte Technik zu zeigen. ;)
2. Punkt ist der Kostenfaktor, nicht jeder wirft mit Hunnis um sich und nutzt vielleicht auch nur eine billige interne Intel-GPU.
Die 10 bis x € können schon zu viel sein, wenn man nichts über hat !!!
S
SpotNic
Als zweitbildschirm gerade im Potraitmodus doch vollkommen ausreichend. Hab davon 2 neben dem 42er hochkant und mit absicht 1920 x 1200 weil 2560 weiter weg ist von 2160 als 1920 ;)
S
SpotNic
Die gibt es, ich kram jedes Jahr ne WII aus dem Keller und trotzdem erwarte ich keine analogen Eingänge an aktuellen Geräten.
Fritz Hunter
