But it’s about time there were 32-inch monitors with OLED panels – or what do you think? Today we take a closer look at the ASUS ROG Swift PG32UCDM. A monitor in 16:9 format with a resolution of 3840 x 2160p and a refresh rate of up to 240 Hz. The built-in panel comes from Samsung Display, a 3rd generation QD-OLED panel with a slightly adapted subpixel layout. I don’t want to waste time with sob stories at this point, so let’s get started!
The packaging is unmistakably ASUS ROG. Inside, the panel is protected by foam and the rest is cardboard. I personally like that very much. Basically, this should protect it from damage during transportation.
The PG32UCDM comes with a lot of features, some of which we’ll look at in detail today, but I won’t go into everything. It’s definitely worth taking a look at the ASUS ROG homepage. (Click here!)
Technical data
ASUS-Datenblatt_ROG-Swift-PG32UCDM_03.24
We have a lot to cover, I would say… You may now accompany me on my adventure with the PG32UCDM. It will certainly be interesting for you. I can assure you that ASUS ROG in Taiwan has a surprise or two in store for you today!
- 1 - Introduction, Features and Specs
- 2 - Workmanship and Details
- 3 - How we measure: Equipment and Methods
- 4 - Pixel Response Times
- 5 - Display Latencies
- 6 - Color-Performance @ Default Settings
- 7 - Direct Comparison and Power Consumption
- 8 - Color-Performance calibrated
- 9 - HDR-Performance
- 10 - Summary and Conclusion
101 Antworten
