CPU Latest news
AMD Ryzen 7 5700G, Ryzen 5 5600G and Ryzen 3 5400G leaked – Cezanne APUs with closer specifications and first benchmarks
Meanwhile, more and more specifications for AMD’s Ryzen 5000G Cezanne ‘Zen 3’ desktop APUs have also leaked out and a total of three upcoming models seem to be confirmed in the process. The AMD Ryzen 5000G family will be the direct replacement for the Zen 2.based Ryzen 4000G Renoir family, which was introduced last year for the OEM segment as a Pro-only variant.
The new Cezanne desktop APUs will feature the latest Zen 3 cores that have already made their debut in the Ryzen Mainstream, Ryzen Mobility and EPYC server platforms. The new family is said to consist of three processors, including the Ryzen 7 5700G, Ryzen 5 5600G and Ryzen 3 5400G.
The AMD Ryzen 7 5700G is supposed to be the flagship in the lineup and equipped with 8 cores or 16 threads. The clock rates are specified with 3.8 GHz base and 4.6 GHz boost. The CPU has a total of 16 MB of L3 and 4 MB of L2 cache and the TDP is specified at 65 W. The APU will also have an integrated Vega GPU with 8 CUs (512 stream processors) running at a clock speed of around 2.1 GHz. The CPU is expected to retail at around $350 to $400. Chiphell even had some benchmarks of the APU online already:
The AMD Ryzen 5 5600G will be the 6-core (12 threads) offering within the lineup. The APU is said to come with a base clock speed of 3.9 GHz and a boost clock speed of 4.4 GHz. The CPU is also said to get 16 MB of L3 cache and 3 MB of L2 cache. The exact Vega iGPU configuration for the Ryzen 5 5600G is currently unknown, but the TDP is also likely to be 65W.
The last thing mentioned is the AMD Ryzen 3 5300G, which will be a standard 4-core, 8-threaded APU. The chip is said to offer a base clock of 4.0 GHz and a boost clock of 4.2 GHz. The APU is said to be equipped with 8 MB of L3 cache and 2 MB of L2 cache. The Vega iGPU configuration is also unknown for this chip, while the TDP is expected to be 65W. It’s safe to assume that the Ryzen 5 5600G will retail at around $250, while the Ryzen 3 5300G could be in the $150 price range
Source: Momomo_US, Chiphell
Martin Gut
8,818 Kommentare 4,329 Likes
Das kann ich mir schlecht vorstellen, dass die Prozessoren mit Grafikeinheit billiger sein sollen als die entsprechenden 6 und 8-Kerner ohne Grafik.
C
Capsaicin
211 Kommentare 92 Likes
Was für die Marktpositionierung und damit den Preis zählt, ist vor allem die CPU-Leistung, und die ist durch geringeren Takt und halbierten L3-Cache geringer.
Allerdings könnte die derzeitige Situation das uU. diesmal anders aussehen lassen. Oder es ist wie bei Renoir, der offiziell gar nicht für Endkunden verkauft wurde, da waren die Preise auch untypisch.
Guest
Wann wird der Prozessor denn endlich auf den Markt kommen und von HP/DEll/Fujitusi eingebaut?
C
Capsaicin
Ein anderer Leak spricht von Juni
R
Ryzen
55 Kommentare 8 Likes
Ich weis nicht warum, aber ich liebe APU‘s ^^
Habe selbst momentan eine Ryzen 3 2200G APU und bin begeistert.
Follow Igor:
