You would think that Windows 11 automatically includes at least the most important standard drivers. The WLAN is active and there might even be an Ethernet cable in the LAN port. You feel well prepared and then you get to a point where you really wonder if they smoked some special weed in Redmond. I have rarely seen so much stupid ignorance and idiocy in a setup program. I already had a similar case where you had to assign the PIN and couldn’t due to the lack of a network. At that time, plugging in a generic WLAN stick helped. But in this (my own) case, which I describe today, not even that helped.
But if you want to use a more recent Z690 or Z790 motherboard, for example, which uses Intel chips for both Ethernet and Wi-Fi, then it’s not that rare to see something like in the picture below. Enjoy the simplicity of this window without a back or close button. The link to a website is a mockery, because you need a second computer for that. Fact is, Windows can’t be installed ready at this point. Without arms no cookies and without drivers no network. Not even when a generic WLAN stick is plugged in. And now?
95 Antworten
