GPUs Practice Reviews
Saving a Gainward RTX 2080 Ti Phoenix GS – Replacing thermal pads correctly | Practice
Even if time is extremely short, I’m happy to help the community once in a while, because this case seemed almost unsolvable for the user. During the deconstruction of a Gainward RTX 2080 Ti Phoenix GS pretty much everything went wrong that could go wrong to end up with GPU temperatures of over 90 °C (hotspot 110 °C) again and again, even after countless attempts, which was indiscussable and not usable (up to emergency shutdown). Even the heights of the pads were correct, which were specially checked by the manufacturer.
Well, at least in theory, because how is a user supposed to know how the manufacturer combines the thickness and the degree of hardness of the pads in such a way that the highest possible manufacturing tolerances can also be reliably compensated? The user, on the other hand, always buys pads only according to the printed values of thermal conductivity, but never pays attention to their hardness. A lot of money spent for nothing! To make sure that doesn’t happen, we need to talk today. Because I also counter-prove that a “crumb” pad with “only” 3.5 W/mK can work better in case of doubt than expensive pads with 7 W/mK or more, if they are too hard and therefore completely unsuitable.
The customer had also used shorter spring bolts to achieve more contact pressure, but the length alone does not guarantee a change. But I’ll get to that in a minute. At least no stone was left unturned, even if all the efforts ended up producing nothing except unnecessary extra costs. Therefore I let soften with to rebuild the card again professionally and to lead back with it also into the commodity cycle. In times of scarce offers certainly not the worst solution!
I have to preface this with one thing, though, because I’m definitely not a garage. I would really like to ask you to refrain from inquiries if I could rebuild or repair one or the other, unless it is really such a difficult case as today. I like to help (in an absolute emergency), but only members of our community and then also not commercially, but purely as a private person with a very small time window and also only in their own free time. Please understand that, because it’s getting a bit much lately.
Hans Yolo
126 Kommentare 29 Likes
Vielen Dank für die Erfahrungen und den Bericht. Ich hab ein ähnliches Problem nach einem Umbau der rog strix oc 3090, unter Wasser habe ich neue Pads drin montiert, die von der Höhe stimmen sollten trotzdem habe ich 10-15 grad schlechtere temperaturen für den vram.
werde mir den Artikel in aller Ruhe wieder zu Genüte führen und versuchen für mich etwas abzuleiten. Ein erneutes Umbau erfordert ja jedesmal ein leeren des Kreislaufes, und befüllung zum testen…. 🤮🤮
LEIV
1,605 Kommentare 681 Likes
Hätte da grad mal ne allgemeine Frage:
Theoretisch reicht es ja aus, 0.5 und 1mm "Brösel" Pads zuhause zu haben, falls man mal an einer GPU rumbasteln will?
11,319 Kommentare 21,488 Likes
Im Prinzip ja. Oder noch ein paar Fujipoly wegen der bessen W/mK und den Brösel für den weicheren Abdruck auf der Platine in Kombination :)
Megaone
1,920 Kommentare 1,834 Likes
Nach dem Paddesaster der 3000er Serie hab ich meine 3090 auf Wasserkühlung umgebaut. Hab mich eisern an die Empfehlungen aus dem großen Pad Test gehalten. Allein die Pads haben über 40 Euro gekostet. Aber unterm Strich hat es sich gelohnt.
ro///M3o
385 Kommentare 279 Likes
Sehr gut, in solch verrückten Zeiten ist jede gerettete Karte ein großer Gewinn für Umwelt, Gamer und dessen Geldbeutel 😁✌🏼Super Aktion Igor.
WeAre138
39 Kommentare 13 Likes
Bei Alphacool (die Pads habe ich noch unverbaut hier) wird die Härte mit/nach ASTM 2240 angegeben, wenn die Information überhaupt irgendwo geschrieben steht. Habe lange gebraucht um einige Infos in PDFs oder auf der Webseite zu finden und das lange nicht zu allen Pads.
Beim "Alphacool Apex Soft Wärmeleitpad 11W/mk 100x100x1mm" wird sie z.B. mit 72 Shore OO angegeben - und die sollten doch soft sein!
Also entweder ist das irgendwie 'ne andere Messmethode, die die anwenden oder ich bin zu doof... Aber du schreibst ja auch von SHORE A und nicht von SHORE OO. Verwirrend für den interessierten Nichttechniker. Kann man das vllt. umrechnen?
Leider fand ich zu meinen hier liegenden Pads "Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm" keinerlei Angaben...
KyoEvo
5 Kommentare 0 Likes
Ich will meine 3080Ti mit dem Alphacool Eisblock Aurora Acryl GPX-N ausstatten. Ist auch mein erstes mal das ich eine Custom´s Wasserkühlung ein baue. An Stelle der mitgelieferten 3W/mk Pad´s habe ich auch vor die Alphacool Apex Soft / Eisschicht Wärmeleitpad 11W/mk zu nehmen.
Aber bei dem Härte-Thema müsste ich ja dann eher die Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk. nehmen die einen Shore von 25 haben.
Die 11W/mk gegenüber den 7W/mk haben mich in Igor´sVideo „Wärmeleitpads im Test auf der NVIDIA GeForce RTX 3080 – GDDR6X-Temperaturen um bis zu 50% niedriger!“ aber von der Leistung mehr überzeugt. Was würdet ihr mir raten? Trotzdem die 11W/mk?
thebagger
104 Kommentare 77 Likes
Erst einmal Danke für den informativen Beitrag!
Ist zwar ein kleines bisschen Offtopic aber, ich hab vor ~2,5 Jahren eine 2080 TI auf Wasser umgerüstet und vor ein paar Wochen wieder zurück mit den original Pads (meiner Meinung nach Sauber abgezogen und schön in Folie weggepackt.) Verlieren die Teile auch mit den Jahren ihre Wirkung? Sollte ich da neue draufschrauben?
Ist ne EVGA XC Black Edition / Furmark ~80°C und ~101°C HotSpot.
Fairerweise muss ich anmerken, ich habe den Luftkühler nie getestet vorher.
Falls der Beitrag hier falsch ist gerne verschieben/löschen :)
feris
46 Kommentare 23 Likes
Spannendes Thema. Ich verschlinge immer mehr Artikel hier, denn es macht Lust auf mehr!
Kleiner Vertipper beim Fazit:
KyoEvo
Danke für den Link. Das hilft sehr viel einen besseren Überblick zu bekommen.
Case39
2,589 Kommentare 993 Likes
@Igor Wallossek Danke für den Artikel und die enthaltenden Tipps.
i
istherelifeonmars
77 Kommentare 13 Likes
Ich hatte mal das Problem, daß die Schrauben mit den Federn alleine nicht ausreichten, um die Wärmeleitpaste gleichmäßig zu verteilen.
Nach zwei Monaten hatte ich dann immer freezes in Spielen.
Das ganze hatte dann zur Folge, daß ich alles nochmal machen mußte.
Diesmal habe ich aber mit einem Druck mit den Fingern nachgeholfen, damit die Paste sich besser verteilen konnte und hab jetzt seit einem halben Jahr Ruhe bei besseren Temperaturen und ruhigeren Lüftern.
WeAre138
Ja, hilft. Danke Dir!
Ok, ist offtopic: Aber weiß zufällig jemand, wieviel Pads (cm²) ich circa für eine RTX 3080 benötige? Also nur ungefähr, damit ich einen Anhaltspunkt habe, denn die sind ja teilweise doch arg teuer. Wollte eine Gigabyte Gaming OC mit niedrigeren Temparaturen entlasten...
LEIV
Eine generelle Auflistung für alle gängigen GPUs wäre schön
h4rp00n33r
46 Kommentare 11 Likes
Im Artikel steht: "Es ist generell wichtig, nicht zu viel Druck anzuwenden, um nichts zu zerstören oder kleine Komponenten abzureißen. Das geht oft schneller, als man glauben mag!"
Nun bekomme ich ein wenig Schweißperlen auf der Stirn, da ich die Reste zwischen den Kerkos neben dem Die doch recht "beherzt" gereinigt habe. @Igor Wallossek Soll ich sicherheitshalber nochmal mit der Lupe kontrollieren, ob da Lötstellen angerissen sind oder gibt es nur die beiden Zustände "Dran" und "Ab"? Bin da ein wenig paranoid... :confused:
Beim Zusammenbauen waren alle Bauteile dran und die Karte funktioniert auch einwandfrei.
Martin Gut
8,277 Kommentare 3,942 Likes
Wenn es läuft, würde ich es sein lassen. Mehrmals aufschrauben macht es auch nicht besser. Dazu sieht man auch mit einer Lupe nicht jede Beschädigung. Man ist also nicht viel schlauer, wenn man es nochmals öffnet und prüft.
h4rp00n33r
Das hatte ich befürchtet, trotzdem Danke für die Rückmeldung. Wie gesagt: Läuft seit einem Monat (Wärmeleitpadwechsel) problemlos.
Follow Igor:
